Thanks! That’s good to hear. Looking forward to seeing AT but honestly I don’t think I’ll want to pay a monthly fee. For me a touchscreen dashboard is more of a nice-to-have/cool factor thing but I don’t have a strong use case for it. I’d probably just stick with voice control through Alexa and Google Home. I am considering using HomeAssistant as a dashboard for ST via MQTT. I’ve used HA before and it’s a pretty nice interface. But like I said, it was more of a cool factor for home automation. Regardless, I’m interested in seeing what you have coming with AT!
tgauchat
23
Thanks… We’re looking forward to showing it off, and especially making sure it is obvious that it will have the potential to have boundless continuous improvement and new features.
We want Customers to feel the price is reasonable and and incredible value. And the product / price is one they will recommend to all their SmartThings friends!
honestly im not 100% sure. i set both fires to turn the screen off after 15 seconds, but i think i have a setting in the Fully Kiosk app that keeps the screen on overriding the system setting. every time i walk into the rooms with the fires, the screen seems to be on before i get there, so i need to check that tonight.
i will say, though, the nexus 7 that i have ST on with Fully will turn the screen off, then it comes back up when i walk into that room. i did have to log it back in a couple of times, but i changed one of the settings in that app so every 10 minutes, no matter what, it will automatically refresh the page. Im hoping thats enough to make sure it stays logged in, since the app wont save my email/password, its a pain to retype it every night. i should know for sure tomorrow if it works, it would time out during the day while we are out of that room all day.
To get rid of the lock screen you must get rid of FireOS. Just install Cyanogenmod. It’s pretty easy.
Root junky’s scrips are very simple. Open them in a text editor to see what they are doing. It will help when something goes wrong and the script can’t help you.
I have tasker wake the tablet every 15 minutes. All is well unless chrome crashes, which is does every couple of days, or there is an app update, which sometimes screws up tasker.
The stability of this setup leaves something to be desires. Too many things can go wrong. The Fire’s get slower and slower the longer they are on. There’s a memory leak somewhere. I see the same issues running FireOS 5.3.1 as CM 12.1. I think it’s Chrome. . . . . Right now there seems to be some kind of Smartiles issue. They all errored out and the launcher screen only has the help button. . . .
I went ahead with installing CM12 on it, removed lock screen, installed fully kiosk, enabled motion detection (when tablet goes to sleep) and auto reload every 15 minutes (for smarttiles login issue) and I seem to be good to go for now. Thanks for the help. Now I have to see if all of this will work on a Fire HD 8 as well.
I think I’ll do that, too. I guess bypassing the lock screen on the fire just won’t work. Sounds like CM takes care of that, so it’should worth a shot.
Are you still seeing that the fire with fully Kiosk Browser turns it on with the lock screen off? I rooted and turned off the OTA like you then installed FKB and I keep getting an error that it can’t make itself the default home app. Thus when I approach it the lock screen is greeting me. I tried installing Nova like you did but it didn’t change the result. Is there a setting in Nova t allow this to work?
yeah, when mine wake up it goes to the lock screen. you might need to set Nova as the default launcher, but that probably wont fix the lock screen problem.
i think its an issue with the Fire OS. i hadnt realized that even though the OS was set to turn the screen off after 15 seconds, Fully was set to keep it on all the time. So when i turned that option off, when the motion would wake the screen, it would be the lock screen, Fully couldnt bypass it. It looks like thats a limitation of the OS, so im going to try CM soon (hopefully this weekend, at least on one of them) and see if that gets around it. Others in this thread have had luck with that, with all of the other configurations the same, so i really think its just something in fire OS that Fully cant get around.
Did you copy all the zip files to an SD card on the fire? I don’t have one so I’m worried I’ll mess something up when it tries to write info to the internal storage, where all the files are
Like Mike mentioned, I couldn’t get it to work as well by just rooting the fire. Had to go one step further and install CM 12. A lot more customization that way.
I put CM12 on one of them and it’s already working better. It turns the screen off and Fully will actually wake up the screen now how it’s supposed to. It wasn’t that tough with FlashFire, either, I just grabbed the wrong Google Apps package so that took a little time to work out. I’ll probably do the other one this weekend.
I have to do my other fire 7 as well. Are you doing this on fire 7’s or the fire HD 8? I have one of those too but not sure if this will work since it’s newer and may not be able to be rooted yet.
It is possible to enter your tablet into developer mode (similar to getting an Android tablet into developer mode). There is then a selection that allows you to keep the screen on at all times so long as the kindle is plugged into power. This way it can be a screen for your smart home without seeing the ads.
Path:
Settings>Device Options>Serial Number [Tap repeatedly until you see Developer Options]>Developer Options>Stay Awake (First option)
Using Flashfire, do the zips definitely go somewhere in INTERNAL storage? When it wipes, wouldn’t it delete the zips also? Rootjunky guy says to put the zips in External, so it’s confusing. I’m having issues.
