Hi @bangali
So have you moved over to the habitat hub yet or are you still between the two
With the averaging you have implemented with the LUX itās providing at least for me a better experience for adjusting my lights as I have light and dark and angles in most of my rooms, my kitchen alone as 4 Lux Sensors in basically each corner
Just wondering if you could add the following somewhere (not even sure if it makes sense). Iāve had a look at the view all settings options and have a potential place for it, but I don;t know if its feasible or even worthwhileā¦but as they say if you don;t ask you donāt know.
The same idea would apply in my mind to any of the sensors where the number of the sensor is used.
Under Room Sensor Settings, where you list all the relevant sensors would it be possible to capture the numeric value of the sensor in question at the point in time where All Settings was hit (or last cached value, not sure how you are coding the attributes).
In my case I have 4 Lux Sensors in my kitchen, that Iām using to figure out my best average to use in the app, but to get each of the devices lx values I need to leave the add, go to the relevant room, enter every device, note down the values, and do the average myself, then adjust in Rooms Manager to work more precisely. But if this sensor information was available in the app itself it would cut down on some clicks
What I was thinking was after the name of the sensor in question, Room Lux1 (10), Room Lux2 (20) was entering the value in brackets after the devices name or something similar.
As I said, just throwing it out there
On another note, going to start testing the holiday nights now that Halloween is coming up Can you believe its a year gone already!!!
