Yes, I’d still like to have it based on the ST mode. That’s the built in mechanism for this.
I could possibly use a button. I already use a button to change ST mode to “night”, but it’s a hold, not just press, and the rooms manager doesnt have that functionality. Could you change that? The reason I want hold is that turning on the alarm, and turning off all lights downstairs is not something I just want to bump, or a kid to press.
this is currently happening for many apps not just rooms manager apps. i am finding the same error for other apps including many of my existing pistons.
so very likely there is a ST platform issue ongoing. something similar to this:
I just started using your smartapp (really cool btw, thanks!), installed all the necessary things and configured two rooms. I added a new motion sensor after configuring the second and when trying the configure the third I’m now getting “Error saving page”. The log shows the following:
Yeah! I was looking at the logs when switching from Vacant to Occupied back to Vacant (for the working rooms) and there seem to be other exceptions as well:
01:12:08: error java.util.concurrent.TimeoutException: Execution time exceeded 20 app execution seconds: 93871173915056 @line -1 (doCall)
01:12:08: error java.lang.reflect.UndeclaredThrowableException @line -1 (toUpdateSwitchInd)
01:11:43: info Gang: roomVacant
01:11:41: info smartapp_pause called by smartAppName=rooms child app, value=10, smartAppVersionId=
01:11:41: debug Gang: whichSwitchesAreOn: [Fibaro Dimmer (gang)]
01:11:41: info Gang: switches2Off
01:11:41: debug Gang: switchesOnOrOff: true | true
01:11:41: debug Gang: processRules: rules to execute: []
01:11:41: info Gang: processRules
01:11:41: info Gang: switchesOnOrOff
01:11:41: info Gang: luxEventHandler
01:11:39: error java.lang.reflect.UndeclaredThrowableException @line -1 (toUpdateSwitchInd)
01:11:39: error java.util.concurrent.TimeoutException: Execution time exceeded 20 app execution seconds: 93841854884798 @line -1 (doCall)
01:11:35: info Gang: occupiedSwitchOffEventHandler
01:11:35: info Gang: switchOffEventHandler
01:11:35: info Gang: vacantSwitchOffEventHandler
01:11:35: info Gang: processCoolHeat
01:11:35: info smartapp_pause called by smartAppName=rooms child app, value=10, smartAppVersionId=
01:11:35: debug Gang: whichSwitchesAreOn: [Fibaro Dimmer (gang)]
01:11:35: info Gang: switches2Off
01:11:35: debug Gang: Gang unschedule calling class: handle switches
01:11:35: info Gang: previousStateStack
01:11:35: info Gang: Gang room state - old: occupied new: vacant
01:11:35: info Gang: runInHandleSwitches
01:11:35: debug rooms manager: rSH initialized
01:11:33: debug Gang: switchesOnOrOff: false | true
01:11:33: info smartapp_pause called by smartAppName=rooms child app, value=10, smartAppVersionId=
01:11:33: info Gang: turnSwitchesOnAndOff
01:11:33: debug Gang: processRules: rules to execute: [1]
01:11:33: info Gang: processRules
01:11:33: info Gang: switchesOnOrOff
01:11:32: info Gang: luxEventHandler
01:11:29: debug rooms manager: rSH initialized
01:11:29: info Gang: occupiedSwitchOnEventHandler
01:11:29: info Gang: switchOnEventHandler
Not sure if it’s related though. I’m on the latest master branch btw!
Yeah, using that one! Same version. Not sure if I have it with other apps, I’ll click through some of my smart apps and things to see if it triggers anything.
another user reported that same error to me in a PM this am. thats when i started checking my own logs. found a bunch of the same errors in my other apps and pistons … thats when i made the post above.
once the errors go away from the other apps and if it still shows for rooms manager apps or devices i will be happy to dig in.
Ah okay! I can’t reproduce the error with other smartapps / things btw. The timeout exception also doesn’t seem related toggling states of rooms but seem to happen randomly.
I’ll try to remove and reinstall the Rooms Manager and see if that helps!
i checked the code on github. this method is clearly defined. its used in a runIn method and whatever the ongoing issue is its causing them to fail randomly.
so there is likely something funky going on with the platform … when those happen they dont tend to be consistent.
may be try editing each of the groovy files so isDebug returns false then publish those … which should turn off most logging. see if that helps?
Ah crap, just got another exception. Around the time the exception happens it’s also not possible to add another room (the ability restores after 30 seconds or so).
