Well the good news is my team also lost, I was rooting for Croatia too. They played with their heart on their sleeves and gave it their all, but lady luck just would not give them a look at all. Unfortunate. Whilst the French, lady luck must have been in love with them .
That’s it exactly Sunset offset 20, sunrise offset -20.
I’ve updated and shall report in a few hours.
As I mentioned before i have numerous other rules for the room all disabled but I did notice one of them show up in the screenshot, just mentioning it in case there was some connection.
Apologises, no I ment even though i have multiple disabled rules and only one live/active one, I noticed in the screen grab one of the disabled rules is also displayed.
@bangali the tv crews captured that, I thought it was brilliant showing that leaders are also human…i’m pretty sure the Croatian president is checking out his ass
Not sure if I’m in the right place for this…
From Devices, I found the Room Name and clicked into it
Under the title “In Use By” …I clicked into rooms Manager and got the below screen grab.
yeah its a really cool picture … definitely brings out the humanness
thats for rooms manager. we want the child app for the room. heres the simplest way to get to it for that room:
IDE -> my locations -> smartapps on rightmost column -> scroll down to find rooms manager and the rooms listed under it -> click on room name -> in pop up window scroll down towards bottom to find scheduled jobs for that room.
This is matching what I see in the logs in terms of the light…
At 22:04 On Command is sent to the light and light comes on
Every 5 minutes after that another log entry is made, On Command Sent
At 04:51 another On Command is Sent
At 04:56 another On Command is Sent
At 04:57 another On Command is Sent
Then no log entries until I manually turn the light off in the morning.
thanks. the 5 mins pattern is right however the on command at 4:57 am which is out of pattern is suspect.
i am wondering if this is getting impacted because of how ST handles sunrise and sunset location data and updates to those.
would you be ok changing that time to 4:58 am instead of sunrise ± x mins … in the rules and see if that works right? not a solution just need to eliminate something.
btw … what is the actual sunrise time for your location as shown in ST IDE?
so even with a fixed time to value the lights did not turn off at 4:58 am? what are the scheduled jobs for the room? please also share the view all settings one more time.
turn it on and that should fix it. to explain a bit how rooms make that decision:
when matching rules it first looks for one or more matching rules to execute various actions as configured on the rule
when no rule matches then it checks that flag to decide if every device in the room should be turned off
– if that flag is on then it finds the devices from various rules and turns them all off.
you have the option of overriding this flag by creating a rule for vacant state for sunrise - 20 and having that turn off any lights you want.
but if all you want to do is turn off all the room devices when state is vacant just set that flag to on and it does the same thing.
but if you don’t mind please do it in 2 stages:
turn it on and save the settings without changing anything else
confirm next day it worked
then change time to sunrise - 20 and save settings.
