so i set my own device health settings to check health with no announcement and only if failed display color notification and saved the settings which triggers the device health check. then tried both arrival and departure.
it sent both the device health message and the arrival and departure messages with the right command to the speaker:
8:25:01 AM: debug playTextAndResume(Long time no see Bhoot, Bhoot is rolling in., 33)
8:24:12 AM: debug playTextAndResume(Live long and prosper Bhoot, Bhoot has flaked off., 33)
8:23:15 AM: debug playTextAndResume(dW BR LI 1, dW BR LI 4, dW BR CS, dW BR LI 2, dW BR LI 3 devices have not checked in last 24 hours., 33)
My Hall Room was working fine before I had to update my account to the Samsung account. Even though I can see all of my devices and they seem to be working ok, my Hall Light does not seem to be turning on when the Lux is below 20 anymore. Not sure what the issue could be as it was working up until that time. I went into the Developer site and updated all the DTH
and Smart Apps. Any suggestions?
from the ST IDE can you please check that the location and sunset/sunrise time is showing the right values? You can find these from going to My Locations then clicking the name of the location from the list that is shown:
Well actually, I have 5 Locations setup and all of them except for my Home location are showing America/Toronto which is correct. My Home Location is showing America/Montreal. This must have happened when the update to the Samsung account happened. How do I fix this?
very likely. from the app if you go to the 3 horizontal stripes tab you should be able to click on the gear icon at the top and choose the right location.
after doing please confirm in the ST IDE that these values are set correctly:
Yes, the Hall Room does use sunrise and sunset times. The others donât. I sent ST support the log from above so they could look into this. They said they would look into it. They didnât think that the sunrise and sunset times would be different but they are actually off by a minute.
the line its erroring on is trying to calculate a new date/time based on the sunrise time. most likely the system sunrise time is not returning a valid value causing this error. i have seen this happen before when location was not set and system sunrise and sunset times were not available as a result.
" Thanks for providing those errors. That is helpful.
I took a look and was able to correct the location timezone to America/Toronto. However, I notice the error is still persisting. I am not familiar with the code, is it possible thereâs an issue with the code at line 4466?"
However, I have replied back to support that the sunrise/sunset times still do not match the other America/Toronto Locations that I have on the hub.
