Rooms Manager: Smarter Rooms: Personalized home automation with Occupancy
rooms
smartrules
microlocation
project_sensors
manager
(Tony Fleisher) #1008
I updated this weekend and found that there is a bug (from debug line) that causes night lights to not turn on with motion if nightMotionSensors is empty (“All room motion sensor(s)”).
#1009
thank you. probably best to comment that line. I will update it in the next push.
edit: also updated the line on github.
(Jane) #1010
What does the “No Auto Engaged” setting under When room is busy mean?
#1011
this will not auto set the room to engaged with traffic.
(Jane) #1012
So it will just be Occupied or Vacant? I am having trouble with a new Room that I am changing over from CoRE. It is my hall light and as of right now it turns on with motion but it doesn’t turn off at all. Here are the settings:
(Tony Fleisher) #1013
Looks like the occupancy timeout is not set (occupied settings -> timeout configuration for OCCUPIED state)
(Jane) #1014
Ah, OK I will try that. Thanks!
(Jane) #1015
Yes, that seemed to have worked. Now as for the Basement room…I have had a couple of times lately where the basement is Vacant but when I walk into it and the motion sensors detect motion it will go into an Engaged state but not turn on the lights. Any ideas?
#1016
is there a rule with engaged state to turn on the lights?
#1017
i looked at your earlier post that one does not show engaged state selected … it only has the occupied state selected for the rules.
(Jane) #1018
So I need to add the Engaged state also to the rules? There is a lot to learning everything about this app!:smirk:
#1019
if you want the lights to turn on when the room is in engaged state … yes please select engaged state in the rule which turn on the lights.
(Jane) #1020
But I thought that the lights stayed on if the room was in an Engaged state?
#1021
engaged state is meant for keeping lights/switches on. you just have to tell the app thru the rules which lights/switches to keep on which may be the same as lights/switches in the rule for occupied state or different from it.
(Jane) #1022
Something weird happening today…my power went out last night (for no apparent reason) and now my Rooms aren’t showing Occupied when motion is detected. They stay Vacant. Any ideas why this would be happening?
(Steve) #1023
Hmmm, my power did not go out but I’m experiencing the same issue this morning. Manually changing rooms taste is not invoking any WebCoRe pistons
(Jane) #1024
Wonder what is up? I thought it was because the power went out. ST probably messing with things again. Still no response from my Rooms.
#1025
Guys, just installing this app. Thanks for all the hard work!
What I’m trying to do is set the GE 26931 switch so that between 10:30pm and 5:30am motion does not turn on the light. But motion does turn on the light all other time.
Is this possible with this app? If so, how the heck do you do it?
#1026
you are welcome.
sure.
yes. when creating the rule specify 5:30am as the time from and 10:30pm as the time to and it will only execute that rule when that time condition is true and turn on any lights specified in the switches on for that rule.
see full doc here: https://github.com/adey/bangali/blob/master/README.md
(Tony Fleisher) #1027
ST was having problems getting events to smart apps off and in for most of the day. (webCoRE was having problems too.) The issues seem to be resolved for me now.
