Rooms Manager: Smarter Rooms: Personalized home automation with Occupancy
rooms
smartrules
microlocation
project_sensors
manager
#908
both of these values appear to be null for some reason … but they both have defaultvalue so should not be null … wondering if that is the issue:
are you comfortable editing the rooms manager app in the IDE directly if i give you the lines to replace?
#909
Sure, just walk me through it
#910
cool. open rooms manager app in the IDE and replace these lines:
section("Announce only between hours:")     {
    if (playerDevice)        {
        input "startHH", "number", title: "From hour?", description: "2 digit hour in 24 hour format", required: true, multiple: false, defaultValue: 7, range: "1..${(endHH ?: 23)}", submitOnChange: true
        input "endHH", "number", title: "To hour?", description: "2 digit hour in 24 hour format", required: true, multiple: false, defaultValue: 23, range: "${(startHH ?: 23)}..23", submitOnChange: true
    else        {
        paragraph "Announce from hour?\nselect either presence or time announcement to set"
        paragraph "Announce to hour?\nselect either presence or time announcement to set"
with these lines:
    if (playerDevice)        {
    else        {
save and publish the app then open the rooms manager app … lets see if the same error shows up.
#911
Error message went away
#912
awesome. put in 7 and 23 respectively and save it.
then reverse the line replacement above. then open the rooms manager app … does the error come back?
#913
7/23 entered then reversed and save it. The error did not come back
#914
enjoy! :slight_smile:
#915
Thanks a bunch. Quick question. If I want the announcements available at all times can I change the 7/23 to 7/7 or 12/12 something like that?
#916
you are welcome.
try 0 / 23 … if it does not work i am always here. :slight_smile:
#917
GOT IT! Nice work
#918
update from github before you use 0 / 23 :wink:
#919
CRAP! I changed it to 0/23 and the error came back
#920
it allowed you to save it with 0 / 23?
update from github and try it before trying the previous code replacement.
#921
Went I hit save, it I think it allowed me to save it (cant remember). But I backed out then tried to go back in and I got the error message
#922
yeah backing out isnt generally a good idea in ST :slight_smile:
#923
ok. I updated from GitHub. About to do the code replacement. Be right back
#924
wait dont do the code replacement yet.
first try with new code from github.
#925
Sorry, just did it.
#926
just update from github again and try it.
#927
Ok…updated tried again. No error message. Now I am so afraid to touch anything. Don’t wont to break it again…lol
