RGB Color based on Temp Sensor?
Does anyone know if there is automation for reading a temperature sensor and then making a RGB bulb change color based on temp? What I would like to do is install a temperature sensor above my shower. Install a RGB bulb for the shower light. When the light is switched on it will start out white while it reads temperature. From there it will turn blue as long as the temperature is below a certain set point. As the temperature increases with the heat being generated by the shower it will turn red once it see a set point temperature. And then after a set time it will set the light to white.
I have just discovered webCoRE! Looks like the possibilities are endless with it.
Indeed. Welcome to the next six months of your life
Hello Shane, you can also check this Weather Color Light SmartApp.
Have fun!
© 2019 SmartThings, Inc. All Rights Reserved. Terms of Use | Privacy Policy
SmartThings; SmartApps®; Physical Graph; Hello, Home; and Hello, Smart Home are all trademarks of the SmartThings, Inc.
