I’ve been having problems with many routines over the last 3-4 months. Lights stopped coming on at sunset. Motion senors didn’t active lights. I went back and forth with email tech support, but it seems after the first round (write above this line) I didn’t hear back from them…fail!
So…putting up Christmas lights, all on ST plugs. On at sunset, off at 11PM = not working. I tried all the solutions the emails suggested. Cycle power on hub. Deleted routines, and redo. Deleted devices and redo. Change my home to a different time zone…nothing worked.
So I CALLED. Got very knowledgeable support guy named Patrick. He looked at my ST, and saw my 40-50 devices…and saw that my “1am shutdown” worked. He suggested, not just unplugging my Hub, but removing the batteries. As far as I remember the suggestion to remove the batteries for a reset is not online?
Worked! He even stayed on the call while we waited 2 minutes for it to work!
I have a rare muscle disease and I do like ST, because it allows me to control my environment when I am partially paralyzed, or just too weak… So I have to do things in spirts …like Christmas decorations, and lights. Plus Im a gadget freak…
I’m not clear how you can power cycle a V2 hub without removing the batteries, they provide battery backup in case of power failure. I don’t have the batteries installed just so I can power cycle if I want to, and also because they’ve got a reputation for being a bit leaky.
https://support.smartthings.com/hc/en-gb/articles/207626796-How-do-I-reboot-the-SmartThings-Hub- is one place it talks about removing the batteries.
Nothing about batteries! Power and ethernet…CABLES!
" To reboot the SmartThings Hub (2018)
Follow these steps:
- Disconnect the power and ethernet cables from the Hub
- Wait 2-3 minutes
- Reconnect the power and ethernet cables
- When the Hub is back online, its LED will turn solid green"
The support site is a little confusing. There is a tab for the v3(2018) hub and v2(2015). The v2 tab lists the steps properly.
To reboot the SmartThings Hub v2 (2015)
Follow these steps:
- Remove the 4 AA batteries (if installed)
- Wait 2-3 minutes
- Reinstall the batteries (optional but recommended)
Yep, I’m all over it now, thanks. I’m wondering they never mentioned it in the email support…just unplugging. I’ve had the v2 hub so long I forgot it even had batteries. I had the “welcome code” from the box taped to the back…just in case.
