Requirement - Help needed (1 second button)
Please could someone help me.
I need to create a button that resets after 1 second to send the below put URL and the body.
http://192.168.1.125/api/BAulOeZrNx-osiFn1UudbWwA0RBP6PYXnWQcvio7/groups/0/action
{“on”:true,“bri”:200,“sat”:255,“hue”:57685}
Thanks for the help.
SmartThings won’t guarantee Execution for anything under one minute, and even then it’s not precise: it might be 55 seconds one time and 70 seconds another… So you can’t use it for super precise applications. Because it’s a cloud-based platform, just the time to get over the Internet will vary. But you can set up a rule for less than a minute using core or webcore and see if it works well enough for your needs. (you can think of Core as a scripting language for SmartThings. It will do a lot of the heavy lifting for you on complex code.)
Thank you
I have core installed and I just need to know where to put the URL and body to make it work.
Mark
In that case, post your question at the end of the following thread and someone should help you:
