Hello,
I would like to request SmartThings Edge driver support for a 2-gang Zigbee wall light switch.
□ Device information
Brand / Product: Hejhome Pica 2-gang Zigbee wall light switch
Type: 2-gang wall light switch
Wiring type: No-neutral / 2-wire
Zigbee Manufacturer:
_TZE284_anz2gdlj -
Zigbee Model:
TS0601 -
SmartThings pairing result: Pairs successfully, but only as
Zigbee Thing -
Current issue: The device pairs with SmartThings Hub, but no usable switch controls are shown.
□ Environment
Hub: SmartThings Smart Home Hub v4
Connection method: Direct Zigbee pairing to SmartThings Hub
I do not want to use the Hejhome hub.
□ Drivers already tested
Personal Tuya Devices / Generic EF00 Device- Result: The device was detected, but the switch controls did not work properly.
Tuya MCU Switch Driver- Result: Not working / not matched properly.
□ Request
Could you please check whether this fingerprint can be added to a SmartThings Edge driver?
manufacturer: _TZE284_anz2gdlj
model: TS0601
Since this is a Tuya TS0601 device, I assume it may require Tuya MCU / EF00 DP mapping. If needed, I can provide additional screenshots from SmartThings Advanced Web App, such as endpoint, clusters, profile ID, device type, or logs.
I would appreciate any help adding support for this device.
Thank you.
