Maybe I’m just expecting too much. Things seem to be inconsistent. I have 4 recessed door sensors. Each sensor is within 2’ of its respective light switch. A piston is set up to turn on the light when the door is open and off when the door is closed.
If I open and close the door 10 times, it works maybe 7 times. Of those 7 times, maybe 5 are instant and the other 2 take between 3 - 5 seconds.
Now that I’ve re-paired the locks, they work about the same as the other stuff, which is 70% of the time.
Am I expecting too much from this system?
As for my system, I’ve tired everything I’ve read and nothing seems to change. I’ve read about rogue devices, but no clue how you go about finding one.
My system (hub is in the center of the basement):
Basement:
4 x Linear / GoControl WD500Z-1 Switches
7 x Zooz Zen25 Double Plugs
9 x GE 14294 Dimmers
2 x Monoprice Recessed Door Sensors
1st Floor:
Master Bedroom / Bathroom
1 x GE 12722
2 x Linear / GoControl Dimmers
1 x Monoprice Recessed Door Sensor
Family Room:
Aeotec SmartSwtich 6ZW096
Kitchen
2 x Zooz Zen27 Dimmer
Living Room
1 x Aeotec ZW096
1 x Zooz Zen27 Dimmer
1 x Kwikset 910
Garage:
1 x Zen27 Dimmer
2 x GoControl / Linear GD00Z
1 x Kwikset 912
I have a ton of devices spread all over the house in both the basement and 1st floor. There isn’t currently anything on the 2nd floor, but we honestly don’t really use that floor of the house.
Almost everything I have is wired and listed as supporting beaming. But I’m constantly running into either delays, or devices that work intermittently. I’ve done repairs, reboots, removal and re-additions.
I’m just hoping if someone can tell me if I’m expecting too much?
