I’ve just added a Nest Protect to my home, and and having some problems getting the full Nest Manager dashboard to appear for the Nest Protect.
When I tap on the Nest Protect in my “Things” list, the green “Clear” status w/battery info in the top half of the screen appears, but the detailed information below doesn’t - the progress spinner spins endlessly and the info doesn’t appear.
I have gotten it to fully show up I think twice out of numerous attempts to view the dashboard.
I can connect normally to the Protect from the Nest app, run tests, etc., and the Nest Manager sees and records those events in “Recently.”
Our apologies as this seems to have been a weird week of issues with Nest Manager
I know I’ve been MIA the last 6 days because I was out of the country but I want to give a big thanks to @E_Sch for holding down the fort and patching these bugs we have been seeing.
He has made a lot of progress toward smoothing out the rough edges Nest has caused with the ECO update.
#[UPDATE] Nest Manager 4.3.0
Added: You can now set the Nest Mode Automation to activate Eco mode when the location goes to Away and will resume previous mode when returning to Home. This needs to be enabled manually (It’s not on by default)
(It is highly recommended to disable the Nest Home/Away Assist from your nest device if you use the Nest Manager Automations.)
Updated: Lot’s of little bugs have been fixed.
Fixed: The Protect Low Battery simulation test has been fixed and works correctly now.
##Please Make sure to update all device handler code as well
Not sure if this is a known issue, but here is the problem I am experiencing:
When it gets to a certain temperature outside, I turn off my heating thermostats via a CoRE piston. I then get constant push notifications from Nest Manager when they are in Away mode b/c Eco is not enabled. I have notifications disabled as well. Shouldn’t Nest Manager see the thermostats are off and not bother trying to put it/report on it being in ECO mode?
Having some issues with Nest Manager. I did a factory reset with my phone last week and the thermostats hadn’t updates since that day, so I went in removed the application and tried to reinstall everything. I go through the process, however after I finish when I select either of my thermostats I get the following. I want to note that both of my thermostats are on.
I get this from the IDE logs:
49ba4084-9710-4514-aa64-ab0c9035d6e9 12:08:32 PM: error groovy.lang.MissingMethodException: No signature of method: physicalgraph.device.DeviceTypeExecutorBase$_closure5.doCall() is applicable for argument types: (java.lang.String, java.lang.NullPointerException) values: [graphHTML Exception:, java.lang.NullPointerException: Cannot get property ‘stringValue’ on null object]
Possible solutions: doCall(), doCall(java.lang.Object), call(), call([Ljava.lang.Object;), call(java.lang.Object), findAll() @ line 2984
49ba4084-9710-4514-aa64-ab0c9035d6e9 12:08:32 PM: error groovy.lang.MissingMethodException: No signature of method: physicalgraph.device.DeviceTypeExecutorBase$_closure5.doCall() is applicable for argument types: (java.lang.String, java.lang.NullPointerException) values: [graphHTML Exception:, java.lang.NullPointerException: Cannot get property ‘stringValue’ on null object].
I’m also getting this:
b9931912-472b-451b-9d0b-c5b734970439 12:12:31 PM: error |Nest Manager | NEED SOFTWARE UPDATE: Presence NestPres | 6RJEXYjfJ7cotXCWnd9jqsoZKcQwt-F-0DfbwInXTrrATSGp1Sucjw (v4.2.0) REQUIRED: (v4.3.0) Update the Device to latest
b9931912-472b-451b-9d0b-c5b734970439 12:12:29 PM: error |Nest Manager | NEED SOFTWARE UPDATE: Thermostat 4pba68Pk3xsSVxfgT7k7lsn7UfMulpEX (v4.2.0) REQUIRED: (v4.3.0) Update the Device to latest
b9931912-472b-451b-9d0b-c5b734970439 12:12:29 PM: error |Nest Manager | NEED SOFTWARE UPDATE: Thermostat 4pba68Pk3xv1xAdpMLLF8Mn7UfMulpEX (v4.2.0) REQUIRED: (v4.3.0) Update the Device to latest
But I am running v4.3.1. Any ideas what I have done wrong? I’m about ready to just delete everything from the IDE and do a fresh install to see if that help. Thanks
I am unable to open the Nest Manager from the Android app.
When opening the app I get the following error message in the IDE Live Logging: error groovy.lang.MissingMethodException: No signature of method: script1482858075822296692587.getIsAutomationDisabled() is applicable for argument types: () values: [] @ line 1760
On the Android App I get the error: “You are not authorized to perform the request operation” with a back button and a big “Remove” button at the top of the window.
However, I was able to get the app to open if I commented out line 1760 from the code, but then the Automation section of the nest manager would not load and gave me the same Android UI screen as explained above.While I was in here I did enable verbose logging and sending the logs to the developer so you should have something
Let me know if you need me do anything or test anything.
