Could you elaborate on this feature please. How does one capture this event
It also emits an event to inform clients that a new image is available.
There arenāt any examples I can find where this is happening, but you should be able to bind to the emitted events like this:
subscribe(<cameraDevice>, 'image', <imageEventHandler>)
Follow up question. How does one delete pictures from the cloud or set an expiration date ? If not possible whatās the timeout for the same?
Mature companies can give you one without the other.
āIāll take a week of inconvenience in the name of security any dayā¦ā
Especially the week of inconvenienceā¦
Hang on just noticed something vis-a-vis your original post. Couple of questions:
storeImage
still works - will this continue to work? (I hope so because itās being used for cameras with non local images being returned through httpGet)getTemporaryImage(String key)
but that doesnāt seem to work, it throws an errorError: groovy.lang.MissingMethodException: No signature of method: script14855936530701998199908.getTemporaryImage() is applicable for argument types: (java.lang.String)
So how does one access that image? I need to process the image before uploading it via storeImage. I was doing it earlier through the old method but how do I do that now?
Thanks! Its working very well.
Thank you for getting an alternative pushed out so quickly.
Sorry I have limited access to Internet this week, Iām out of country.
I ended up removing the getTemporaryImage method based on the reasoning that you can access and modify images once it is in the collection stored by the device (i.e. getImage
and storeImage
Do you need to modify the image before it is emitted to ST clients?
No but I need access to the raw byte data for analysis. Didnāt know about getImage. Do you have the API template for it?
I have tried to update a device handler but I am getting the following error when calling the storeTemporaryImage method
āThe specified key does not existā
The error seems to imply the key returned by the event isnāt correct
Does anyone have any ideas?
Which handler have you been using? Posting your code would probably help.
I am using a slightly modified version of the Foscam handler posted by ST earlier in the thread.
What shows in your simulator log when testing? The parse method logs the value received from the device response, mine looks something like
418f5d1a-df5f-49a7-ad3d-e9243945bd4f ā12ā:ā13ā:ā06ā āPM: debug Parsing 'index:17, mac:0080F0B6BA9C, ip:C0A801FB, port:0050, requestId:6e23ed4c-d143-4dd2-93c1-e36947846f5c, bucket:smartthings-device-conn-temp, key:534aadcb-ec08-4931-945c-d7b3b24c8612'
But the code I stole parses that string using a custom function, not the stringToMap function. I think stringToMap might expect JSON?
This is what I am getting back, its successfully parsed into an array and everything seems complete.
'index:17, mac:E8ABFA6BBD78, ip:C0A80203, port:0058, requestId:d3b63da0-effe-4614-968e-76f14add0a40, bucket:smartthings-device-conn-temp, key:546a7c13-3de4-40d2-b4ab-057a46c7d9bc'
Is mapped into this
[index:17, mac:E8ABFA6BBD78, ip:C0A80203, port:0058, requestId:d3b63da0-effe-4614-968e-76f14add0a40, bucket:smartthings-device-conn-temp, key:546a7c13-3de4-40d2-b4ab-057a46c7d9bc]
Same error with getImage() also, somethingās mixed up with the bucket/key mapping those APIās @gausnes
error com.amazonaws.services.s3.model.AmazonS3Exception: The specified key does not exist. (Service: Amazon S3; Status Code: 404; Error Code: NoSuchKey; Request ID: F47DFCB9AE713EE6), S3 Extended Request ID: UBu+wgIP26NOVTb153pCl0CQ0bW/xEhgeH3wKhn7RdB2FZ/BVTukX5mZVH/xLQl7GZ1jAzWgeO0=
Weird, mineās still fine. That error text definitely appears to be from S3. I wonder if the firmware update scheduled for today is the difference. Iām still on 000.016.00011.
storeTemporaryImage() is working, getImage() isnāt
I am on firmware version 000.016.00013
if that helps anyone
Thatās not the problem, Iām on v 16.13 now and cameras are still working.
