Hi
I wonder if somebody can help I am trying to wire a remote light switch, two live coming in and one wire to the bulb and I have two places to put wire but what ever I try the bulb will not go out.
Help
Your description of your wiring does not exactly make sense. If you have two live wires that means you are 220vac? But then you said you have one wire going to the bulb. That tell me that it’s a 120vac circuit and that your two wires one should be your line and the other should be your neutral. And your bulb must have 2 wires it can’t just have one unless you have a short to ground somewhere. Take some pictures.
