[OBSOLETE] Fibaro Motion Sensor v3.2
I mean it will continue stay at pending even after the sync, but it’s actually synced.
Hello all,
Is anyone noticing a delay in triggering an action, I got a delay of 2 seconds before it triggers a light on via smart lighting.
Also the devices do freeze from time to time and a battery reset is needed :frowning:
You need to make sure your motion sensors are processing these requests locally, or they will be subject to a cloud lag.
Also, I can’t remember ever having to do a hard reset on my Fibaro motion sensors as you describe. The ST Zigbee one on the other hand needs doing frequently. Perhaps they might be on the edge of the z-wave mesh and struggling with signal?
The Fibaro Motion Sensors do not run locally.
Thanks John,
How do you make them run locally? I also got the Fibaro dimmer 2 which I hope it extends the zwave mesh
Using the Samsung motion control on the same position is instant however the fibaro motion sensor is a bit slow. no matter which setting do I change. I got 5 of these and they are all the same so i don’t think they are all faulty
There are only a few ST devices that run locally. Also there are only a couple of apps that run locally.
So you need an ST device with Smart Lighting and that’s about it.
Nothing else will.
Admittedly I’ve not looked into it, and live with the short delay (which doesn’t bother me too much).
@Bobbles comment above means that only the ST motion sensor can run locally. I’m certainly not going to fill my house with those!
Looks like I’m wrong.
Have a look at this.
Were you able to fix this? I’m having the same issue
Unfortunately my changes didn’t work. The Device stayed good for about 4 weeks then got stuck on motion.
Its a pain in the back side as its over the stair gap :frowning: lol
@JBR have you had any issues since you went back to the stock DH?
Do you hv the same issue when using ST stock DH?
@CSC I’ll let you know. I’ve switched one of them back to Stock to test that scenario.
Yes, the Fibaro shows C on your DTH and the stock DTH. My hub is set for F
Hey, did you get it working with v3.02?
Finally got ''this working thanks to this device handler. I also use F instead of C to report temp. It does report close to the correct temp but I noticed the recently activity still shows the temp in C. Can this also be corrected.
So it’s something broken at the server, even when using stock DTH, same issue also happen
I will check on the recent activity info, I think that can be fix
I don’t seem to be getting Lux updates… I’m running the _F version, but it’s stuck at 4 lux.
Try to re-pair the sensor may help
Is there a way of adding the GitHub code from this device to the ST IDE so that when the code is updated the IDE changes colour? Saves having to check back for when there is an update that way.
Thanks in advance
