Ok, so I just added this device and am using this DTH. Seems to have gone without a hitch, including commenting out the off routine (thanks for the suggestion).
Now onto the real question. I bought this to monitor my outside refrigerator that has been left ajar more than once. I was planning on using the energy usage % change, but I misread that, there’s only power % change and with refrigerators, they cycle on off with large power fluctuations. Anyone have a suggestion on how to get an alert when the fridge uses more than 10% of its typical hourly usage? I’m out of my depth!
Need 2 sensors for fridge, and freezer. Contact switches don’t reliably sense a door that is ever so slightly ajar yet not sealed. The freezer can be within 0.05" of closed and yet not be. My experience shows when it’s left open, it looks closed, but upon further inspection it is ever so slightly ajar
Ah - ok - I’m using a Quirky Tripper on my freezer and it’s worked flawlessly to identify that it’s ajar – it did take a while to adjust - but I’m betting freezer mechanisms, closing, etc. might be different. (My freezer has to be fairly open to stay open and not get shut by the magnets in the door.)
Good luck with your solution! Wondering if some kind of a temperature sensor around the door might be an additional option… (sensing colder air for too long - not sure you could have one inside).
Hi All, i will be using the zen15 to known if sump pump have run i known the DTH shows active and in inactive
how can I get a date/ time of when it is active and have it so i can track it ?
thanks for any help beau
I Known if i uses ts it shows power i like to change it to display the last date power was above 100
standardTile(“power2”, “device.power”, width: 3, height: 1, decoration: “flat”) {
state “power”, icon: “st.secondary.activity”, label:’${currentValue} W’
main “power2”
hi all
I known on the zooz zen15 you can use the button to check z-wave signal the problem is I cam not get to it to test is there any thing i can do or look at in smart thing yo see how it working ?
is there a was to see if protection kicked in
Hi Beau, to enable the Z-Wave range test toll you need to first make sure the ZEN15 is included to your hub. Then if you press and HOLD the Z-Wave button for 6-9 seconds, it will start flashing green and then either stay solid green (good connection), flash orange (connection issue diagnosis in progress), stay solid orange (fair connection), or stay solid red (failed connection) until you click the Z-Wave button again.
If by “protection” you mean overload protection, then you’ll be able to see if it the switch turned off by itself without any automations or commands, this is usually a sign of overload protection following a current draw over 16.5 Amps.
