SmartThings Community
[RELEASE] Zooz Motion Sensor ZSE18
(Jim Gaudette) #62
Well it’s Monday morning and I see nothing. Still chasing those aliens?
#63
Someone must have cursed the delivery (not pointing any finger here :smiley: ), there’s a customs-related delay but we hope tomorrow or Wednesday we’ll finally receive them. We’ll keep you guys posted!
(Jim Gaudette) #64
Not pointing any FINGER (not fingers)?
We know you are blaming E.T.
Looks like they’re moving, we should start shipping out today and for the time being, you get a nice promo price of $19.95 through 5/14:
(Jim Gaudette) #66
Well that price made the 3 month wait almost worth it. :slight_smile:
(Jim Gaudette) #67
Just to be safe is the USB micro b or c?
#68
It’s micro B, we sell 2 types of cables and adapters here:
(Jim Gaudette) #69
Is there any reason to pull the battery and pull tap if running on usb?
#70
Not really, you can leave it as is if the battery is not activated.
(Kevin) #71
It depends…
If it’s included using the normal procedure described in the manual then it can be powered by USB or battery. Leaving the batteries in so it continues working during a power failure can be useful, but only if your internet is on a battery backup.
If the device is included as a repeater it can still run on batteries, but it will most likely burn through them in a matter of hours so I wouldn’t bother keeping them in the device.
(Jim Gaudette) #72
Have zooz 4 in 1 and the new 18’s. Under sensitivity one has 1 as least and the other has 1 as most. Guess it could be true but suspect not. Is 4 in 1 wrong or are they really opposite each other?
(Kevin) #73
They’re completely different devices… The handlers match the manuals and I doubt the manuals are wrong.
#74
ZSE40 and ZSE18 have different settings and the sensitivity values are reversed. They also have separate handlers to match the settings.
(Jim Gaudette) #75
So after zse18 params are set up what’s the best dth to run local?
(Kevin) #76
If you’re not using it for vibration then use the Z-Wave Motion Sensor handler. I just checked its code and it has the ZSE18 fingerprint in it so the battery reporting and motion detection must work.
(Jim Gaudette) #77
Thank you for your help with all this Kevin…
