The child switches are working in the new app now
The outlets for the Power Strip are now working with the new mobile app tooβ¦
Kevin,
Could the βauto turn onβ after xx time period feature of your dth be used to power cycle a modem or router? Or does the plug need to be connected to the cloud to auto turn on?
Thanks in advance, and thanks for all your great contributions.
That functionality is handled by the deviceβs firmware so it should still perform the action without an internet connection and/or the hub.
Kevin,
Thanks a ton for the reply!
I need a method to reboot my βWISPβ (Wireless Internet Service Provider) antennae and a router at a vacation home when I am not present.
When I was configuring ZEN25 plug (with your dth- thanks) that I am using on my water softener and UV system, I noticed the βauto turn on afterβ and was hoping that I could then use that feature to be able to power cycle a router and βWISPβ antennae from a remote location.
Thanks again !
Hi Kevin β Today, my Zooz Double Plugs started showing up as βTile Missingβ in Classic. This happened after attempting to rename them. I was able to access and rename them in the Connect app. How can I resolve?
Iβve only seen that happen when someone tried to change the name of a device handler that was already assigned to a device or messed something up in the device handler.
Try opening the device in the IDE and make sure itβs still set to the correct type.
If itβs one of the outlet devices then try opening the device with the issue and save the settings. If you canβt do it from the classic mobile app then try it from the IDE.
Hi Kevin, Iβm attempting to use the double plug for a echo dot ver 1 and a stereo receiver. Is there a minimim wattage that is picked up, as it pops up with a wattage on startup but then goes to zero and stays there. I have it set to 1 watt threshold but no luck getting it to showup. My understanding is it should be in the 2-3 watt category. Looking to use that to turnoff my receiver if its left on when no music is playing.
Suggestion for research, some classes of amplifiers use minute current when idle (??? Class D amps ???). Is it possible that your receiver goes to a sleep mode by design?
The stereo receiver is 20+ years old and the double plug is picking up the wattage just fine. The echo dot is my problem. Seems that wattage under 3 watts is reflecting as 0 on the double plug. Just tried using the zooz zen15 on the echo and it is picking up the wattage just fine being 2.xx watts. Maybe a minimim wattage setting that is different between the two handlers? Slightly above 3 seems to work fine.
If you perform the steps below I should be able to determine whether the issue is the handler, the settings youβre using, or if the double plug isnβt sensitive enough to detect whether or not the echo is playing music.
You should probably change the power settings to 10% and 5 minutes while testing to avoid those reports from interfering with the testβ¦
- remove β//β from the logTrace line at the very bottom of the code
- save and publish the code
- open live logging
- open the child device that the echo is plugged into using the classic mobile app
- tap the refresh tile while the echo isnβt doing anything
- wait at least 30 seconds
- make the echo play music
- make it stop playing music
- wait about 10 seconds
- filter live logging by that outlet
- post the live logging results
Hi Kevin, so for zooz double plug zen25 its not picking up any wattage for the echo dot at all when its under 3 watts. On startup of music it goes above but shortly after it goes back to reflecting 0 watts. Using the zen15 it reflects wattage of 2xx something. So was hoping to first solve why the zen25 handler is showing 0 watts.
The question is, is the device not measuring anything or is it just not automatically reporting it and the logs I requested might answer that.
Hi Kevin,
See the details. Seems like if I refresh quickly I see the wattage upon an action, then a couple seconds later itβs dropping back to 0W looking at the logs.
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β17β:β21β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β17β:β21β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β17β:β18β βAM: debug Zooz Double Plug-LEFT - voltage is 121.7 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β17β:β18β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β17β:β16β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β17β:β16β βAM: debug Zooz Double Plug-LEFT - voltage is 121.6 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β17β:β12β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β17β:β12β βAM: debug Zooz Double Plug-LEFT - voltage is 122.1 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β17β:β09β βAM: debug Zooz Double Plug-LEFT - voltage is 122.1 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β17β:β09β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β17β:β08β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β17β:β08β βAM: debug Zooz Double Plug-LEFT - voltage is 122.1 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β17β:β07β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β17β:β04β βAM: debug Zooz Double Plug-LEFT - voltage is 122.1 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β58β βAM: debug Zooz Double Plug-LEFT - voltage is 123.1 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β57β βAM: debug Zooz Double Plug-LEFT - voltage is 122.2 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β55β βAM: debug Zooz Double Plug-LEFT - voltage is 122.2 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β54β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β51β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β51β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β48β βAM: debug Zooz Double Plug-LEFT - voltage is 123.3 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β46β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β46β βAM: debug Zooz Double Plug-LEFT - voltage is 122.1 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β42β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β42β βAM: debug Zooz Double Plug-LEFT - voltage is 123 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β39β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β39β βAM: debug Zooz Double Plug-LEFT - voltage is 122.8 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β36β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β36β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β33β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β33β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β33β βAM: debug Zooz Double Plug-LEFT - voltage is 122.1 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β30β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β30β βAM: debug Zooz Double Plug-LEFT - voltage is 122.1 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β28β βAM: debug Zooz Double Plug-LEFT - voltage is 120.8 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β24β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β22β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β21β βAM: debug Zooz Double Plug-LEFT - voltage is 121.1 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β18β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β18β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β18β βAM: debug Zooz Double Plug-LEFT - voltage is 121.6 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β15β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β15β βAM: debug Zooz Double Plug-LEFT - voltage is 122.1 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β12β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β12β βAM: debug Zooz Double Plug-LEFT - voltage is 122.1 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β09β βAM: debug Zooz Double Plug-LEFT - voltage is 123.4 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β09β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β06β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β06β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β04β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β03β βAM: debug Zooz Double Plug-LEFT - voltage is 122.2 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β00β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β16β:β00β βAM: debug Zooz Double Plug-LEFT - voltage is 123.4 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β58β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β58β βAM: debug Zooz Double Plug-LEFT - voltage is 122.7 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β54β βAM: debug Zooz Double Plug-LEFT - voltage is 121.9 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β54β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β52β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β51β βAM: debug Zooz Double Plug-LEFT - voltage is 122 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β48β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β48β βAM: debug Zooz Double Plug-LEFT - voltage is 122.3 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β45β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β45β βAM: debug Zooz Double Plug-LEFT - voltage is 120.9 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β42β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β42β βAM: debug Zooz Double Plug-LEFT - voltage is 122.2 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β39β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β37β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β36β βAM: debug Zooz Double Plug-LEFT - voltage is 121.9 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β34β βAM: debug Zooz Double Plug-LEFT - voltage is 122.5 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β33β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β30β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β30β βAM: debug Zooz Double Plug-LEFT - voltage is 122.3 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β27β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β27β βAM: debug Zooz Double Plug-LEFT - voltage is 122.8 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β24β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β24β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β21β βAM: debug Zooz Double Plug-LEFT - voltage is 122.1 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β21β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β20β βAM: debug Zooz Double Plug-LEFT - voltage is 122.1 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β12β βAM: debug Zooz Double Plug-LEFT - voltage is 122.2 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β09β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β09β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β06β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β06β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β06β βAM: debug Zooz Double Plug-LEFT - voltage is 123.4 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β04β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β04β βAM: debug Zooz Double Plug-LEFT - voltage is 123.4 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β03β βAM: debug Zooz Double Plug-LEFT - voltage is 122.7 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β03β βAM: debug Zooz Double Plug-LEFT - power is 6.1 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β03β βAM: debug Zooz Double Plug-LEFT - energyDuration is 5.26 Days
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β03β βAM: debug Zooz Double Plug-LEFT - energy is 0.04 kWh
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β00β βAM: debug Zooz Double Plug-LEFT - switch is on
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β15β:β00β βAM: debug childRefresh(22-LEFT)β¦
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β58β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β57β βAM: debug Zooz Double Plug-LEFT - voltage is 122.3 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β54β βAM: debug Zooz Double Plug-LEFT - voltage is 122.1 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β51β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β51β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β51β βAM: debug Zooz Double Plug-LEFT - voltage is 121.8 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β48β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β48β βAM: debug Zooz Double Plug-LEFT - voltage is 122.5 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β45β βAM: debug Zooz Double Plug-LEFT - voltage is 121.7 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β44β βAM: debug Zooz Double Plug-LEFT - voltage is 114.8 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β42β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β39β βAM: debug Zooz Double Plug-LEFT - voltage is 122.4 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β39β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β36β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β36β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β36β βAM: debug Zooz Double Plug-LEFT - voltage is 121.7 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β33β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β31β βAM: debug Zooz Double Plug-LEFT - power is 2.7 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β30β βAM: debug Zooz Double Plug-LEFT - energyDuration is 5.26 Days
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β30β βAM: debug Zooz Double Plug-LEFT - energy is 0.04 kWh
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β30β βAM: debug Zooz Double Plug-LEFT - switch is on
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β29β βAM: debug childRefresh(22-LEFT)β¦
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β27β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β27β βAM: debug Zooz Double Plug-LEFT - voltage is 122.3 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β24β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β24β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β21β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β21β βAM: debug Zooz Double Plug-LEFT - voltage is 121.5 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β18β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β18β βAM: debug Zooz Double Plug-LEFT - voltage is 121.9 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β15β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β15β βAM: debug Zooz Double Plug-LEFT - voltage is 122 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β12β βAM: debug Zooz Double Plug-LEFT - voltage is 121.9 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β09β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β07β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β07β βAM: debug Zooz Double Plug-LEFT - voltage is 122.3 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β04β βAM: debug Zooz Double Plug-LEFT - voltage is 122.2 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β00β βAM: debug Zooz Double Plug-LEFT - voltage is 122.3 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β14β:β00β βAM: debug Zooz Double Plug-LEFT - power is 9.2 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β59β βAM: debug childRefresh(22-LEFT)β¦
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β57β βAM: debug Zooz Double Plug-LEFT - voltage is 122.3 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β57β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β54β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β54β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β51β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β51β βAM: debug Zooz Double Plug-LEFT - voltage is 122.2 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β48β βAM: debug Zooz Double Plug-LEFT - voltage is 122.3 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β46β βAM: debug Zooz Double Plug-LEFT - voltage is 121.8 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β45β βAM: debug Zooz Double Plug-LEFT - power is 0 W
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β42β βAM: debug Zooz Double Plug-LEFT - voltage is 122.2 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β39β βAM: debug Zooz Double Plug-LEFT - voltage is 121.8 V
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β39β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β36β βAM: debug Zooz Double Plug-LEFT - current is 0 A
adaa3db8-55ac-4c59-8787-089ec3923c67 β12β:β13β:β36β βAM: debug Zooz Double Plug-LEFT - voltage is 121 V
Ryan
I canβt tell for sure because you didnβt follow my instructions for testing, but it appears that the device isnβt capable of measuring values that low.
Contact Zoozβ¦
When we are forced to switch to the new App - what is the stock Device Type name in the IDE drop down box? Thanks
ST will post the documentation ahead of time and once they do that Iβll be able to make the handler work as expected in the new mobile appβ¦
Thanks Kevin.
I havenβt received the βinvitationβ to migrate to the new app but was curious what may occur and be prepared. My router is powered via a zen25 in a home 2000 miles away, so I am a bit concerned about the zen25 and entire network during the potential migration to the new app while I am not present in the home.
Iβm not sure what the account migration does, but I was under the impression that both mobile apps would still work after migration because they both work before you migrate.
At some point theyβll retire the old mobile app, but that shouldnβt break the handler because it already works in the new mobile app.
The only issue is that the UI doesnβt display everything because the custom capability documentation hasnβt been released yet, but that doesnβt affect on/off control of the outlets.
Thanks Kevin - I just am just beginning to use new app and can confirm that the on/off controls work -
interesting is that in the new app it displays both of my βplugsβ as βoffβ and βofflineβ - and each of the two outlets on each plug as connected and βonβ. In the classic app the βplugsβ are display as βonβ and each of the two outlets on each plug as βonβ.
Not concerned, but just reporting my experience.
