A simple handler that communicates with a YouLess meter. IP address can be set in preferences. The LS110 version displays P1 value and total kWh. The LS120 version displays P1, S0 and total kWh. LS120 is mostly used to measure both smart meter and solar panels.
Oh **** you make me happy, i was looking for a way too integrate my power and gas into smartthings.
Ive yet not have this product but its relative cheap and works in (dutch power/gas meters) so im definitly gonna buy it sometime.
What does it read, power? gas? does it need to be polled?
It’s a pulse counter. I’ve only built watt/kwh measurement but let me know if you need anything more. It’s a network device so it doesn’t need to be polled, the DTH accesses the Youless built in api every 60 seconds. I have a very old Youless device, the newer ones have some extra options.
That is the correct api output. This is probably the famous hubcommand issue where no response is received back to the hub… Can you check if there’s any “received values” mentions in the log?
How do I setup the password? If I go to “http://youryoulessip/a?f=j” in my browser I get a prompt for my password. If I put in my password it gives me the following result: {“cnt”:" 19339,908",“pwr”:395,“lvl”:28,“dev”:"(±3%)",“det”:"",“con”:"",“sts”:"",“ps0”:0,“raw”:269}
But I’m not sure where to setup the password for this device handler.
I recently installed the Youless LS120 and I wonder how I get the readings visible in my SmartThings app.
I’m not a coder, so bear with me I installed the device handler for LS120 but seems I’m missing the part how to get this device handler activated with proper IP and then how to add it to my things?
Can somebody help me with the connection between youless ls 120 and smartthings.
I have the handler and I created a new device.
Is the IP adress in preferences the same as the device network id?
The local lan ip adress is set in preferences and in the device network but in the simulator i get always the same problem:
IP adress is missing. Also in the app: no connection with cloud.
