Yes, I can lower volume and Power On/Off, its just that i cannot manage to change from my HDMI inputs. What do you mean with configuring the input sources? Should I just enter HDMI1, 2, 3, etc. and that’s it?
Yup… open the device thing in the ST app → click on the gear to open the device settings → type in HDMI1, etc for Source1, Source2, etc. BUT… the values you enter are limited to the following: AUDIO1, AUDIO2, AV1, AV2, AV3, AV4, AV5, AV6, Bluetooth, DOCK, HDMI1, HDMI2, HDMI3, HDMI4, HDMI5, iPod, MULTI CH, SIRIUS, TUNER, UAW, V-AUX, NET
Thanks for this handler. I have a R-N602. I managed to edit some sources (like “tuner” or “optical1”), but I’m unable to define/switch to the Net Radio. I tried “net” and “net radio”, but it’s not recognized. Any ideas?
(By the way: why don’t you replace the AV1/AV2/etc. labels with the - more intuitive - name of the sources? Or at least allow to edit those from the app itself?)
Just got this working for me, I am able to see what source is selected and control the volume in smarthings. Is there any way the the volume control section could be integrated into actiontiles and shown as a tile?
The volume control section does show up in AT for me… The source selection section on the other hand would be super useful and I havent worked out a nice way of doing it yet (other than having 5 or 6 separate buttons which will change the source to a single thing each), especially as I would then need to have something for controlling each source (e.g. radio channel selection)
I have a Yamaha RX-V679BL and I cannot get the device to appear in ST.
I installed created the app and DTH in the IDE.
When trying to install the App, I named the device, set the hub, a zone and entered the IP address of the receiver. I then received a message saying your app is installed but then received a message saying “an unexpected error has occurred” which causes the device not to be added.
This is provided by the log:
8:52:21 AM: error physicalgraph.app.exception.UnknownDeviceTypeException: Device type 'MusicCast Zone' in namespace 'redloro-smartthings' not found.
That’s weird… I’ve got both working with my receivers. For power on, make sure that the receiver setting to enable network power on when off is set… otherwise that won’t work. Also recommended to assign a static IP to the receiver so that the IP address doesn’t change and screw up the SmartApp.
@redloro What do you use to do your automatic polling? (poll or refresh s never called automatically)
This is still working great for me and I love it, but I do struggle with getting it to update in the background and hence the status is set to whatever it was last used as through ST rather than by remote/Yamaha App. I could add a schedule/runin to the refresh command to automate, but thought I would ask here first.
Cool ok, thanks @redloro and @barrios35 . I wasnt sure if something wasnt working or if it wasnt automatic to reduce load on the ST servers (or one of a million other reasons).
For anybody else interested, I added: runEvery30Minutes(refresh)
to the refresh function (just after the last line in refresh() (EDIT - see here))
