Hi all.
I’ve been using the original motion and contact sensors for months with no issues. Very happy with them.
I now want to get a couple of temp sensors but from reading through this thread I might be limited to a temperature update every hour. This really won’t cut it for my use case.
Can anyone confirm that they have these temp sensors Using a more frequent update poll?. Has any successfully used pollster or core to get an update every 10 minuets for example?
Any info would be greatly appreciated. I’m just about to press “buy” on 8 if these but need to be sure first!
It’s far more frequent than every hour. This should give you an idea…
Date Source Type Name Value User Displayed Text Changed
2017-10-22 2:06:56.955 PM BST
8 minutes ago DEVICE activity online Your SmartThings device Temp Living Room is now online true
2017-10-22 2:04:36.718 PM BST
10 minutes ago DEVICE activity offline Your SmartThings device Temp Living Room is now offline true
2017-10-22 1:48:38.575 PM BST
26 minutes ago DEVICE lastCheckin 2017 Oct 22 Sun 1:48:38 PM Temp Living Room last checkin is 2017 Oct 22 Sun 1:48:38 PM true
2017-10-22 1:18:12.749 PM BST
57 minutes ago DEVICE pressure 101.02 Temp Living Room pressure is 101.02 kpa true
2017-10-22 1:18:12.726 PM BST
57 minutes ago DEVICE humidity 60 Temp Living Room humidity is 60% true
2017-10-22 1:18:12.717 PM BST
57 minutes ago DEVICE lastCheckin 2017 Oct 22 Sun 1:18:12 PM Temp Living Room last checkin is 2017 Oct 22 Sun 1:18:12 PM true
2017-10-22 12:55:08.184 PM BST
1 hour ago DEVICE pressure 101.0 Temp Living Room pressure is 101.0 kpa true
2017-10-22 12:55:08.163 PM BST
1 hour ago DEVICE humidity 59 Temp Living Room humidity is 59% true
2017-10-22 12:55:08.143 PM BST
1 hour ago DEVICE temperature 20.7 Temp Living Room temperature is 20.7°C true
1 hour ago DEVICE lastCheckin 2017 Oct 22 Sun 12:55:08 PM Temp Living Room last checkin is 2017 Oct 22 Sun 12:55:08 PM true
2017-10-22 12:54:07.334 PM BST
1 hour ago DEVICE lastCheckin 2017 Oct 22 Sun 12:54:07 PM Temp Living Room last checkin is 2017 Oct 22 Sun 12:54:07 PM true
2017-10-22 12:32:43.187 PM BST
2 hours ago DEVICE pressure 100.97 Temp Living Room pressure is 100.97 kpa true
2017-10-22 12:32:43.165 PM BST
2 hours ago DEVICE humidity 60 Temp Living Room humidity is 60% true
2017-10-22 12:32:43.166 PM BST
2 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 12:32:43 PM Temp Living Room last checkin is 2017 Oct 22 Sun 12:32:43 PM true
2017-10-22 12:27:52.082 PM BST
2 hours ago DEVICE pressure 100.95 Temp Living Room pressure is 100.95 kpa true
2017-10-22 12:27:52.064 PM BST
2 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 12:27:52 PM Temp Living Room last checkin is 2017 Oct 22 Sun 12:27:52 PM true
2017-10-22 12:24:41.261 PM BST
2017-10-22 12:24:41.243 PM BST
2 hours ago DEVICE humidity 62 Temp Living Room humidity is 62% true
2017-10-22 12:24:41.209 PM BST
2 hours ago DEVICE temperature 20.9 Temp Living Room temperature is 20.9°C true
2017-10-22 12:24:41.228 PM BST
2 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 12:24:41 PM Temp Living Room last checkin is 2017 Oct 22 Sun 12:24:41 PM true
2017-10-22 12:02:06.475 PM BST
2 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 12:02:06 PM Temp Living Room last checkin is 2017 Oct 22 Sun 12:02:06 PM true
2017-10-22 12:01:36.112 PM BST
2017-10-22 12:01:36.094 PM BST
2 hours ago DEVICE humidity 63 Temp Living Room humidity is 63% true
2017-10-22 12:01:36.089 PM BST
2 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 12:01:36 PM Temp Living Room last checkin is 2017 Oct 22 Sun 12:01:36 PM true
2017-10-22 11:48:23.472 AM BST
2 hours ago DEVICE pressure 100.92 Temp Living Room pressure is 100.92 kpa true
2017-10-22 11:48:23.427 AM BST
2 hours ago DEVICE humidity 64 Temp Living Room humidity is 64% true
2017-10-22 11:48:23.404 AM BST
2 hours ago DEVICE temperature 21.0 Temp Living Room temperature is 21.0°C true
2017-10-22 11:48:23.421 AM BST
2 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 11:48:23 AM Temp Living Room last checkin is 2017 Oct 22 Sun 11:48:23 AM true
2017-10-22 11:20:08.034 AM BST
3 hours ago DEVICE pressure 100.89 Temp Living Room pressure is 100.89 kpa true
2017-10-22 11:20:07.994 AM BST
3 hours ago DEVICE temperature 21.2 Temp Living Room temperature is 21.2°C true
2017-10-22 11:20:08.015 AM BST
3 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 11:20:08 AM Temp Living Room last checkin is 2017 Oct 22 Sun 11:20:08 AM true
2017-10-22 11:02:54.220 AM BST
3 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 11:02:54 AM Temp Living Room last checkin is 2017 Oct 22 Sun 11:02:54 AM true
2017-10-22 10:55:02.539 AM BST
3 hours ago DEVICE pressure 100.87 Temp Living Room pressure is 100.87 kpa true
2017-10-22 10:55:02.496 AM BST
3 hours ago DEVICE temperature 21.3 Temp Living Room temperature is 21.3°C true
2017-10-22 10:55:02.519 AM BST
3 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 10:55:02 AM Temp Living Room last checkin is 2017 Oct 22 Sun 10:55:02 AM true
2017-10-22 10:36:59.034 AM BST
4 hours ago DEVICE pressure 100.84 Temp Living Room pressure is 100.84 kpa true
2017-10-22 10:36:58.991 AM BST
4 hours ago DEVICE temperature 21.4 Temp Living Room temperature is 21.4°C true
2017-10-22 10:36:59.011 AM BST
4 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 10:36:59 AM Temp Living Room last checkin is 2017 Oct 22 Sun 10:36:59 AM true
2017-10-22 10:28:07.201 AM BST
4 hours ago DEVICE pressure 100.82 Temp Living Room pressure is 100.82 kpa true
2017-10-22 10:28:07.158 AM BST
4 hours ago DEVICE temperature 21.5 Temp Living Room temperature is 21.5°C true
2017-10-22 10:28:07.178 AM BST
4 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 10:28:07 AM Temp Living Room last checkin is 2017 Oct 22 Sun 10:28:07 AM true
2017-10-22 10:27:56.930 AM BST
4 hours ago DEVICE pressure 100.85 Temp Living Room pressure is 100.85 kpa true
2017-10-22 10:27:56.886 AM BST
4 hours ago DEVICE temperature 21.6 Temp Living Room temperature is 21.6°C true
2017-10-22 10:27:56.905 AM BST
4 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 10:27:56 AM Temp Living Room last checkin is 2017 Oct 22 Sun 10:27:56 AM true
2017-10-22 10:11:03.691 AM BST
2017-10-22 10:11:03.648 AM BST
4 hours ago DEVICE temperature 21.8 Temp Living Room temperature is 21.8°C true
2017-10-22 10:11:03.666 AM BST
4 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 10:11:03 AM Temp Living Room last checkin is 2017 Oct 22 Sun 10:11:03 AM true
2017-10-22 10:04:41.827 AM BST
4 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 10:04:41 AM Temp Living Room last checkin is 2017 Oct 22 Sun 10:04:41 AM true
2017-10-22 9:58:10.384 AM BST
4 hours ago DEVICE pressure 100.8 Temp Living Room pressure is 100.8 kpa true
2017-10-22 9:58:10.357 AM BST
4 hours ago DEVICE temperature 21.9 Temp Living Room temperature is 21.9°C true
2017-10-22 9:58:10.376 AM BST
4 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 9:58:10 AM Temp Living Room last checkin is 2017 Oct 22 Sun 9:58:10 AM true
2017-10-22 9:27:34.540 AM BST
5 hours ago DEVICE temperature 22.4 Temp Living Room temperature is 22.4°C true
2017-10-22 9:27:34.583 AM BST
5 hours ago DEVICE pressure 100.79 Temp Living Room pressure is 100.79 kpa true
2017-10-22 9:27:34.550 AM BST
5 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 9:27:34 AM Temp Living Room last checkin is 2017 Oct 22 Sun 9:27:34 AM true
2017-10-22 9:13:31.858 AM BST
5 hours ago DEVICE pressure 100.76 Temp Living Room pressure is 100.76 kpa true
2017-10-22 9:13:31.834 AM BST
5 hours ago DEVICE humidity 63 Temp Living Room humidity is 63% true
2017-10-22 9:13:31.811 AM BST
5 hours ago DEVICE temperature 22.3 Temp Living Room temperature is 22.3°C true
2017-10-22 9:13:31.832 AM BST
5 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 9:13:31 AM Temp Living Room last checkin is 2017 Oct 22 Sun 9:13:31 AM true
2017-10-22 9:08:10.247 AM BST
5 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 9:08:10 AM Temp Living Room last checkin is 2017 Oct 22 Sun 9:08:10 AM true
2017-10-22 8:56:27.890 AM BST
5 hours ago DEVICE pressure 100.75 Temp Living Room pressure is 100.75 kpa true
2017-10-22 8:56:27.870 AM BST
5 hours ago DEVICE humidity 64 Temp Living Room humidity is 64% true
2017-10-22 8:56:27.847 AM BST
5 hours ago DEVICE temperature 21.8 Temp Living Room temperature is 21.8°C true
2017-10-22 8:56:27.867 AM BST
5 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 8:56:27 AM Temp Living Room last checkin is 2017 Oct 22 Sun 8:56:27 AM true
2017-10-22 8:44:25.502 AM BST
6 hours ago DEVICE pressure 100.72 Temp Living Room pressure is 100.72 kpa true
2017-10-22 8:44:25.461 AM BST
6 hours ago DEVICE temperature 21.3 Temp Living Room temperature is 21.3°C true
2017-10-22 8:44:25.483 AM BST
6 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 8:44:25 AM Temp Living Room last checkin is 2017 Oct 22 Sun 8:44:25 AM true
2017-10-22 8:33:43.268 AM BST
6 hours ago DEVICE pressure 100.71 Temp Living Room pressure is 100.71 kpa true
2017-10-22 8:33:43.227 AM BST
6 hours ago DEVICE temperature 20.8 Temp Living Room temperature is 20.8°C true
2017-10-22 8:33:43.246 AM BST
6 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 8:33:43 AM Temp Living Room last checkin is 2017 Oct 22 Sun 8:33:43 AM true
2017-10-22 8:16:29.858 AM BST
6 hours ago DEVICE pressure 100.7 Temp Living Room pressure is 100.7 kpa true
2017-10-22 8:16:29.816 AM BST
6 hours ago DEVICE temperature 20.3 Temp Living Room temperature is 20.3°C true
2017-10-22 8:16:29.834 AM BST
6 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 8:16:29 AM Temp Living Room last checkin is 2017 Oct 22 Sun 8:16:29 AM true
2017-10-22 8:15:18.983 AM BST
6 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 8:15:18 AM Temp Living Room last checkin is 2017 Oct 22 Sun 8:15:18 AM true
2017-10-22 7:50:14.019 AM BST
6 hours ago DEVICE pressure 100.67 Temp Living Room pressure is 100.67 kpa true
2017-10-22 7:50:14.007 AM BST
6 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 7:50:14 AM Temp Living Room last checkin is 2017 Oct 22 Sun 7:50:14 AM true
2017-10-22 7:50:13.973 AM BST
6 hours ago DEVICE temperature 20.2 Temp Living Room temperature is 20.2°C true
2017-10-22 7:50:13.994 AM BST
6 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 7:50:13 AM Temp Living Room last checkin is 2017 Oct 22 Sun 7:50:13 AM true
2017-10-22 7:17:17.201 AM BST
7 hours ago DEVICE lastCheckin 2017 Oct 22 Sun 7:17:17 AM Temp Living Room last checkin is 2017 Oct 22 Sun 7:17:17 AM true
2017-10-22 7:16:06.727 AM BST
7 hours ago DEVICE pressure 100.64 Temp Living Room pressure is 100.64 kpa true
Thanks for the reply. These logs are a great indication. thanks for posting. can you confirm that these are the newer temp sensors or the older ones?. Thanks again.
I am pretty new to smarthings, this forum and custom handlers. SO far, it has been a great help!! so thank you all!!
I have successfully added a xiaomi water sensor and its using the smartsense moisture device handler.
I am trying to add a door/window sensor with the a4refillpad handler but i am having an issue. everytime i go through the event log, look for catch all and add the device manually, all i see is the device stuck in open position with an exclamation mark in the middle of the image. no matter if the sensor is mechanically open or closed it still shows the same open with exclamation mark symbol. has anyone experienced this problem?
Woohoo. After pushing reset buttons for a month and looking in the logs and the hub events I was finally able to see a catch all while hitting F5 to constantly refresh the hub events log. Both my sensors are now paired!
Is it possible that the handler cant display below zero correctly? The nights are getting cold here and i have one sensor outside, when it should show -1°C it shows 101°C.
Here is a screenshot from the log: http://prntscr.com/h1hpji
