getting 88% on a brand new install on the motion sensor (the non Aqara one.) Using a4refillpad’s DH.
Overall, great little device…Let us know when you need readings on the motion sensor.
I just removed one my my 3 motion sensors and re-paired it back in ST to see what that does. I’ll wait awhile before going back to the older code. Thanks.
I’ll get that info from you, even though it is not a door/window sensor. I’m thinking battery reporting schemes are the same. Feel free to reply on this thread with the “value” and “rawDescription”.
I’m having an issue with how offer my motion sensors are activating…I went into the DH settings and set the the fastest reset (1) and I’m just not getting any motion. I noticed in the settings for the DH it says it is blind for 60 seconds. Does this mean each time it detects motion it won’t see motion for another 60 seconds? If true, these probably won’t work for me, as that’s a long time between sensing motion…Not sure if I’ve done something wrong…but sometimes they are detecting motion within a few seconds of each other and other times, not.
Update:
After reading more carefully, I guess that’s just the way this sensor is programmed. It would be nice to be able to alter the 60 second blindness, but they probably did that to conserve battery. I have another brand sensor that doesn’t limit this like this one does…
To all who is seeing 0% (or close to) battery with brand new batteries in your motion sensors, try changing the following line in your device handler:
resultMap = getBatteryResult(cluster.data.get(23)) to resultMap = getBatteryResult(cluster.data.get(30))
This may or may not work on other sensors, try it and report back.
I repushed the latest dth for the motion sensor and I’m finally reporting battery % on all 3 sensors. I’ve had these sensors over a month now. This is an interesting screen shot…
I haven’t been able to “fix” the issue been busy. One thing I’d try is switching them to C instead of Friday measurement.
I figured out what I was doing wrong…I was using the standard DTH instead
of the one specifically for the Aqara. Solved the problem in a heartbeat.
Would you mind sharing link or code for the right DH. TIA
Has anyone successfully and repeatedly paired the temp/humidty sensors?
I can pair the motion and button without issue but I have 2 new temp/humidity sensors that won’t pair. I don’t even get anything in the logs for a catchall - nada.
Batteries test fine. LED’s blink as per usual on reset.
i’m using the standard DTH from @a4refillpad and v1/v2 hubs.
I had issues where the Aquara Leak Sensor was not getting recognized at all. Here is what I had to do for it to work (putting it in beginner words, as I am a beginner):
ENJOY! Wait for a developer to create a proper device handler for this thing: to get battery status etc.
P.S: Either all of this is fluke (highly likely) or I was drunk (I do not drink) or this actually works (somewhat likely). I was able to reproduce this on two devices.
surprised you had had so much trouble. My trial one paired right away as a thing. I have two more coming, one of which i’m going to ship off to someone (who wants to volunteer?) to keep it and try and write a DTH that can get the battery %.
Just got two of the Xiaomi Aqara Temp/Humidity sensors, and wanted to share my experiences with you. I got the square sensors, exactly as described in the link, including the model number on the back of the device. Picked them for the added atmospheric pressure monitoring.
I paired them successfully with my ST Hub v2, firmware 000.018.00022, after about 4 hours of struggling and reading through more than half this thread. This is what worked in the end.
There’s one change I made for my Device Handler, to get rid of the hardcoded deviceId. I’m not sure if this makes any difference -
Changed this in the handler
fingerprint profileId: "0104", deviceId: "0302", inClusters: "0000,0001,0003,0009,0402,0405"
To this -
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0009,0402,0405", manufacturer: "Xiaomi Aqara", model: "WSDCGQ11LM"
Hope this helps someone. Also, I’m happy to run any diagnostics or any steps for anyone who’s working on making the device handlers better. I’d like to see the battery status, and pressure stats from the sensor.
Some useful instructions of the Xiaomi manuals as translated by someone else that I found useful - https://docs.google.com/document/d/1zYOjPk4Fttndztbq7hqnCrVLcNKX_AI4uWWjXL6h3nw/edit
There’s about two of the Xiaomi Smart Water Sensors coming in some time in the future. Hopefully, they will give me less of a headache when pairing
Got some of the Xiaomi Temp/humidity sensors (the older round ones). Finally got them paired (I was originally looking at live logging to find the device id, but once I looked under hub events to get it, things went smooth).
They are paired up and do report temperature, although the refresh feature does not seem to refresh data on command. Not sure why.
A question/issue I have is that every so often (every hour ish) they will show Last Update on their main screen as if the data was refreshed and is up to date according to that last update time, but in the “recently” tab the events show that only checkin was completed for the last bunch of events (every hour ish), but the last new temp/humidity/battery data receive event was like 6-8 hours ago. Hitting refresh usually doesn’t do anything, but if it does, it will update the “Last Update” date/time on the main page, and a lastcheckin event will show, but again, the battery/humidity/temp data points don’t change and the events don’t show new data for those. It’s only been a day but the temp/humidity/battery data seems to just update when it feels like it and nothing to do with checkins or refresh requests.
Is this normal? Maybe a bug? Anything I can try?
I will try this little change to see if it helps. I have tried the battery removal technique as well but I get nothing in the logs. I haven’t tried the “one minute” press for reset so I’ll give that a try as well. Was looking at live logging also so will look under hub events for some clues.
Cheers
My sensors started with 3% after pairing. Here’s the info: catchall: 0104 0000 01 01 0100 00 0C52 00 04 115F 0A 01 01FF421D0121490C0328180421A81305214F00062404000300000A210000641000
Obviously not correct, but maybe it will get the ball rolling.
Model # is MCCOQ1LM.
To partially answer my own question above, I noticed a note in the code that the refresh is not expected to work. I can see the refresh command is sent via logging, but usually doesn’t do anything. Sometimes it will do a lastcheckin update a minute or two later but I’m not entirely sure it’s related.
As far as temps not updating I did a little experimentation and it seems like the temp is only reported when it changes by 0.9 degrees F. Most updates are exactly 0.9 apart. I put the sensors in radically different temperature area from where they were and the updates rolled in automatically in 0.9 to 1.0 degrees F increments (not time based, change in temp based). Humidity appears to send updates on a 1% change basis. Battery I couldn’t get a feel for as presumably the battery is fairly stable, but the couple updates I did get were 4% changes.
My final question is – is this amount of change required to send an update something I can control via changes in the device handler? Looked quick and didn’t see anything obvious? I wouldn’t care as much if the refresh worked to pull the latest data but as is I wouldn’t mind getting a little more resolution on updates (no real reason other than more updates would inspire more confidence that it’s working and updating properly).
Let me try to find it…I can’t remember where it was!
Can you try the solution in my previous post? After you update your DH, you might need to wait up to a day, because the sensors report battery % about once a day.
Which sensor does this work with aeozyalcin? I briefly tried it yesterday, but it made no difference. I will leave the code in longer today. For a Xiaomi Aqara contact sensor (model # MCCOQ1LM), I used Brian Sparanger’s forked code from here to finally get battery % (https://github.com/bspranger/Xiaomi/blob/master/devicetypes/a4refillpad/xiaomi-aqara-door-window-sensor.src/xiaomi-aqara-door-window-sensor.groovy).
For the motion sensors, I’ve inserted your code. The bigger issue with the motion sensor right now is that it’s going offline (or at least it did last night) after 5 hours of inactivity. If it stays connected, I’ll report back to see if the battery % is working.
