I recently got a temp sensor and am having the issue where it disappears from the app but not ide. If I assign it the generic Temperature Sensor DH, it shows up and shows temp & humidity. Every time I switch back to your DH it disappears from the app.
This is what I get when I click the button on the sensor and it disappears:
3197c171-fc50-4588-a270-ef042e351700 7:50:36 PM: debug Parse returned Temp humidity is 65%
3197c171-fc50-4588-a270-ef042e351700 7:50:36 PM: debug Evencreated: humidity, 65, %
3197c171-fc50-4588-a270-ef042e351700 7:50:36 PM: debug Parsevalue: 65
3197c171-fc50-4588-a270-ef042e351700 7:50:36 PM: debug Parsename: humidity
3197c171-fc50-4588-a270-ef042e351700 7:50:36 PM: debug RAW: humidity: 64.52%
3197c171-fc50-4588-a270-ef042e351700 7:50:36 PM: debug Parse returned Temp temperature is 80.8°F
3197c171-fc50-4588-a270-ef042e351700 7:50:36 PM: debug Evencreated: temperature, 80.8, F
3197c171-fc50-4588-a270-ef042e351700 7:50:36 PM: debug Parsevalue: 80.8
3197c171-fc50-4588-a270-ef042e351700 7:50:36 PM: debug Parsename: temperature
3197c171-fc50-4588-a270-ef042e351700 7:50:36 PM: debug RAW: temperature: 27.11
3197c171-fc50-4588-a270-ef042e351700 7:50:30 PM: debug Parse returned Temp battery is --
3197c171-fc50-4588-a270-ef042e351700 7:50:30 PM: debug Evencreated: battery, --, null
3197c171-fc50-4588-a270-ef042e351700 7:50:30 PM: debug Parsevalue: --
3197c171-fc50-4588-a270-ef042e351700 7:50:30 PM: debug SmartShield(clusterId: 0x0500, command: 0x0b, data: [0x00, 0x81], destinationEndpoint: 0x01, direction: 0x01, isClusterSpecific: false, isManufacturerSpecific: false, manufacturerId: 0x0000, messageType: 0x00, number: null, options: 0x0140, profileId: 0x0104, senderShortId: 0x7e53, sourceEndpoint: 0x01, text: null)
3197c171-fc50-4588-a270-ef042e351700 7:50:30 PM: debug Parsename: battery
3197c171-fc50-4588-a270-ef042e351700 7:50:30 PM: debug RAW: catchall: 0104 0500 01 01 0140 00 7E53 00 00 0000 0B 01 0081
3197c171-fc50-4588-a270-ef042e351700 7:50:30 PM: debug Parse returned null
3197c171-fc50-4588-a270-ef042e351700 7:50:30 PM: debug Evencreated: null, null, null
3197c171-fc50-4588-a270-ef042e351700 7:50:30 PM: debug Parsevalue: null
3197c171-fc50-4588-a270-ef042e351700 7:50:30 PM: debug unknown: read attr - raw: 7E53010000240500420E6C756D692E73656E736F725F6874, dni: 7E53, endpoint: 01, cluster: 0000, size: 24, attrId: 0005, encoding: 42, value: 6C756D692E73656E736F725F6874
3197c171-fc50-4588-a270-ef042e351700 7:50:30 PM: debug Parsename: null
3197c171-fc50-4588-a270-ef042e351700 7:50:30 PM: debug RAW: read attr - raw: 7E53010000240500420E6C756D692E73656E736F725F6874, dni: 7E53, endpoint: 01, cluster: 0000, size: 24, attrId: 0005, encoding: 42, value: 6C756D692E73656E736F725F6874
I’m assuming it does have to do with battery status because I then continue to get regular updates on everything else
3197c171-fc50-4588-a270-ef042e351700 7:54:32 PM: debug Parse returned Kitchen Temp humidity is 65%
3197c171-fc50-4588-a270-ef042e351700 7:54:32 PM: debug Evencreated: humidity, 65, %
3197c171-fc50-4588-a270-ef042e351700 7:54:32 PM: debug Parsevalue: 65
3197c171-fc50-4588-a270-ef042e351700 7:54:32 PM: debug Parsename: humidity
3197c171-fc50-4588-a270-ef042e351700 7:54:32 PM: debug RAW: humidity: 64.52%
3197c171-fc50-4588-a270-ef042e351700 7:54:31 PM: debug Parse returned Kitchen Temp temperature is 78.9°F
3197c171-fc50-4588-a270-ef042e351700 7:54:31 PM: debug Evencreated: temperature, 78.9, F
3197c171-fc50-4588-a270-ef042e351700 7:54:31 PM: debug Parsevalue: 78.9
3197c171-fc50-4588-a270-ef042e351700 7:54:31 PM: debug Parsename: temperature
3197c171-fc50-4588-a270-ef042e351700 7:54:31 PM: debug RAW: temperature: 26.07
3197c171-fc50-4588-a270-ef042e351700 7:52:19 PM: debug Parse returned Temp humidity is 64%
3197c171-fc50-4588-a270-ef042e351700 7:52:19 PM: debug Evencreated: humidity, 64, %
3197c171-fc50-4588-a270-ef042e351700 7:52:19 PM: debug Parsevalue: 64
3197c171-fc50-4588-a270-ef042e351700 7:52:19 PM: debug Parsename: humidity
3197c171-fc50-4588-a270-ef042e351700 7:52:19 PM: debug RAW: humidity: 63.69%
3197c171-fc50-4588-a270-ef042e351700 7:52:19 PM: debug Parse returned Temp temperature is 79.8°F
3197c171-fc50-4588-a270-ef042e351700 7:52:19 PM: debug Evencreated: temperature, 79.8, F
3197c171-fc50-4588-a270-ef042e351700 7:52:19 PM: debug Parsevalue: 79.8
3197c171-fc50-4588-a270-ef042e351700 7:52:19 PM: debug Parsename: temperature
3197c171-fc50-4588-a270-ef042e351700 7:52:19 PM: debug RAW: temperature: 26.58
