@DroidSector first, thanks a lot for this integration!
Im having troubles making this magic cubes to stay connected to the hub, they are lasting half hour or so. Then I have to re-pair them and they change the CATCHALL code I used as device ID.
Can you please let me know if you are on HUB v1 or v2? Apparently Im the only one having this problem so I would like to know if its becuase of the V1 hub.
Thanks again for this DH. My cube has worked perfectly for a week now and thanks for enabling CoRE. I used a few virtual switches and had them activate the CoRE rules originally. I’ll be simplifying this weekend by removing the virtual switches.
I followed the instruction. But I can not see anything with catchall. Please see the screen shot. I pressed and held the botton at 10:56 and pressed again few time at 10:57.
Motion Sensor will pair without you using the log…
Get yourself a cup of tea or something stringer…
Add a thing using the ST app
Then press and hold the reset button
when it start flashing press it a couple of times
Keep doing that until it pairs (it will).
Be prepared to be patient and sit near the hub when doing it! It can take a while!
I ordered mine on Dec 30 to be shipped to the US and I’m still waiting for it to arrive. They did say up to 25 business days so I’ll give them another week.
Update: Just received my Magic Cube on Jan 28 so it took about 1 month to get here.
Just tried another hour sitting next to my ST Hub with no luck. I pressed and holded the reset button till the LED blink 3 times and kept pressing every 15 seconds. But nothing was showed on ST App-Add a thing. Is there another way to find out the network ID? I have the Xiaomi Gateway and I enable the developer mode to find out the device ID. But it’s useless here, right?
I’m not sure if you can add it manually if you have the signee id, maybe someone else will know. Alternatively you just try it using the instructions above?
