Thanks for you DTH. It’s mostly working for me - just a few questions. Would be glad if someone could help
I added the cube manually using the Device Network Id from the catchall log.
Six of the functions work - sometimes more, sometimes less reliably, but I guess that’s just a hardware thing. However, I was never able to trigger the “knock” action. Any specific hints or is my cube simply not 100 % functional? edit: got it - needs a bit more “force” apparently
Battery reporting is not working for me. Do I have to do some special “magic” in the pairing process to get it (like with some of the other Mi sensor - still waiting for my 2nd shipment)?
Is it possible for a device to un-pair by itself? I paired my 2 magic cubes yesterday and everythring was workin perfectly. I went to bed and at the next day any of the 2 magic cubes works…
Any idea?
I’m trying to pair a Mi Magic cube to and it’s not working. I’ve identified 12 catchall that aren’t it. Is there a special code I have to tap out on the one button? I’ve tried both the short press (one short blue flash) and the long press (slow flash followed by several fast flashes. Any assistance is much appreciated.
Thank you for the work on the DTH - this is fun!!! Great job!
Has anyone made this work with CoRE yet? It works great with the smart app above but I would like to use button 6/7 to increase/decrease dim level. I could do all this via virtual switches but there must be an easier way. Core recognizes the device as a single button device.
Or Im doing something wrong, or I have a defective Magic cubes… When I follow the steps in the first post Im able to link the magic cubes with my hub. But this is only lasting a couple of minutes. All of a sudden the magic cubes stop working. I have to follow all the steps again to pair them and I see they change the CATCHALL CODE used as “device ID”. Im running hub first gen.
Can anyone help? When they are working, they are great.
See this thread below. This seams to be a common thing for Xiaomi products.Mine has stayed connected for about 8 hrs now. How far away is your cube from the hub?
