Yes, but you can’t pick your weather station so the data is not nearly as good
Better than no data, at least is semi local.
Didn’t say that…
Because we cannot choose the station to pull data from we are at the mercy of whatever station is located closest to the center of the zipcode inputted. WU has many reporting stations but many are either low quality stations or improperly installed. The station my data comes from is clearly installed incorrectly. Depending on if the sun is shining the reporting station’s temperature can be off nearly 20 degrees. Many station barometers were never calibrated and are wildly off. Also can’t use it anymore for luminescence. Garbage in, garbage out.
For the Zip I put in my personal weather station ID, but it doesn’t seem to work… Should it?
PWS:KTNASHLA20
Am I doing this wrong? (I did update the various units)
To the best of my knowledge Weather Station Tile 2.0 is dead. Only option is the reduced function of “SmartWeather Station Tile” which uses a different API and doesn’t accept the PWS:xxxxx format.
This probably has nothing to do with SmartThings but more to do with IBM who owns WU. Maybe at some point things will change.
Weather Station Tile 2.0 could be alive!
At least for PWS owners.
Because I have a PWS pushing updates to wunderground I still have access to the API.
@takissd Any pointers to where I might specify the API key in the smartapp?
F
I dont think the app itself accepts the api key. and if it does it has to be written to make api calls for the new api from wu.
Yesterday the built in Smart weather Tile stopped updating as well
Am I the only one?
This tile does not update anymore.
I see the following error on IDE log:
2c321fe7-3a81-4e5c-9100-71d42879964 12:25:00 PM: warn No response from Weather Underground API
2c321fe7-3a81-4e5c-9100-71d42879964 12:25:00 PM: debug WUSTATION: Executing ‘poll’, location: 0Home
I did notice that illuminance did not update yesterday. None of my lights turned on because they thought it was still light outside. The other weather appears to be updating today, but there’s no way to know if illuminance is updating until it gets dark later.
Doesn’t update for me at all, last update date/hour stuck on yesterday even if I do manual update
This is working:
Just use no pws or specific zip code.
Stopped updating for me for 3 months… just deleted it. Any other updates or alternative?
Just installed and it’s not updating any values. Is this app dead?
This might be a valuable working alternative:
I started using the stock Weather Station Tile a couple of months ago, after the switch to the new weather API. It has been working great for me.
Yes, it seems to be working just fine
When you say stock, where did you find it? I looked through the ST classic app and couldn’t find it. How did you install it?
