[Release] Weather Station Tile 2.0
weather
dth_weather
(Phil Pugh) #325
I’ve got this setup and using with ActionTiles, one thing I notice is that the temp recordings appear a few degrees higher than expected. I haven’t entered a postcode so using my hub location which is set correctly. Which service does this use to get it’s weather info? I will check on there to see if the readings are as expected.
(Anders) #326
I’m thinking about doing some warnings for my skylight windows when it rains. Is there any specific reason why this handler doesn’t implement the water sensor capability? Seems water: true/false would translate nicely to this, and make it easy to use with other smartapps and integrations.
I guess I’ll get it to work in webcore anyway, but my programmer OCD kicked in. :wink:
A,
(JIm) #327
Trying to install this app and keep getting error about something not supported???
Trying copying code from 1st page and from raw. Same result. If I try the Githup update nothing shows up there.
(James Yeo) #328
Are you adding it as a device handler, and not an app?
(JIm) #329
Yep, my mistake. Just realized it. Works fine as device handler.
(Scott Taylor) #330
How did you get this into ActionTiles?
#331
Just go through all the devices for your location in ActionTiles and select the Weather Station thing.
Then when you are setting up your dashboard, select it for the appropriate Tab.
(the rooms manager guy) #332
in the device config i have it set to an international location zipcode in asia. after waiting 30 mins not seeing any data in the device details. does the weather data work for any zipcode or are there some limitations to which zipcodes it will work for?
thanks.
(the rooms manager guy) #333
@takissd any way to get international weather data? if i need to make code or config changes to get that working happy to do so. any pointers would be much appreciated.
thanks!
(Takis) #334
hello @bangali, I believe that sometimes there are users in UK that can get weather data for their locations, so it must work internationally. In the settings (gear icon upper right corner) you can set your zipcode. This device handler is pretty much a copy of the original weather device. So i would try the original one first, if that doesnt work, then the weather station tile 2.0 would not work either.
(the rooms manager guy) #335
Thanks @takissd. After some experimenting I found that using international zip code does not seem to work consistently. But if you change zip code to weather underground station code, it works fine.
(Jason Crosier) #336
Thanks for all the info It’s been bugging me that my auto lights using the Lux values has not been working sinse the update now code modified and working fine. I have my zipcode set to my station code and works fine here in the UK. Can anyone suggest how to modify the code to show my station ID instead of the city? I’ve had a bash at it and failed miserably!
(Jason) #337
@takissd Hello were you planning on updating the code to include the updates in post 301? I pull from repo and cannot do that as i have updated the code with those changes and if I update it will overwrite them.
(Takis) #338
@jasonrwise77
Hello Jason , all done, please verify on your side.
Thank @takissd. Was holding out updating. Just updated my code from the repo.
(Jason) #340
oh, sweet, I will check it out after work when I get home, thanks for doing that!!!
(Jason) #341
Ok, I took a look and it looks like some things are different. Here is the code I am using, can you tell me what is different, it looks like a lot of the colors are not the same? Line 95 to 103 line 165 line 192 and line 211 to 220 all are different. Please advise!!!
*  Copyright 2015 SmartThings
*  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
*  in compliance with the License. You may obtain a copy of the License at:
*      http://www.apache.org/licenses/LICENSE-2.0
*  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
*  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
*  for the specific language governing permissions and limitations under the License.
*  SmartWeather Station
*  Author: SmartThings
*  Date: 2013-04-30
metadata {
    definition (name: "SmartWeather Station Tile 2.0", namespace: "takis", author: "Takis") {
        capability "Illuminance Measurement"
        capability "Temperature Measurement"
        capability "Relative Humidity Measurement"
        capability "Sensor"
        capability "Polling"
        attribute "localSunrise", "string"
        attribute "localSunset", "string"
        attribute "city", "string"
        attribute "timeZoneOffset", "string"
        attribute "weather", "string"
        attribute "wind", "string"
        attribute "winddirection", "string"
        attribute "wind_gust", "string"
        attribute "winddirection_deg", "string"
        attribute "windinfo", "string"
        attribute "uv_index", "string"
        attribute "water", "string"
        attribute "weatherIcon", "string"
        attribute "forecastIcon", "string"
        attribute "feelsLike", "string"
        attribute "percentPrecip", "string"
        attribute "percentPrecipToday", "string"
        attribute "percentPrecipLastHour", "string"
        attribute "alert", "string"
        attribute "alertKeys", "string"
        attribute "sunriseDate", "string"
        attribute "sunsetDate", "string"
        attribute "dewpoint", "string"
        attribute "wind_degrees", "string"
        attribute "pressure", "string"
        attribute "solarradiation", "string"
        attribute "visibility", "string"
        attribute "pressureTrend", "string"
        command "refresh"
    preferences {
        input "zipCode", "text", title: "Zip Code (optional)", required: false
        input (description: "Setting the Barometer Pressure units (optional)",
            title: "Pressure units", displayDuringSetup: false, type: "paragraph", element: "paragraph")
        input ("pres_units", "enum", title: "Pressure units", required: false,
			options: [
		        "press_in":"Inches",
		        "press_mb":"milli bars"
        input (description: "Setting the distance units (optional)",
			title: "Distance Units", displayDuringSetup: false, type: "paragraph", element: "paragraph")
        input ("dist_units", "enum", title: "Distance units", required: false,
			options: [
		        "dist_mi":"Miles",
		        "dist_km":"Kilometers"
        input (description: "Setting the Height units (optional)",
			title: "Height Units", displayDuringSetup: false, type: "paragraph", element: "paragraph")
        input("height_units", "enum", title: "Height units", required: false,
			options: [
                "height_in":"Inches",
                "height_mm":"Millimiters"
        input (description: "Setting the Speed units (optional)",
			title: "Speed Units", displayDuringSetup: false, type: "paragraph", element: "paragraph")
        input("speed_units", "enum", title: "Speed units", required: false,
			options: [
                "speed_mph":"Miles per Hour",
                "speed_kph":"Kilometers per Hour"
        input "weather", "device.smartweatherStationTile", title: "Weather...", multiple: true, required: false
    tiles(scale: 2) {
        multiAttributeTile(name:"temperature", type:"generic", width:6, height:4, canChangeIcon: false) {
            tileAttribute("device.temperature", key: "PRIMARY_CONTROL") {
                attributeState("temperature", label:'${currentValue}°',
					backgroundColors:[
                    		[value: 32, color: "#153591"],
				[value: 44, color: "#1e9cbb"],
				[value: 59, color: "#90d2a7"],
				[value: 74, color: "#44b621"],
				[value: 84, color: "#f1d801"],
				[value: 92, color: "#d04e00"],
				[value: 98, color: "#bc2323"]
            tileAttribute("device.feelsLike", key: "SECONDARY_CONTROL") {
                attributeState("default", label:'Feels Like ${currentValue}°')
        standardTile("weatherIcon", "device.weatherIcon", decoration: "flat") {
            state "chanceflurries", icon:"st.custom.wu1.chanceflurries", label: ""
            state "chancerain", icon:"st.custom.wu1.chancerain", label: ""
            state "chancesleet", icon:"st.custom.wu1.chancesleet", label: ""
            state "chancesnow", icon:"st.custom.wu1.chancesnow", label: ""
            state "chancetstorms", icon:"st.custom.wu1.chancetstorms", label: ""
            state "clear", icon:"st.custom.wu1.clear", label: ""
            state "cloudy", icon:"st.custom.wu1.cloudy", label: ""
            state "flurries", icon:"st.custom.wu1.flurries", label: ""
            state "fog", icon:"st.custom.wu1.fog", label: ""
            state "hazy", icon:"st.custom.wu1.hazy", label: ""
            state "mostlycloudy", icon:"st.custom.wu1.mostlycloudy", label: ""
            state "mostlysunny", icon:"st.custom.wu1.mostlysunny", label: ""
            state "partlycloudy", icon:"st.custom.wu1.partlycloudy", label: ""
            state "partlysunny", icon:"st.custom.wu1.partlysunny", label: ""
            state "rain", icon:"st.custom.wu1.rain", label: ""
            state "sleet", icon:"st.custom.wu1.sleet", label: ""
            state "snow", icon:"st.custom.wu1.snow", label: ""
            state "sunny", icon:"st.custom.wu1.sunny", label: ""
            state "tstorms", icon:"st.custom.wu1.tstorms", label: ""
            state "nt_chanceflurries", icon:"st.custom.wu1.nt_chanceflurries", label: ""
            state "nt_chancerain", icon:"st.custom.wu1.nt_chancerain", label: ""
            state "nt_chancesleet", icon:"st.custom.wu1.nt_chancesleet", label: ""
            state "nt_chancesnow", icon:"st.custom.wu1.nt_chancesnow", label: ""
            state "nt_chancetstorms", icon:"st.custom.wu1.nt_chancetstorms", label: ""
            state "nt_clear", icon:"st.custom.wu1.nt_clear", label: ""
            state "nt_cloudy", icon:"st.custom.wu1.nt_cloudy", label: ""
            state "nt_flurries", icon:"st.custom.wu1.nt_flurries", label: ""
            state "nt_fog", icon:"st.custom.wu1.nt_fog", label: ""
            state "nt_hazy", icon:"st.custom.wu1.nt_hazy", label: ""
            state "nt_mostlycloudy", icon:"st.custom.wu1.nt_mostlycloudy", label: ""
            state "nt_mostlysunny", icon:"st.custom.wu1.nt_mostlysunny", label: ""
            state "nt_partlycloudy", icon:"st.custom.wu1.nt_partlycloudy", label: ""
            state "nt_partlysunny", icon:"st.custom.wu1.nt_partlysunny", label: ""
            state "nt_sleet", icon:"st.custom.wu1.nt_sleet", label: ""
            state "nt_rain", icon:"st.custom.wu1.nt_rain", label: ""
            state "nt_snow", icon:"st.custom.wu1.nt_snow", label: ""
            state "nt_sunny", icon:"st.custom.wu1.nt_sunny", label: ""
            state "nt_tstorms", icon:"st.custom.wu1.nt_tstorms", label: ""
        valueTile("lastSTupdate", "device.lastSTupdate", inactiveLabel: false, width: 2, height: 1, decoration: "flat", wordWrap: true) {
            state("default", label: 'Last Updated\n ${currentValue}')
        valueTile("humidity", "device.humidity", inactiveLabel: false, width: 2, height: 1, decoration: "flat", wordWrap: true) {
            state "default", label:'Humidity ${currentValue}%', unit:"%"
        valueTile("weather", "device.weather", inactiveLabel: false, width: 1, height: 1, decoration: "flat", wordWrap: true) {
            state "default", label:'${currentValue}'
        valueTile("percentPrecip", "device.percentPrecip", inactiveLabel: false, width: 1, height: 1, decoration: "flat", wordWrap: true) {
            state "default", label:'Chance\n ${currentValue}%'
        valueTile("percentPrecipToday", "device.percentPrecipToday", inactiveLabel: false, width: 2, height: 1, decoration: "flat", wordWrap: true) {
            state "default", label:'Rain Today\n ${currentValue}'
        valueTile("percentPrecipLastHour", "device.percentPrecipLastHour", inactiveLabel: false, width: 2, height: 1, decoration: "flat", wordWrap: true) {
            state "default", label:'Rain Last Hour\n ${currentValue}'
        standardTile("refresh", "device.weather", inactiveLabel: false, width: 1, height: 1, decoration: "flat", wordWrap: true) {
            state "default", label: "", action: "refresh", icon:"st.secondary.refresh"
        valueTile("alert", "device.alert", inactiveLabel: false, width: 5, height: 1, decoration: "flat", wordWrap: true) {
            state "default", label:'Weather Alerts:\n ${currentValue}'
        valueTile("rise", "device.localSunrise", inactiveLabel: false, width: 2, height: 1, decoration: "flat", wordWrap: true) {
            state "default", label:'Sunrise\n ${currentValue}'
        valueTile("set", "device.localSunset", inactiveLabel: false, width: 2, height: 1, decoration: "flat", wordWrap: true) {
            state "default", label:'Sunset\n ${currentValue}'
        valueTile("light", "device.illuminance", inactiveLabel: false, width: 2, height: 1, decoration: "flat", wordWrap: true) {
            state "default", label:'${currentValue} lux'
        valueTile("visibility", "device.visibility", inactiveLabel: false, width: 2, height: 1, decoration: "flat", wordWrap: true) {
            state "default", label:'Visibility\n ${currentValue}'
        valueTile("uv_index", "device.uv_index", inactiveLabel: false, width: 2, height: 1, decoration: "flat", wordWrap: true) {
            state "uv_index", label: 'UV Index\n ${currentValue}', unit: "UV Index"
        standardTile("water", "device.water", inactiveLabel: false, width: 1, height: 1, decoration: "flat", wordWrap: true) {
            state "default", label: 'updating...', icon: "st.unknown.unknown.unknown"
            state "true",        icon: "st.alarm.water.wet",        backgroundColor:"#ff9999"
            state "false",       icon: "st.alarm.water.dry",        backgroundColor:"#99ff99"
        valueTile("dewpoint", "device.dewpoint", inactiveLabel: false, width: 2, height: 1, decoration: "flat", wordWrap: true) {
            state "default", label:'Dewpoint ${currentValue}°'
        valueTile("pressure", "device.pressure", inactiveLabel: false, width: 3, height: 1, decoration: "flat", wordWrap: true) {
            state "pressure", label: 'Barometric Pressure ${currentValue}'
        valueTile("windinfo", "device.windinfo", inactiveLabel: false, width: 3, height: 1, decoration: "flat", wordWrap: true) {
            state "windinfo", label: 'Wind ${currentValue}'
        valueTile("temperature2", "device.temperature", width: 1, height: 1, canChangeIcon: true) {
            state "temperature", label: '${currentValue}°',
				backgroundColors:[
        main(["temperature2"])
        details(["temperature", "feelslike", "weatherIcon", "weather", "humidity" , "dewpoint", "windinfo", "pressure", "solarradiation", "uv_index", "light", "visibility", "city", "rise", "set", "lastSTupdate", "percentPrecip", "percentPrecipToday", "percentPrecipLastHour", "water", "alert", "refresh"])}
    log.debug "Parsing '${description}'"
def installed() {
	runEvery15Minutes(poll)
def uninstalled() {
	unschedule()
def updated() {
	unschedule()
// handle commands
def poll() {
    log.debug "WUSTATION: Executing 'poll', location: ${location.name}"
    // Current conditions
    def obs = get("conditions")?.current_observation
    if (obs) {
        log.debug "obs --> ${obs}"
        def now = new Date().format('HH:mm:ss M.d.yyyy',location.timeZone)
        sendEvent(name:"lastSTupdate", value: now)
        def weatherIcon = obs.icon_url.split("/")[-1].split("\\.")[0]
        if(getTemperatureScale() == "C") {
            send(name: "temperature", value: Math.round(obs.temp_c), unit: "C")
            send(name: "feelsLike", value: Math.round(obs.feelslike_c as Double), unit: "C")
            send(name: "dewpoint", value: Math.round(obs.dewpoint_c as Double), unit: "C")
        } else {
            send(name: "temperature", value: Math.round(obs.temp_f), unit: "F")
            send(name: "feelsLike", value: Math.round(obs.feelslike_f as Double), unit: "F")
            send(name: "dewpoint", value: Math.round(obs.dewpoint_f as Double), unit: "F")
        send(name: "humidity", value: obs.relative_humidity[0..-2] as Integer, unit: "%")
        send(name: "weather", value: obs.weather)
        send(name: "weatherIcon", value: weatherIcon, displayed: false)
        send(name: "uv_index", value: obs.UV)
        send(name: "solarradiation", value: obs.solarradiation, display: false)
        def pressure_trend_text
        switch (obs.pressure_trend) {
        case "-" :
            pressure_trend_text = "Falling"
            break;
        case "+":
            pressure_trend_text = "Rising"
            break;
        case "=":
            pressure_trend_text = "Steady"
            break;
        case "0":
            pressure_trend_text = "No Change"
            break;
        default:
            pressure_trend_text = "N/A"
        if (pres_units) {
            switch (pres_units) {
            case "press_mb" :
                send(name: "pressure", value: "${obs.pressure_mb} mbar (${pressure_trend_text})")
                break;
            case "press_in":
                send(name: "pressure", value: "${obs.pressure_in} inches (${pressure_trend_text})")
                break;
            default:
        } else {
        if (dist_units) {
            switch (dist_units) {
            case "dist_mi" :
                send(name: "visibility", value: "${obs.visibility_mi} mi")
                break;
            case "dist_km":
                send(name: "visibility", value: "${obs.visibility_km} km")
                break;
            default:
        } else {
        if (height_units) {
            switch (height_units) {
            case "height_in" :
                send(name: "percentPrecipToday", value: "${obs.precip_today_in} in")
                send(name: "percentPrecipLastHour", value: "${obs.precip_1hr_in} in")
                break;
            case "height_mm":
                send(name: "percentPrecipToday", value: "${obs.precip_today_metric} mm")
                send(name: "percentPrecipLastHour", value: "${obs.precip_1hr_metric} mm")
                break;
            default:
        } else {
        if (speed_units) {
            switch (speed_units) {
            case "speed_mph" :
                send(name: "windinfo", value: "${obs.wind_dir} (${obs.wind_degrees}°) at ${obs.wind_mph} mph\n(Gust: ${obs.wind_gust_mph} mph)")
                send(name: "wind_gust", value: "${obs.wind_gust_mph}")
                send(name: "winddirection", value: "${obs.wind_dir}")
                send(name: "winddirection_deg", value: "${obs.wind_degrees}")
                send(name: "wind", value: "${obs.wind_mph}")
                break;
            case "speed_kph":
                send(name: "windinfo", value: "${obs.wind_dir} (${obs.wind_degrees}°) at ${obs.wind_kph} kph\n(Gust: ${obs.wind_gust_kph} kph)")
                send(name: "wind_gust", value: "${obs.wind_gust_kph}")
                send(name: "wind", value: "${obs.wind_kph}")
                break;
            default:
        } else {
        // Since precip_1hr_in is a string, we need to convert it to a decimal in order to compare it as a number.
        if (obs.precip_1hr_in.toFloat() > 0) {
            sendEvent( name: 'water', value: "true" )
        } else {
            sendEvent( name: 'water', value: "false" )
        if (obs.local_tz_offset != device.currentValue("timeZoneOffset")) {
            send(name: "timeZoneOffset", value: obs.local_tz_offset, isStateChange: true)
        def cityValue = "${obs.display_location.city}, ${obs.display_location.state}"
        if (cityValue != device.currentValue("city")) {
            send(name: "city", value: cityValue, isStateChange: true)
        // Sunrise / sunset
        def a = get("astronomy")?.moon_phase
        def today = localDate("GMT${obs.local_tz_offset}")
        def ltf = new java.text.SimpleDateFormat("yyyy-MM-dd HH:mm")
        ltf.setTimeZone(TimeZone.getTimeZone("GMT${obs.local_tz_offset}"))
        def utf = new java.text.SimpleDateFormat("yyyy-MM-dd'T'HH:mm:ss.SSS'Z'")
        utf.setTimeZone(TimeZone.getTimeZone("GMT"))
        def sunriseDate = ltf.parse("${today} ${a.sunrise.hour}:${a.sunrise.minute}")
        def sunsetDate = ltf.parse("${today} ${a.sunset.hour}:${a.sunset.minute}")
        def tf = new java.text.SimpleDateFormat("HH:mm")
        def localSunrise = "${tf.format(sunriseDate)}"
        def localSunset = "${tf.format(sunsetDate)}"
        send(name: "localSunrise", value: localSunrise, descriptionText: "Sunrise today is at $localSunrise")
        send(name: "localSunset", value: localSunset, descriptionText: "Sunset today at is $localSunset")
        send(name: "illuminance", value: estimateLux(sunriseDate, sunsetDate, weatherIcon))
        // Forecast
        def f = get("forecast")
        def f1= f?.forecast?.simpleforecast?.forecastday
        if (f1) {
            def icon = f1[0].icon_url.split("/")[-1].split("\\.")[0]
            def value = f1[0].pop as String // as String because of bug in determining state change of 0 numbers
            send(name: "percentPrecip", value: value, unit: "%")
            send(name: "forecastIcon", value: icon, displayed: false)
        else {
            log.warn "Forecast not found"
        // Alerts
        def alerts = get("alerts")?.alerts
        def newKeys = alerts?.collect{it.type + it.date_epoch} ?: []
        //log.debug "WUSTATION: newKeys = $newKeys"
        log.trace device.currentState("alertKeys")
        def oldKeys = device.currentState("alertKeys")?.jsonValue
        //log.debug "WUSTATION: oldKeys = $oldKeys"
        def noneString = "no current weather alerts"
        if (!newKeys && oldKeys == null) {
            send(name: "alertKeys", value: newKeys.encodeAsJSON(), displayed: false)
            send(name: "alert", value: noneString, descriptionText: "${device.displayName} has no current weather alerts", isStateChange: true)
        else if (newKeys != oldKeys) {
            if (oldKeys == null) {
                oldKeys = []
            def newAlerts = false
            alerts.each {alert ->
                if (!oldKeys.contains(alert.type + alert.date_epoch)) {
                    def msg = "${alert.description} from ${alert.date} until ${alert.expires}"
                    send(name: "alert", value: pad(alert.description), descriptionText: msg, isStateChange: true)
                    newAlerts = true
            if (!newAlerts && device.currentValue("alert") != noneString) {
    else {
        log.warn "No response from Weather Underground API"
def refresh() {
    poll()
def configure() {
    poll()
private pad(String s, size = 25) {
    def n = (size - s.size()) / 2
    if (n > 0) {
        def sb = ""
        n.times {sb += " "}
        sb += s
        n.times {sb += " "}
        return sb
    else {
        return s
private get(feature) {
    getWeatherFeature(feature, zipCode)
private localDate(timeZone) {
    def df = new java.text.SimpleDateFormat("yyyy-MM-dd")
    df.setTimeZone(TimeZone.getTimeZone(timeZone))
    df.format(new Date())
private send(map) {
    //log.debug "WUSTATION: event: $map"
    sendEvent(map)
private estimateLux(sunriseDate, sunsetDate, weatherIcon) {
    def lux = 0
    def now = new Date().time
    if (now > sunriseDate.time && now < sunsetDate.time) {
        //day
        switch(weatherIcon) {
        case 'tstorms':
            lux = 200
            break
        case ['cloudy', 'fog', 'rain', 'sleet', 'snow', 'flurries',
            'chanceflurries', 'chancerain', 'chancesleet',
            'chancesnow', 'chancetstorms']:
            lux = 1000
            break
        case 'mostlycloudy':
            lux = 2500
            break
        case ['partlysunny', 'partlycloudy', 'hazy']:
            lux = 7500
            break
        default:
            //sunny, clear
            lux = 10000
        //adjust for dusk/dawn
        def afterSunrise = now - sunriseDate.time
        def beforeSunset = sunsetDate.time - now
        def oneHour = 1000 * 60 * 60
        if(afterSunrise < oneHour) {
            //dawn
            lux = (long)(lux * (afterSunrise/oneHour))
        } else if (beforeSunset < oneHour) {
            //dusk
            lux = (long)(lux * (beforeSunset/oneHour))
    else {
        //night - always set to 10 for now
        //could do calculations for dusk/dawn too
        lux = 10
    lux
(Takis) #342
Hello Jason, i am currently on vacation with minimal internet and devices, i will have to get back to it when i get back in a few days… thanks
#343
I recently just started using this, love that I can easily see the brightness now! I have an existing tile that is used in a bunch of webCore routines using the stock tile. I setup a test tile using 2.0. Can I take the existing tile and just update the handler to be the 2.0 version or would I need to edit the routines to use the new tile?
(Allan) #344
GitHub repo under maintenance? I added the info but nothing shows up when trying to download.
