I have spent an entire afternoon and night (1:30am now) to get this working and have failed. At some point I got it to show active with Kevin’s DTH, but not any more.
What is the proper way to reset the device? The instructions are a little unclear. Comments in [ ] are mine.
Press the locking tab on the top of the sensor cover and gently remove the cover [OK I got that]
Remove the batter [OK I got that]
Press and hold the Program/Tamper Switch for about 5 seconds and at the same time, reinsert the battery. [I interpret this to mean as soon as I press the switch, I put the battery in] The sensor will reset to the default values and transmit the DEVICE RESET LOCALLY NOTIFICATIOn command class to the controller. The LED will be steadily illuminated for about 5 seconds [mine only stays steady for less than 2 seconds], then it will start flashing to indicate that it is not “included” in a network.
Also, do you guys adjust the sensitivity or just leave it at the default position (middle)?
Do you guys test it by tapping the device itself or the table?
I got this “warning” in Live Logging during adding of the device:
Unable to extract encapsulated cmd from SecurityMessageEncapsulation(commandByte: [95, 197, 90, 180, 220, 207, 203, 56, 245, 102, 80, 77, 225, 189, 116, 101, 243, 0, 62, 10], commandClassIdentifier: 104, commandIdentifier: 122, reserved13: 0, secondFrame: false, sequenceCounter: 14, sequenced: false)
Any help will be appreciated. I like a challenge, but this is taking way too much time. I had envisioned setting something like this up at my parents’ place, but I can only imagine how often I have to show up to repair the system.
Tom
