SmartThings Community
[RELEASE] Virtual Garage Door Opener/Controller with Relays and Tilt/Door Sensors
dth_garage
smartapp
garagedooropener
dth_sensors
rboyapps
#101
Does this only work with the zwave relays or the relays that are listed above? I am hoping to use a smart switch (ihome control isp5) with a RIB relay to act as the relay piece in conjunction with the SmartThings Multi-Purpose sensor setup for a garage door sensor. While waiting for the RIB relay to arrive and connect, I tried setting up the device via the SmartApp, selecting the isp5 as the “Relay switch” and the multi-purpose sensor as the “Open/Close sensor” - when I try to Save everything it initially says it updates it but then I get an error saying “Installing device Garage Door 2 failed”
Any ideas on what’s going wrong here?
(Head of Support (rboyapps.com)) #102
Minor enhancement release
Virtual Garage Door Manager SmartApp - v01.04.01
  • < No change >
Virtual Garage Door Controller Device Handler - v01.02.05
  • Report the momentary event when pushed (toggled)
