Will this work with the Aeotec Garage Door Controller?
RBoy
46
Thatâs an integrated garage door controller, this is for build a custom garage door opener using various sensors.
See the first post or below for a link to an integrated garage door device handler. However that one doesnât have support for advanced features of the Aeotec model. If we get enough requests for the device we can build support for it.
I have run into a slight problem, not sure if it is the Smartapp, DTH or something else. My system as you know has a Inovelli Dual Channel Smart plug.
When I open my garage door and close it everything is fine
If I open my wifeâs garage door there isnât a problem,
But when I close it I see the Parent channel flashes on then off then on and the door closes, but the Parent shows on even when it is off.
So not sure if it is something related to the Smartapp or DTH, Or a quirk with ST.
If I hit the refresh button on the outlet it reverts to the state it is actually in. Which is closed.
RBoy
48
These all appear to be related your outlet/plug device handler. Youâll have to contact the author of the outlet device handler.
I am using this now and I am very pleased⊠One question is related to the optional alert sound.you have included, but that I am not using. Would it be difficult to tie a delay in to the door trigger, so that if you used the alert sound option - you could make it more like the goControl door opener and have a couple seconds of sound (and maybe light) before the door was triggered to activate? Thanks.
I have a sound question also, I have it turned on to admit a sound from my IRIS keypad, but no sound is heard, then tried with Aeon Siren same result., any ideas? Or could it be made to use a connected speaker?
RBoy
54
I think thatâs very do able, please send in the request to our support team so we can prioritize it.
@joelw135 we tried the IRIS keypad also and I think itâs an issue with the device handler since I canât get that device to beep anywhere.
Basically if your device supports the capability âtoneâ, it should work fine. I know someone else had tried a Chime device (Aeon?) sometime ago with another SmartApp that supports beep and it didnât work. You can verify with the device author if the device supports the command âbeepâ
Since the big ST âcrashâ last week the response from Alexa to âAlexa, open the big garage doorâ is now âBig garage door doesnât support thatâ instead of simply opening the door.
âOpen the big garage doorâ and âShut (CLOSE command has never worked) the big garage doorâ were working fine since I set it up 6 weeks or so ago.
