@tgauchat Ok. So I pushed it to GitHub. Only thing people will have to edit is their ip camera addresses(if they have cameras) in the camera.php file, their actiontile website addresses in the index.html file, the traffic location in the index.html file (It uses GPS coordinates), and the “Hub” is Dakboard. So they will have to set one up, and use that link. The weather uses geolocation. Should be fairly simple for people to do. It’s not noob, but very close. It’s a simple local website that uses frames to display their actiontiles, cameras, Weather, and dakboard.
@tgauchat, maybe you guys can write something up. I’m not a writer or explained, by any means lol.
Synthesis
(The Viking AKA "Holy Crap You're a Giant!")
1281
I started poking at this a little bit, discovered some things you’ll want to tweak in the files before you release publicly. I sent details to you in a PM.
In the meantime, I’ve set it up on my Intel ComputeStick 22" portrait wall control panel and started adding some menu buttons on the left to control my whole home audio and home theater systems. Once I sort out the iFrame layouts and make them taller for my portrait screen, I’ll be able to start helping you write documentation for it.
I have noticed in the past week or so the need to ‘reload’ more frequently than usual. Also a few days ago I noticed that the ‘mode’ tile seemed reluctant to change status (it failed to update to the current state even though other tiles did respond to a reload). I haven’t seen that happen again.
I have a routine with a single quote mark in it (added via iPad if that’s relevant - I think sometimes iOS uses a different char than standard). It looks like the UTF-8 code for the quote is being displayed in AT:
That appears to refer to foreign characters. So a single quote falls in to that category?
tgauchat
1290
Any “extended” character. I don’t know the exact specs; but either it works, or doesn’t.
The problem is due to a bugin SmartThings such that “extended” characters are stripped in outgoing asynchronous JSON posts. So we escape them all. We just haven’t unescaped them in every place in our app. They are handled properly in some places. It’s just an app change that hasn’t been fully implemented.
Is down here too. I posted it just now on their forum.
Great, now I have to teach my wife how to use SmartThings App…
Synthesis
1294
Confirmed: Is Down.
I’m able to see my control panel where I can define/edit all of my AT settings, but it is blank with regards to what panels I have.
Looks like all panels are missing from the admin panel on my end. You can add a new one and it’s viewable. Don’t recommend doing this though, as they may need to do a restore or something.
