In the post you quoted, I specifically said that I got it to work properly and how I did it. Your rude answer doesn’t even answer the question you quoted.
I don’t think Barry was being rude. He was stating a fact.
When you say that you got “it” to work, what is “it” since it isn’t the version that this thread is about. That is what he was trying to point out.
Perhaps you posted on the wrong thread?
My sincere apologies, I did not intend to insult you.
My point here is that you aren’t using either of the DTH versions discussed this thread, and so it is doubtful anyone reading this thread will be able to answer your questions. You should probably post a new/separate thread that is specific to the DTH version you are using.
FWIW, both @StrykerSKS and my version of the Ecobee DTH cannot be installed manually. Everything must be installed and configured using the Ecobee (Connect) parent SmartApp that each of our versions supplies. I generally find that people who have problems with sourcing their code from Github have extraneous copies of other Ecobee DTH and/or SmartApps existing within their IDE, have made local changes to the copy in their IDE, and/or they have installed to an IDE running on shard that is different from the one their SmartThings hub has been assigned to.
I thought it is obvious that I am using everything from StrykerSKS and that I would not post in the wrong thread.
Isn’t this StrykerSKS github repo?
That same page says that anyone can manually install everything manually instead of using GitHub Integration that SmartThings offers with their IDE.
I have other apps using GitHub Integration that do not have any problems.
So that goes back to the original question: why would GitHub Integration not work and work fine manually and only for StrykerSKS?
Yup, that’s his repo.
But his DTH suite doesn’t look like the screenshot you posted above. His UI is described here:
Note the extreme differences from your screen shot.
Hence, our collective confusion…
All I did was install the DTH using GitHub Integration according to instructions at https://github.com/StrykerSKS/SmartThingsPublic/tree/StrykerSKS-Ecobee3/smartapps/smartthings/ecobee-connect.src#install-using-github-integration-recommended-method.
I then installed the smart app manually according to instructions at https://github.com/StrykerSKS/SmartThingsPublic/tree/StrykerSKS-Ecobee3/smartapps/smartthings/ecobee-connect.src#install-manually-from-code-1.
I installed the smart app manually because the instructions at https://github.com/StrykerSKS/SmartThingsPublic/tree/StrykerSKS-Ecobee3/smartapps/smartthings/ecobee-connect.src#install-using-github-integration only produces this error: {“error”:true,“type”:“java.lang.reflect.UndeclaredThrowableException”,“message”:“An unexpected error occurred.”}
In the end, I decided to try to install DTH manually using instructions at https://github.com/StrykerSKS/SmartThingsPublic/tree/StrykerSKS-Ecobee3/smartapps/smartthings/ecobee-connect.src#install-manually-from-code and the smart app using instructions at https://github.com/StrykerSKS/SmartThingsPublic/tree/StrykerSKS-Ecobee3/smartapps/smartthings/ecobee-connect.src#install-manually-from-code-1. Lo and behold, it worked!
But it didn’t work. It should look like the screenshots!
My best guess is that you either have some other DTH installed too or pulled from a very old version of mine.
In the code in the IDE what version does the headers say it is?
Making a mistake setting up GitHub Integration seems impossible to me when looking at this:
Here’s the other DTH’s I have:
Delete the device, delete the device handlers, delete the smart app, make sure you don’t have any other EcoBee devices anywhere and start from scratch. Something is very wrong with your install.
You are using the wrong branch. Don’t use “master” use the one specified in the instructions please.
Thanks. I will try that. Did not think that was possible.
Also, you should really consider moving over to Barry’s app instead. He is actively maintaining his version, whereas I’ve stopped doing anything to mine since his has been released.
@SEAN KENDALL SCHNEYER, is that project still in play and being updated? I just got myself an Ecobee Lite and would be intersted in testing out the app. Thanks thanksk.
