Does this work for the E3 Lite? I got past the step where I connect to Ecobee then when I go back in I can select the thermostats to install but when I click done it saves error saving page. I didn’t want to setup any helper smartapps yet so occurred to me that since I have no sensors to select maybe its erroring out?
I usually see this when Ecobee is doing server maintenance. It should clear itself up automatically but if you continue to see it then I’d suggest re-authenticating.
This is what fixed it for me. Even though the device handler was showing it as connected , I went back in and re-entered the credentials and everything came back to communicating again.
When using CoRe, which action do I choose for it to change to Away/Home mode?
I tried using away(…), but there is a time limit shown on the thermostat itself. Any option for hold type change to until I change like in the Ecobee Routine app? Also, I can’t find home(…) in there.
As a note if you want to hold it until the next program in your schedule use nextTransition instead of indefinite. There is also Temporary (think that is a set amount of time but I haven’t tried it)
I was wondering what was going on with all my sensors frozen at a certain temp. Wouldn’t update or see any polls in the recent activity to get the latest temps.
I tried your suggestion and re-entered my credentials to authorize the SmartApp and it worked!! Thanks! Spent hours trying to troubleshoot.
EDIT: spoke too soon, not sure what’s up with my setup but all my ecobee remote sensors don’t poll to get temps but my main thermos poll every 10-15 mins for new temps. Never had this issue before.
I think using away(…) will only set the program based on your default preferences. If you want to override your default preferences you’ll have to do that with setThermostatProgram(…)
It won’t pick up motion as quickly as a real motion sensor. It takes a few minutes. I tried using the ecobee motion sensor for turning on lights when I entered the room. Doesnt work u less you’re in there for a few minutes.
I tried generating new tokens for OAuth but now the app wont let me login to Ecobee with my credentials, it gives me a blank screen inside the app with the token and token invalid.
I tried to delete the connection but it says “Unexpected error occurred”.
I actually had to blow away all my thermostats and sensors and just remove the SmartApp. I set it up all over again and going to see if it works with the default settings for now. I’ll see if my sensors temps update. How long do they poll for temps?
Default polling is every 5 minutes. You can adjust that in the settings, but 5 minutes is recommended by Ecobee for polling. More than that can sometimes cause additional disconnects.
Does anyone else have their Ecobee setup with no schedule and then just change Ecobee modes (Home, Away. Sleep) via Smartthings? I recently changed to this and it’s working well.
