[RELEASE] Universal Virtual Device Type and Translator
Is this still available anywhere? I am just getting a 404 error when I go to any of the links to the GitHub. Thanks for any assistance.
It apparently vanished, along with the github repo :frowning:
I’ve rescued it from one of the posts further up and stuck it in a git repo. You can grab it from
or use Owner: CultusMechanicus Name: uvdt Branch: master in the IDE github integration
If anyone (ie. Mike or Scott) objects to me doing that, shout and I’ll get rid of it.
Anybody know what in the world happened?
The developer became a principal in a startup that is developing another home automation hub.
At least that’s my guess as to why all of his ST smartapps and device handlers are no longer available.
Does anybody have the 1.0.7 version of this DTH? I believe it added some “not used” changes to the code.
Also requesting somebody help out and upload 1.0.7 either here or on GitHub. Please and thank you!
What did 1.07 fix?
	Universal virtual DTH
  	Copyright 2016 Mike Maxwell
	1.0.7	2016-09-22	added smoke, water and sound thanks Scott
    					added not used option to each device tile
                        fixed bug in illuminance not working
    1.0.5	2016-08-29  added sensor and actuator capabilities per Alex
    1.0.4	2016-05-21	added LUX capability
    1.0.3	2016-05-18	added optional auto off
    1.0.2	2016-05-15	ignore duplicate input requests
    					added version info
	This software if free for Private Use. You may use and modify the software without distributing it.
	This software and derivatives may not be used for commercial purposes.
	You may not distribute or sublicense this software.
	You may not grant a sublicense to modify and distribute this software to third parties not included in the license.
	Software is provided without warranty and the software author/license owner cannot be held liable for damages.
metadata {
		definition (name: "uDTH", namespace: "MikeMaxwell", author: "mike maxwell") {
	    capability "Sensor"
	    capability "Actuator"
		//inputs
	    capability "Switch"					//on, off
        capability "Lock"					//lock, unlock
        //outputs
        capability "Contact Sensor"			//"open","closed"
        capability "Motion Sensor"			//"active", "inactive"
        capability "Presence Sensor"		//"present", "not present"
        capability "Acceleration Sensor"	//"active", "inactive"
        capability "Illuminance Measurement"
        capability "Smoke Detector"    //"detected", "clear", "tested"
        capability "Water Sensor"      //"dry", "wet"
        capability "Sound Sensor"      //"detected", "not detected"
        //both
        capability "Door Control"			//listen for "open", "close" respond with "open" "closed"
        capability "Garage Door Control"	//listen for "open", "close" respond with "open" "closed"
        command "localOff"
        command "localOn"
        attribute "version", "string"
    preferences {
    	def s1
        def s2
        def d
        //paragraph input
        input(
            title			: "uDTH version: ${getVersion()}"
            ,description	: null
            ,type			: "paragraph"
    	input(
        	title			: "Device inputs\nRespond to these events/commands."
            ,description	: null
            ,type			: "icon"
            ,required		: false
            ,defaultValue	: "st.illuminance.illuminance.dark"
        input(
            ,title			: "Switch (on, off)"
           	,type			: "bool"
            ,defaultValue	: true
        input(
            ,title			: "Door Control (open, close)"
           	,type			: "bool"
            ,defaultValue	: false
        input(
            ,title			: "Garge Door Control (open, close)"
           	,type			: "bool"
        input(
            ,title			: "Lock (lock, unlock)"
           	,type			: "bool"
        input(
            ,title			: "Delayed device turn off (optional)"
            ,type			: "enum"
            ,required		: false
            ,options		: [["5":"5 seconds"],["30":"30 seconds"],["60":"1 Minute"],["300":"5 Minutes"]]
        input(
           	title			: "Device outputs\nSend the events listed below."
            ,description	: null
           	,type			: "icon"
            ,required		: false
        d = "Contact"
        s1 = "open"
        s2 = "closed"
        input(
           	,title			: buildTitle(d,s1,s2)
           	,type			: "enum"
           	,options		: buildOptions(d,s1,s2)
           	,description	: contactOn ?: "Not Used"
		d = "Motion"
        s1 = "active"
        s2 = "inactive"
		input(
            ,type			: "enum"
            ,description	: motionOn ?: "Not Used"
        d = "Smoke"
        s1 = "detected"
        s2 = "clear"
		input(
            ,type			: "enum"
            ,description	: smokeOn ?: "Not Used"
        d = "Water"
        s1 = "wet"
        s2 = "dry"
		input(
            ,type			: "enum"
            ,description	: waterOn ?: "Not Used"
        d = "Sound"
        s1 = "detected"
        s2 = "not detected"
		input(
            ,type			: "enum"
            ,description	: soundOn ?: "Not Used, Tap to enable..."
        d = "Presence"
        s1 = "present"
        s2 = "not present"
		input(
            ,type			: "enum"
            ,description	: presenceOn ?: "Not Used"
        d = "Door"
        s1 = "open"
        s2 = "closed"
        input(
            ,type			: "enum"
            ,description	: doorOn ?: "Not Used"
        d = "Acceleration"
        s1 = "active"
        s2 = "inactive"
		input(
            ,type			: "enum"
            ,description	: accelOn ?: "Not Used"
        d = "Illuminance"
        s1 = "0 Lux"
        s2 = "50 Lux"
		input(
            ,type			: "enum"
            ,description	: luxOn ?: "Not Used"
  	simulator {
	// tile definitions
	tiles (scale:1) {
    	multiAttributeTile(name:"switch", type: "generic", width: 6, height: 2, canChangeIcon: true){
			tileAttribute ("device.uDTH", key: "PRIMARY_CONTROL") {
				attributeState "on", label: '${name}', action: "localOff", icon: "st.switches.switch.on", backgroundColor: "#53a7c0"
				attributeState "off", label: '${name}', action: "localOn", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
		standardTile("contact", "device.contact", inactiveLabel: false, height:2, width:2, canChangeIcon: false) {
        	state "default", label:"contact\nnot used" //, backgroundColor: "#ffffff"
            state "closed", label:'${name}', backgroundColor: "#ffffff", icon:"st.contact.contact.closed"
            state "open", label:'${name}', backgroundColor: "#53a7c0", icon:"st.contact.contact.open"
        standardTile("motion", "device.motion", inactiveLabel: false, height:2, width:2, canChangeIcon: false) {
            state "default", label: "motion\nnot used" //, icon:"st.motion.motion.inactive"
            state "inactive", label:'${name}', backgroundColor: "#ffffff", icon:"st.motion.motion.inactive"
            state "active", label:'${name}', backgroundColor: "#53a7c0", icon:"st.motion.motion.active"
        standardTile("smoke", "device.smoke", inactiveLabel: false, height:2, width:2, canChangeIcon: false) {
            state "default", label: "smoke\nnot used" //, icon:"st.alarm.smoke.clear"
            state "clear", label:'${name}', backgroundColor: "#ffffff", icon:"st.alarm.smoke.clear"
            state "detected", label:'${name}', backgroundColor: "#e86d13", icon:"st.alarm.smoke.smoke"
        standardTile("water", "device.water", inactiveLabel: false, height:2, width:2, canChangeIcon: false) {
            state "default", label: "water\nnot used" //, icon:"st.alarm.water.dry"
            state "dry", label:'${name}', backgroundColor: "#ffffff", icon:"st.alarm.water.dry"
            state "wet", label:'${name}', backgroundColor: "#53a7c0", icon:"st.alarm.water.wet"
        standardTile("sound", "device.sound", inactiveLabel: false, height:2, width:2, canChangeIcon: false) {
            state "default", label: "sound\nnot used" //, icon:"st.quirky.spotter.quirky-spotter-sound-off"
            state "not detected", label:'${name}', backgroundColor: "#ffffff", icon:"st.quirky.spotter.quirky-spotter-sound-off"
            state "detected", label:'${name}', backgroundColor: "#53a7c0", icon:"st.quirky.spotter.quirky-spotter-sound-on"
        standardTile("present", "device.presence", inactiveLabel: false, height:2, width:2, canChangeIcon: false) {
            state "default", label: "presence\nnot used"
            state "not present", label:'${name}', backgroundColor: "#ffffff", icon:"st.presence.tile.presence-default"
            state "present", label:'${name}', backgroundColor: "#53a7c0", icon:"st.presence.tile.presence-default"
        standardTile("door", "device.door", inactiveLabel: false, height:2, width:2, canChangeIcon: false) {
            state "default", label: "door\nnot used"
            state "closed", label:'${name}', backgroundColor: "#ffffff", icon:"st.doors.garage.garage-closed"
            state "open", label:'${name}', backgroundColor: "#53a7c0", icon:"st.doors.garage.garage-open"
        standardTile("accel", "device.acceleration", inactiveLabel: false, height:2, width:2, canChangeIcon: false) {
            state "default", label: "acceleration\nnot used"
            state "inactive", label:'${name}', backgroundColor: "#ffffff", icon:"st.motion.acceleration.inactive"
            state "active", label:'${name}', backgroundColor: "#53a7c0", icon:"st.motion.acceleration.active"
        standardTile("lux", "device.lux", inactiveLabel: false, height:2, width:2, canChangeIcon: false) {
            state "default", label: "illuminance\nnot used"
            state "dark", label:'${name}', backgroundColor: "#ffffff", icon:"st.illuminance.illuminance.dark"
            state "bright", label:'${name}', backgroundColor: "#ecf23a", icon:"st.illuminance.illuminance.bright"
        main(["switch"])
        details(["switch","contact","motion","smoke","water","sound","present","door","accel","lux"])
def open(){
	if (inDoorOn || inGDoorOn) localOn()
def close(){
	if (inDoorOn || inGDoorOn) localOff()
def lock(){
	if (inLockOn) localOn()
def unlock(){
	if (inLockOn) localOff()
def on(){
	if (inSwitchOn) localOn()
def off(){
	if (inSwitchOn) localOff()
def buildTitle(d,s1,s2){
	return "${d} (${s1}, ${s2})"
def buildOptions(d,s1,s2){
	def sOn = "on"
    def sOff = "off"
	def options = []
    options.add(["1":"when ${sOn} set ${d} to '${s1}'\nwhen ${sOff} set ${d} to '${s2}'"])
    options.add(["0":"when ${sOn} set ${d} to '${s2}'\nwhen ${sOff} set ${d} to '${s1}'"])
    options.add(["-1":"Not Used"])
	return options
def syncDevices(cmd){
	if (cmd == null) cmd = device.currentValue("uDTH") == "on" ? "1" : "0"
    //log.debug "cmd: ${cmd}"
	if (contactOn in ["0","1"]){
		if (contactOn == cmd) sendEvent(name: "contact", value: "open")			//"when on send 'open'\nwhen off send 'closed'"
        else sendEvent(name: "contact", value: "closed")						//"when on send 'closed'\nwhen off send 'open'"
    } else sendEvent(name: "contact", value: null, displayed	: false)
	if (motionOn in ["0","1"]){
		if (motionOn == cmd) sendEvent(name: "motion", value: "active")			//"when on send 'active'\nwhen off send 'inactive'"
        else sendEvent(name: "motion", value: "inactive")						//"when on send 'inactive'\nwhen off send 'active'"
    } else sendEvent(name: "motion", value: null, displayed	: false)
    if (smokeOn in ["0","1"]){
		if (smokeOn == cmd) sendEvent(name: "smoke", value: "detected")			//"when on send 'detected'\nwhen off send 'clear'"
        else sendEvent(name: "smoke", value: "clear")						//"when on send 'clear'\nwhen off send 'detected'"
    } else sendEvent(name: "smoke", value: null, displayed	: false)
    if (waterOn in ["0","1"]){
		if (waterOn == cmd) sendEvent(name: "water", value: "wet")			//"when on send 'wet'\nwhen off send 'dry'"
        else sendEvent(name: "water", value: "dry")						//"when on send 'dry'\nwhen off send 'wet'"
    } else sendEvent(name: "water", value: null, displayed	: false)
    if (soundOn in ["0","1"]){
		if (soundOn == cmd) sendEvent(name: "sound", value: "detected")			//"when on send 'detected'\nwhen off send 'not detected'"
        else sendEvent(name: "sound", value: "not detected")						//"when on send 'not detected'\nwhen off send 'detected'"
    } else sendEvent(name: "sound", value: null, displayed	: false)
	if (presenceOn in ["0","1"]){
		if (presenceOn == cmd) sendEvent(name: "presence", value: "present")		//"when on send 'present'\nwhen off send 'not present'"
        else sendEvent(name: "presence", value: "not present")					//"when on send 'not present'\nwhen off send 'present'"
    } else sendEvent(name: "presence", value: null, displayed	: false)
	if (doorOn in ["0","1"]){
		if (doorOn == cmd) sendEvent(name: "door", value: "open")			//"when on send 'active'\nwhen off send 'inactive'"
        else sendEvent(name: "door", value: "closed")						//"when on send 'inactive'\nwhen off send 'active'"
    } else sendEvent(name: "door", value: null, displayed	: false)
	if (accelOn in ["0","1"]){
		if (accelOn == cmd) sendEvent(name: "acceleration", value: "active")
        else sendEvent(name: "acceleration", value: "inactive")
    } else sendEvent(name: "acceleration", value: null, displayed	: false)
    if (luxOn in ["0","1"]){
    	if (luxOn == cmd){
        	sendEvent(name: "illuminance", value: 50)
        	sendEvent(name: "lux", value: "bright", displayed	: false)
        } else {
        	sendEvent(name: "illuminance", value: 0)
            sendEvent(name: "lux", value: "dark", displayed	: false)
    } else {
    	sendEvent(name: "illuminance", value: null, displayed	: false)
        sendEvent(name: "lux", value: null, displayed	: false)
def localOn() {
	if (device.currentValue("uDTH") != "on"){
    	log.info "on request: OK"
		sendEvent(name: "uDTH", value: "on" ,displayed: false)
    	syncDevices("1")
        if (autoOff) runIn(autoOff.toInteger(),localOff)
    } else {
    	log.info "on request: duplicate, ignored"
def localOff() {
	if (device.currentValue("uDTH") != "off"){
    	log.info "off request: OK"
		sendEvent(name: "uDTH", value: "off" ,displayed: false)
    	syncDevices("0")
    } else {
    	log.info "off request: duplicate, ignored"
def getVersion(){
	return "1.0.7"
//capture preference changes
def updated() {
	sendEvent( name: "version", value: getVersion(), displayed: false)
    //log.debug "syncDevices"
    syncDevices(null)
def configure() {
So I haven’t needed to use this thread or the handlers in a while since I’ve already got them installed but tried looking at the repo today and it’s gone. However I do notice there’s a repo for Hubitat. Did @Mike_Maxwell leave the SmartThings world? Not sure I understand why he couldn’t have at least left the repo in place. Disappointing.
Mike is one of the owners of Hubitat. It would make sense from a business standpoint that he would pull his code from a competing product.
Can anyone here add a wake/sleep sensor capability to this? (…or just create a virtual/simulated wake/sleep sensor?)
@Mike_Maxwell any plans on updating this for the new app so the devices don’t show offline?
For the reasons above it doesn’t look like there’s any more dev. activity on this otherwise brilliant DTH. That is, unless someone else decides to with it?
Could somebody add Vibration support for the Multipurpose Sensors?
… with mode and “Low battery warning indicator”.
Could you paste the app code also?
