Hi, I just bought a Foscam R2 camera.
Which features are available at the moment?
Do I get live streaming on this particular model? The St app can save clips if SHM detects intrusion?
I bought the fi9928p…Wow, what a camera!
I also just purchased your lifetime subscription. Looking forward to setting this all up. I just hope I can get it all working like I want it to but I’m confident I can now.
I am able to use video stream perfectly. But everything else failing with timeout error, taking a picture, arm/disarm. None of these working for me. Anything missing in configuration? Tried rebooting router, cameras but no luck.
Log shows.
b0f2653e-bfee-47c9-8fb0-0f4d3445450d 1:16:21 PM: warn Aysnc httpGet response has error: Failed to complete. Message was: connection timed out: /10X.X.X.XX:XXXX
b0f2653e-bfee-47c9-8fb0-0f4d3445450d 1:16:21 PM: error Error response from host 10X.X.X.XX:XXXX, HTTP Response code: null
b0f2653e-bfee-47c9-8fb0-0f4d3445450d 1:16:21 PM: trace Received response from camera to httpGet, headers=null, status=null
b0f2653e-bfee-47c9-8fb0-0f4d3445450d 1:16:21 PM: trace Received response from camera to async httpGet, headers=null, status=null, warning=[], data=[:]
ive a few JPT3815 tried this but didn’t work, so any help would be gret
How can i deactivate sound detection on my foscam R2? In the foscam app I have it off, also on this device handler I do not have it activated but I still get push notifications from smartthings detecting sound as for intrusion. I have the intrusion smartapp set to only record and take pictures when the main door sensor is activated (open/closed), motion and sound detection are off. What can I do to stop this?
I am looking for a way to set up my R2 so that it automatically turns on the motion and/or human detection when all of the predefined Presences are Away, and turn the detection off when at least one Presence arrives.
Any suggestions on how to best achieve that?
Foscam Camera and Motion Alarm Manager SmartApp does automatic discovery, installation and configuration of cameras. Please see this page for installation instructions.
Live video streaming can be accessed from inside and outside the home by using camera LAN IP address (discovered and configured automatically). If you’re having trouble connecting kill your SmartThings app and restart it.
I noticed that if I try to expand the image to full screen it will not rotate and really doesn’t gain any size. Is there a way to allow it to rotate. My phone is set to auto rotate. or is there a way to add pinch to zoom.
Agreed I have the same - no option to pinch zoom or rotate. Hopefully this will be fixed as my eyesight is not adequate to see otherwise.
I get a huge number of alarms despite having sensitivity set at “lowest”. Is there a way to stop this?
Samsung is releasing the new Smartthings (Samsung Connect) to replace the current Smartthings. I am wondering if this will affect the Foscam Camera!
Please send in a request to the ST support desk as these feature are implemented by the SmartThings mobile app and not the device handler. For e.g. rotation works with the iOS ST Mobile App but not the Android ST mobile app. Similarly for pinching and zooming it’s something ST would need to enable in their video tiles.
Will the DH and SmartApp work with Amcrest Cams? It does not discover them and have tried manually configuring and seems to see them, but when trying to view (says connected) it then says camera unavailable…anyone gotten this to work with Amcrest?
I just got a C1 and tried to use the Foscam Camera and Motion Alarm Manager. I already had 1 F9831P discovered with that app. The app discover both cameras but for the C1 shows “INCOMPLETE CONFIGURATION”, and it doesnt add the camera to Things. C1 its already setup with the Foscam app. I’m able to look at the livefeed from the app and from the web. Any idea what i could be missing? With the F9831 i didnt had this trouble.
my foscam FI9800P
active camera unavailable
How do I view the camera in smartthings?
When SmartThings is in “away” mode and motion is detected by the camera, where are the images sent/stored? Can I see either stills / videos in SmartThings or do I need an SD card to view the footage manually?
The mode doesnt’ matter.
Pictures can be stored in 2 different places depending upon how you’ve configured your settings:
Take picture
option in the Camera device settings (gear icon), then it’ll save a picture on your SD card or eMail it to you depending on how you’ve configured your camera through it’s own web interface/GUIYou can have both options enabled at the same time.
Strange. I’m using the Foscam smartapp but no picture shows in camera device page or events. If I take a picture using the smart app, that image does show up.
Hi, I’m using this Device Handler very successfully with quite a few foscam cameras but I’m struggling to configure my new FI9901, specifically the motion detection areas. The CGI command to return the getMotionDetectionConfig just returns a -3 error code. I know the motion detection area parameters need to be configured in the camera settings on ST but I can’t retrieve the current settings (set on the camera) via the CGI. Can you help?
-3 is access denied (from the logs):
Access denied. Make sure the Username you’ve entered has Administrative rights on the camera
