SmartThings Community
[RELEASE] Universal Enhanced Z-Wave Plus Lock Device Handler: Schlage, Yale, Kwikset, IDLock, DanaLock, August Pro, Samsung, Locstar, Delaney, KeyWe, Philia Locks and Popp Z-Wave Keypad with Alarm Control, Notification, RFID, Door Sensor
Back in Business, that worked with the new handler appreciate it.
I’ve had the @RBoy Lock DTH for a number of months and have upgraded each time by simply wiping out the old code in the IDE and then cutting and pasting in the new. I then save and publish for me. Then I go to ST, choose the lock, then the cog and save. I don’t believe I’ve had issues in the past. With the quoted procedure above, it appears that maybe I’ve been doing it incorrectly?
Nope, you haven’t been doing anything wrong. For the most part that has always worked for most people. I think moving forward and with all the additional enhancements that have been made recently (compatibility with Smart Locks, etc.), additional issues are possible and with the procedures Maddie posted, you will ensure an even more successful upgrade/update without some of the issues you have seen posted the last couple days.
You are simply switching your devices to the stock DTH while you perform your code updates to the SA/DTH, and then change the Type back to the Universal DTH after saving and publishing. This step replaces the need for opening the device in Things and saving from the gear icon. :slight_smile:
Thanks for the response. Although I understood the difference in the procedure, I didn’t understand the need for the change. I’ll keep an eye out for issues.
My raw data tile looks like this: zw:Fs type:4003 mfr:003B prod:6341 model:5044 ver:128.22 zwv:3.42 lib:06 cc:22,72,7A,98,86 sec:5D,85,20,80,70,62,71,63
All I show on the Right Now status is Lock/Unlock and a battery status two rows down. Should I reinstall the App and Device Handler in the IDE?
Exclude and repair for best results and update to the v04.00.02 code.
@RBoy was this update supposed to fix the main favorites page for unlocked and locked? I am still having the same issue, locks are unlocked, but main page still shows all locked.
Jason, read posts in other thread. This is a bug that @RBoy has submitted to ST.
Always wondered why there are two separate threads for the @RBoy Locks. One for Device Handler and one for the SmartApp itself. Hard to follow everything having to bounce back and forth between both topics.
Wouldn’t it be better to merge the two?
I under stand that, but in the post above for the update it says “update with patch for ST firmware bug” So is this the bug that was fixed or a different one.
I gotcha. Further up from Maddie’s post, I think that patch is related to this. Of course I could be wrong, but I think it applies to the following:
Submit a ticket to ST and mention that bug number that RBoy gave. The more traction it gets, the better and maybe quicker they resolve that annoying issue.
That’s the primary reason I have Smart Locks installed, just so I can view/monitor the status from the dashboard when I occasionally open the app.
Worked perfect. Thanks.
I think I just got a notification that the DM got updated to 4.0 or something?
Hi.
Do you know if your Universal Enhanced Z-Wave Lock Device Handler will work with the new IDLock model 150 and the new Z-Wave module?
The 150 z-wave module hasn’t been released as yet, the new 150 locks will be likely be shipping with the older 101 z-wave modules. So it should work fine.
Thx a lot m8! :slight_smile:
My Yale conexis L1 eat battery. 3 days drain 50% :tired_face:
DH 4.0 SA 6.00003
That type of drain only has a few reasons:
  1. Battery - make sure you’re using Alkaline or Lithium 1.5V and not NiMH/rechargeable batteries, also check if you have a bad battery
  2. Defective unit in which case contact Yale support to get a replacement. (Some Schlage locks are known to have defective firmware which cause higher than normal battery drain but that’s measured in months)
if use as stand alone the battery goes normal of cause cant get any information from ST
and i see the ST send deletecode command every min.
ps The new battery just remain 10% now (9:30AM) that installed @ sat ( around 6pm)
