SmartThings Community
[RELEASE] Universal Enhanced Z-Wave Lock, Schlage, Yale, Kwikset, IDLock, DanaLock, August Pro, Samsung, Locstar, Delaney, KeyWe, Philia Locks and Popp Z-Wave Keypad Device Handler with Alarm Control, Notification, RFID, Door Sensor and advanced features
smartapp_alerts
dth_locks
smartapp_security
smartapp_locks
rboyapps
(www.rboyapps.com - Make your home your butler!) #335
###Universal Enhanced Z-Wave Lock and Schlage Lock, Yale Lock and Kwikset Lock Device Handler - Version 2.9.0
  • Added support for external keypad button locked attribute outsideLockEvent
This allows the lock to report if the external lock button was pressed on the keypad and SmartApps to use that functionality to take actions. E.g.
(Fast, Good, Cheap...pick two.) #336
I don’t know about everyone else but this functionality is going to be huge for me!
(Fast, Good, Cheap...pick two.) #337
Instead of relying on the geofencing hokey pokey you now have both sides covered based of keying code or locking the door.
The only thing better would be to specialize by user.
(www.rboyapps.com - Make your home your butler!) #338
In the next version…
(David P.) #339
Its motion detection I believe based on the alarm being enabled. I don’t see it reporting motion otherwise but will test further tonight and respond back.
Further, I want to give props to RBoy on this app. It is great for code managemet which is not inherant in the default handler. I tried a couple of the other smartapps posted on here and they were hit and miss.
The ability to set the alarm for my schlage locks that have alarms, control sensitivity of the alarm, vacation mode as well as codes is huge.
I was even able to set it up so when a code is input and its after dark the inside light is turned on as well.
I was able to comment out the unlock code so “remote unlock” is not possible. Anyone interested in that as an alternate handler should message rboy to let him know.
(www.rboyapps.com - Make your home your butler!) #340
###Universal Enhanced Z-Wave Lock and Schlage Lock, Yale Lock and Kwikset Lock Device Handler - Version 2.10.2
  • Improved support for Yale locks, added ability to configure auto relock time and wrong entry tamper alert limits in the configuration page
  • Added support for Yale user code based locks
  • Added support for Yale external one touch lock
  • Fixed issue with base ST device handler sending tamper instead of invalid code alerts
This allows the lock to report if the external lock button or a code was used to lock via the keypad and SmartApps to use that functionality to take actions. E.g.
Thanks to @Horse3109 for his time and lock :slight_smile:
EDIT: 2.10.2 fixes a issue with 2.10.1 Yale locks’ not reporting code locks from the keypads correctly
[RELEASE] Lock User Unlock/Lock Door Notifications and Actions
[RELEASE] Lock User Management - Door lock code manager (create, delete and schedule codes) with automatic lock/unlock, custom user actions and SHM/ADT integration
(Dennis ) #341
after installing both the DH and SA i am getting constant code limit reached alarms when no one touching the lock.
#342
In order to replace my current device handler, do I need to import the code in and assign the handler to the device?
Also,once that is done I assume I will need to reconfigure all my codes again? Will those old codes just be wiped from the device?
(David P.) #343
You should just be able to replace the code for the current handler, save and publish
#344
All my settings and associated rules will continue to work?
(David P.) #345
I did the smartapp yesterday, no change. codes still there.
#346
Excellent. Thanks so much.
(www.rboyapps.com - Make your home your butler!) #347
You may need to reboot your lock, the DH is only reporting what the lock is sending it. PM me your IDE Live Logs,it’ll show what’s going on.
(Dennis ) #348
will reboot lock tonight but looking at the event list it does show it coming from the device.
(Zachary) #349
Hey Rboy, love your SmartApps and DHs. Is there any way to have them auto update? I hate having to constantly check the threads here, see an update, go to the site, enter login info, copy code, paste in IDE, etc EVERY TIME there is an update…
Thanks!
(www.rboyapps.com - Make your home your butler!) #350
Unfortunately ST hasn’t provided such a mechanism yet. I’ve requested them but no update yet.
For now just subscribe to our Facebook page and you’ll be notified of app and DH updates.
(Rafael D'Afonseca) #351
Hi there. Here are my things in place:
Schlage Connect Touchscreen Deadbolt with alarm
Smartthing Multipurpose sensor
Sensor is working fine. I can unlock and unlock the deadbolt from Smartthings app with no issue
I’m trying to relock the door automatically after closing/relock immediately but nothing happens. Any ideas
(Rafael D'Afonseca) #352
resetting the lock did the trick. It is working now…
(Fast, Good, Cheap...pick two.) #353
How did you reset? Did you pull the battery?
(Rafael D'Afonseca) #354
Yes, but I’m having issues again, minutes after the reset…
