SmartThings Community
[RELEASE] Universal Enhanced Z-Wave Lock, Schlage, Yale, Kwikset, IDLock, DanaLock, August Pro, Samsung, Locstar, Delaney, KeyWe, Philia Locks and Popp Z-Wave Keypad Device Handler with Alarm Control, Notification, RFID, Door Sensor and advanced features
smartapp_alerts
dth_locks
smartapp_security
smartapp_locks
rboyapps
(www.rboyapps.com - Make your home your butler!) #131
Added support for attribute ‘invalidCode’ to Schlage SmartDevice to report when too many invalid codes have been entered
E.g. of a SmartApp that uses this attribute
(Jim) #132
I installed the app and the custom device type a few days ago. My primary reason was to use temporary codes. I setup a one time code which was pushed to the lock and it worked. The code only worked one time, that is after the update delay, but still shows up in the list of codes in the app and is not flagged as being used or disabled. How am I supposed to know if the code was used? Am I missing something? Also, is there a way to see how many times a code was used?
(www.rboyapps.com - Make your home your butler!) #133
Keeping the app simple. Why do you need to know how many times a code is used?
(www.rboyapps.com - Make your home your butler!) #134
BTW you’re posting on the wrong thread, this is about the Schlage lock device type and that is about the code management app. Completely different.
(Fast, Good, Cheap...pick two.) #135
There is a learning curve there for us all. With ST selling to the general public now, let’s not assume everyone knows the difference between a device type and an app; therefore, know where to request features.
Instead of seemingly shaming someone in a public forum, just ask a moderator to move the post to the correct thread as it will be more friendly to your customer :smile:
(www.rboyapps.com - Make your home your butler!) #136
Agreed!, so the right place to post the comment would be this thread:
(www.rboyapps.com - Make your home your butler!) #137
Version 2.3.0
  • Added fix for non motorized deadbolt locks like FE599 not reporting locked after user unlocks the door using a code and it relocks automatically
FE599NX specific device type?
(Michael K) #138
thanks for the FE599 fix.
the first couple times i did it there was a ~3 minutes delay but i realized i was making changes to the smartapp at the time so it apparently waits to reprogram the lock before sending the locked status.
After the lock was all programmed it’s close to real time. I unlock with the pin and get the notification on my phone that the pin was entered and then immediately after get a notification that the lock re-locked electronically.
perfect!
(Fast, Good, Cheap...pick two.) #139
@RBoy
Your most recent code changes to this app have now (in my mind anyway) made this the “go to” app for door lock control in SmartThings.
There were obviously a lot of great features before, which is why I donated; however, now that you have pulled in open / close sensor integration and individual functions based off individual door unlock events, your code is both ultimately flexible and all encompassing.
You’ve put in a lot of hard work and it shows!
Thank you sir.
(Goose) #140
First off, RBoy has been awesome and very helpful and I love the app!
My lock is the Schlage Connect (FE469NX)
I’ve noticed since the last ST update, the lock is sometimes slow, or doesn’t even tell me via the ‘messages’ on the ST app if the door was locked or unlock or who used their code. Sometimes it works and registers, but sometimes it doesn’t. It worked fine on Thanksgiving day, as I’d show my family how it would respond and how I could unlock from my phone. As of today, it does not unlock/lock from my app, or its very slow in doing so (more like 10% chance it will work).
Now we did have power shut off during a storm after Thanksgiving (when the lock became worse and worse in responding), so I did the following:
Unplugged my STv2 Hub for 5 or so minutes and waited until steady green to do the following:
Removed/Reinstalled the lock app
Removed/Reinstalled lock from my Z Network
Now for today, I reinstalled the app with the newest version, and the codes were sent and all is well. When I used one of the codes, it worked, but ST did not see it as it happened. It just unlocked the door and the activity did not show that it was unlocked, and in which, did not tell me via SMS that it was unlocked.
I just tried it again after a few minutes since the last time I tried, and it worked and show me via the app and SMS. But I tried to unlock the door from the app and it did not work. If I manually lock it, it thinks its still unlocked. I have the Schlage lock to auto-lock after 15 seconds, I’m not using any App to do so, could that be the cause?
I know I rambled on, but I’m fairly new to all HA, and don’t know the best way to explain myself.
Thoughts?
(www.rboyapps.com - Make your home your butler!) #141
The most likely cause is the distance between your lock and hub is too far and it causing communication issues. Looks like you’ve covered the rest of the stuff. If you can’t move it closer then try to get a powered Z-Wave repeater device (like a Z-Wave power outlet) in between that will help the communications.
(Goose) #142
Copy that. It’s probably 50 feet away or so from the hub. Through walls too.
(www.rboyapps.com - Make your home your butler!) #143
Added a patch to the code to speed up first time install initialization of feature states.
(Goose) #144
Unsure where to put this update.
I installed the new app yesterday. Everything was great. The coded deleted yesterday at 5PM.
The code was not sent today at 8AM, didn’t try or anything.
Thoughts? Same issue for the past week. I resent all the codes again and it of course works, but even with the updated code, it still doesn’t send the code in the morning.
(www.rboyapps.com - Make your home your butler!) #145
This one belongs on the other thread Goose:
I had answered this questions yesterday in the above link / last 2 posts, please report it to the link I had posted on the above post. It’s due to the platform timers dying that ST is looking into.
Got this error tonight…what do now?
Oh No! Something Went Wrong!
Error
500: Internal Server Error
URI
/device/update
Reference Id
7b31795b-761d-4691-8e2d-a6d72065c74d
Date
Sun Dec 06 02:05:46 UTC 2015
(Benji) #147
I think the ST cloud is having some issues tonight.
(www.rboyapps.com - Make your home your butler!) #148
Please report it to support@smartthings.com otherwise they won’t know/fix it.
(www.rboyapps.com - Make your home your butler!) #149
On request from users, added code to expose capabilities for a Switch (on -> lock, off -> unlock). However this has been commented out to avoid confusion. You can un comment the code out to enable it. Look for the words “Dummy code”
(Tolik) #150
Just setup this device type. Was using Garyd9’s code previously
Couple of things…
  1. I’m not sure how or why but all my user codes got deleted… (my wife was not happy coming home =)
  2. Whats the point of having the icons for Lock/Unlock if the pressing on the green circle basically does the same thing.
  3. On my Note 5 you can see how the “code entry on” is overlapping the icon (not a big deal just pointing it out)
