[EDGE] Universal Enhanced Z-Wave Lock Driver for Schlage, Yale, Kwikset, IDLock, Popp, Danalock, August Pro, Keywe, Philia, Samsung
IMPORTANT: REQUIRED UPDATE FOR UPCOMING FIRMWARE 25.x for V2 and V3 hubs
This update is required to continue receiving lock/user usage notifications once ST deploys the 25.x firmware to the hubs (this update is backwards compatible with 24.x and older firmware)
Universal Enhanced Z-Wave Lock for Schlage, Yale, Kwikset, IDLock, DanaLock, August Pro, Samsung, Locstar, Delaney, KeyWe and Popp Z-Wave Keypad Device Handler - Version 04.03.01
  • Support for upcoming 25.x firmware z-wave framework user/lock notifications
  • Improved compatibility with SmartLocks
Schlage Lock Alarm Mode and Sensitivity Change and Monitor - Version 02.02.00
  • < no changes >
A SmartApp like Lock User Management (LUM) or SmartLocks is required for programming user codes.
To get real time updates with the Smart Locks dashboard refer to this post
This Device Handler has been tested and verified and optimized on the following lock models:
  • Yale Z-Wave locks (Assa Abloy, YRD2xx, YRD4xx, YRL2xx, YRC2xx, B1L, T1L, Keyfree, Assure, Conexis, Touchscreen, Deadbolt, RealLiving, nexTouch)
  • Schlage Z-Wave locks (FE469, BE469, BE468, FE599, BE369)
  • Kwikset Z-Wave locks (910, 912, 914, 916)
  • DanaLock Z-Wave locks (V2/V3)
  • August Pro Z-Wave locks
  • IDLock Z-Wave locks (101/150)
  • Samsung Z-Wave locks (SHP-xxx, SHS-xxx)
  • Delaney (ZWxxx)
  • Locstar Z-Wave locks
  • Monoprice Z-Wave locks
  • KeyWe Z-Wave locks
  • Popp Z-Wave keypad
Key features include automatic discovery of lock features:
  • Lock/Unlock
  • Privacy/keypad control
  • Autolock
  • Audio control
  • One touch/Lock n leave
  • Alarm mode
  • Alarm sensitivity
  • DPS/Door sense
  • Fire/smoke alarm
  • Tamper/motion alerts
  • Emergency alerts (police/fire)
  • Battery life optimization
  • Configuration of one time parameters
    • Yale -> relock timeout, wrong code reporting limit, volume level and dps
    • Danalock ->turn speed, brake n go, turn n go and relock timeout
    • IDLock -> volume level, unopened relock
  • Enhanced programming communication for a weak mesh
If you’re looking to capture specific events (e.g. invalid codes) and create custom actions/rules refer to this post.
Copyright © RBoy Apps
