[RELEASE] Universal Enhanced Z-Wave Lock Device Handler for Schlage, Yale, Kwikset, IDLock, Popp, Danalock, August Pro, Keywe, Philia, Samsung
Ignore that, I’ve just done a z-wave repair and it’s sorted it.
###Universal Enhanced Z-Wave Lock and Schlage Lock, Yale Lock, Kwikset Lock and IDLock Device Handler - Version 3.0.1
  • < no change >
###Schlage Lock Alarm Mode and Sensitivity Change and Monitor - Version 1.1.1
  • Workaround for ST bug with contact address book for notifications
###Universal Enhanced Z-Wave Lock and Schlage Lock, Yale Lock, Kwikset Lock and IDLock Device Handler - Version 3.0.2
  • Unsupported features for locks now show up as blank tiles to avoid confusion
  • < no change >
Since ST doesn’t allow dynamically adding, removing or re-positioning tiles, to make it easier for users, unsupported features for locks show up as blank tiles. When installing a new lock make sure you press the refresh button a few times to query the locks on it’s available features. As the locks start to respond/confirm feature availability the tiles will start showing up.
So here’s little summary of a comparison the Locks and features. Note that specific features depend on the models of the locks (e.g. Yale YRD 240 vs Keyfree or Schlage BE469 vs FE599 etc), this is just a quick reference for Z-Wave locks from these manufacturers not specific to any region but on an overall perspective based on available features across models:
###Universal Enhanced Z-Wave Lock and Schlage Lock, Yale Lock, Kwikset Lock and IDLock Device Handler - Version 3.0.3
  • Added a battery icon to make the UI look cleaner
  • < no change >
Hi, tonight I updated both
  1. Lock Multi User Management with Unlock Notifications, Advanced Scheduling and Automatic Lock/Unlock
    and
  2. User Unlock/Lock Door Notifications and Actions
    apps to the latest versions and carefully followed the instructions on your web site.
    One thing I noticed is that when I get notifications when User Slot 1 or User Slot 2 enters in the proper code to either lock or unlock my Schlage lock, both the alerts and text messages no longer tell the user that either unloocked or locked the door It just says “Front Door z-Wave Lock was locked electronically” Prior to these upgrades it used to say “Front Door Z-Way Lock was locked by James” since I have James defined as the user in user slot 2. I have James defined both of these apps.
Do you have any idea on how I can get the notifications and SMS messages (I enabled that) to indicate which user locked or unlocked the door? I triple checked my smart app config and don’t see what is missing. I wonder if this feature got dropped somehow???
This thread for the DH. I think you’re referring to the smart app.
Did you update your device handler also along with the apps. That’s
probably the likely reason you aren’t seeing it.
Any way to automatically be able to update the app if you have full access?
@RBoy Can you point me to a summary of your business model/how we purchase/how we upgrade? I see you making what seem to be pretty amazing software for ST and just want to understand you and the model a bit more. I’m sure you have a link or something somewhere :).
Thx.
Unfortunately there is no automated way offered by ST yet for DEV app stores.
You can find all the details at www.rboyapps.com
###Universal Enhanced Z-Wave Lock and Schlage Lock, Yale Lock, Kwikset Lock and IDLock Device Handler - Version 3.0.4
  • Added support for enabling/disabling beeper (audio) for Schlage FE599 and BE369 locks
  • < no change >
@RBoy I just paid you to get the Z-Wave smartapp. Please send me information ASAP.
Also - I noticed that the company name on Paypal is MCEBuddy…I used that in the golden days of Media Center! Before Vista changed their container to be DRM capable, your DVR-MS commercial stripper was FANTASTIC!!!
code MSR 003B-6341-5044.
I hope I found the solution to this code…
I restarted my Hub by removing a battery and unplug for 10 seconds. I think it worked…
This time around I did not do anythings else.
Hey,
RBoy, im using your app on my IDlock. ST can find the lock but everything else is not responding. in ST it always shows locked and when i push to unlock it doesnt respond even when the ST says it is.
you got any solutions?
Your lock isn’t communicating with the hub
  1. Check batteries on lock
  2. Reboot hub
  3. Repair z wave network
  4. Check distance from hub and use active repeater if necessary (> 20ft)
  5. Exclude and repair device
I just installed the device handler and this app. Very impressive!
I have it mostly working with my Schlage lever locks but I can’t seem to figure out a way to set it up to temporarily disarm my door sensor/alarm. I travel for work and often come home late at night. My SMH is armed automatically at 11pm. What i would like to do is have SMH set to disarmed when I enter my code at the lock, then re-arm automatically 2 minutes later. I just use door sensors to trip the alarm. Any tips on how to make this work? I know I could pull my phone out and do it manually but I might forget one night and wake up the whole family.
Using version 2.8.5, I had an odd unlock event, shown here in my logs:
What is “Alarm is” and “alarm mode” and why would it result in the door being unlocked? Why didn’t it report the code that it was supposedly unlocked with?
Alarm and alarm mode is ST polling the status of the lock. Has nothing to do with anything else.
Unlock is because the lock reported that it was unlocked with a code. It was initiated by the lock and for security reasons the details aren’t displayed on the screen.
###Universal Enhanced Z-Wave Lock and Schlage Lock, Yale Lock, Kwikset Lock and IDLock Device Handler - Version 3.0.5
  • Don’t show lock configuration status in “Recently” tab unless it has changed (to avoid confusion)
Hi, Just trying this device handler for the first time on my Yale Keyfree Connected Smart Lock (UK). However, the device does not detect when someone unlocks with an RFID tag. Is this a known issue. Works fine when they use a pincode.
Graham
