FYI when I change the Yale z-wave module to be the original type (had to get via ebay) rather than the new Z-wave 2 module things worked as expected.
I have 2 Yale YRD220 locks with the V1 ZWave module. I am having issues with current state and notifications in general. It last worked about 9 months ago. I reset lock to factory settings, Removed the Rboy App and DH. Rebooted smartthings and then set it all up again. Then recently I bought another YRD220 and zwave module hoping it would resolve the issue.
Below is breakdown of behaviour
Unlock from Keypay = Lock will unlock, but will not send a notification nor will the Lock Status change to unlocked
Unlock from ST App = Lock will unlock and status changes to unlocked, but after 180 seconds when autolock activates the lock will lock, but the status remains unlocked
Adding/changing users from the app = No issues here, just takes a little time to process
Rboy SmartApp version “07.06.06”
Rboy DH version 04.02.02
Yes I know they are a little out of date, but dont want to spend anymore money on this issue unless I know it will work as expected
I have also tried using the generic DH within ST Z-Wave with and without codes
Both locks are within 15ft of the smartthings
Anyone have any ideas what I could try
In live logging I noticed this, not sure if related
10d9f00a-ae24-4e65-b83a-6e057f84a117 13:30:04: warn Ignoring command from A Lock: NotificationReport(eventParametersLength: 0, eventParameter: , zensorNetSourceNodeId: 0, v1AlarmType: 22, reserved61: 0, notificationStatus: 0, sequence: false, event: 0, notificationType: 0, v1AlarmLevel: 1)
ST had made changes to the hub firmware which is why we work hard to keep the apps and DTH’s up to date with the environment. See this release. You should also consider adding a repeater close to your lock.
Thanks for that. Both seem to be working now. Just a little slow. Will give it time to settle down and do all its syncing.
Hi,
Total newbie at this, so please bear with me.
I have an Idlock 150. Installed the device handler (and the app) yesterday following the installation guide at the RBOY side, but I am having a struggle making it work. After enabling the code in IDE, the door locked by itself, and several sounds came from the lock. But, from the classic ST app, the only thing that actually works, is toggling audio. Battery status is also null.
What have I tried:
- Moving the ST hub practically next to the door.
- Z-wave repair
- Changing batteries.
I would really appreciate any assistance.
/depple
Hi there. If your lock is having trouble with the mesh, this may not help. On the contrary you will need to move the hub away and add a buffering device (like a repeater) close to your lock. See this topic for more details.
Suggestion for new feature… when I am modifying a user I would be interested to see a button that generates a new random code, with a desired number of digits, that I haven’t already used.
Unable to update the first post, so folks who’re looking for the app to configure the built in Schlage Alarm/Siren, see this topic:
RBoy Apps is now an officially approved partner for IDLock
Universal Enhanced Z-Wave/Plus Lock/Keypad Device Handler - Version 04.05.00
- Updated to support IDLock z-wave firmware 1.6
It helps to add a buffering device/repeater within 20ft of your lock for best performance
You need a SmartApp like Lock User Management (LUM) , Rental Lock Automater (RLA) or SmartLocks to program user codes, create actions for locking/unlocking/user codes and notify you.
Refer to the first post for more details and on how to enable Real Time Dashboard with SmartLocks
We have compiled a comparison of different lock model features on this link to get started with buying locks
NOTE: You should be on DTH version 04.03.00 or newer to be compatible with the new 25.x firmware for V2 and V3 hubs
Just purchased. I have Schlage touchscreen. When using Lock User Management and trying to add a user, I type a name , a code and done, it blanks out. I can’t create a user in any of the slots.
If I change a setting such as notify on use it blanks out what i typed. example logging after trying to add user 1.
4cca91b5-fa38-4066-b49a-6ceddb03699c 12:51:51 PM: debug Front Door Lock user 3 is empty, code already deleted
4cca91b5-fa38-4066-b49a-6ceddb03699c 12:51:51 PM: debug Front Door Lock user 2 is empty, code already deleted
4cca91b5-fa38-4066-b49a-6ceddb03699c 12:51:51 PM: debug Front Door Lock user 1 is empty, code already deleted
4cca91b5-fa38-4066-b49a-6ceddb03699c 12:51:51 PM: trace The date/time on the hub now is Sat Oct 19 2019 12:51 EDT
4cca91b5-fa38-4066-b49a-6ceddb03699c 12:51:51 PM: warn READ THIS BEFORE PROCCEDING: IT IS NORMAL TO SEE DEBUG MESSAGES EVERY MINUTE, IT CONFIRMS THAT THE APP IS HEALTHY AND RUNNING IN THE CLOUD. IT DOES NOT COMMUNICATE WITH THE LOCK UNLESS YOU SEE A MESSAGE BOX SAYING ‘REQUESTED LOCK TO XXXXX’.
4cca91b5-fa38-4066-b49a-6ceddb03699c 12:51:12 PM: trace Configured lock fixed code length: 4, max code length: null, min code length: null
4cca91b5-fa38-4066-b49a-6ceddb03699c 12:51:12 PM: trace Initial 1 Name: null, Code: null, Notify: null, NotifyModes: null, ExpireDate: null, ExpireTime: null, StartDate: null, StartTime: null, UserType: null
4cca91b5-fa38-4066-b49a-6ceddb03699c 12:51:12 PM: trace User Codes Page, user:1, name:null, passed params: [nextPage:userConfigPage, settings:[userType1:[name:userType1, value:Permanent, type:enum], userNames1:[name:userNames1, value:Rich, type:text], userCodes1:[name:userCodes1, value:9246, type:text], userNotifyModes1:[name:userNotifyModes1, value:, type:mode], userXNotifyPresence1:[name:userXNotifyPresence1, value:, type:capability.presenceSensor], userNotifyUseCount1:[name:userNotifyUseCount1, value:, type:number], userNotify1:[name:userNotify1, value:true, type:bool]], modes:, label:Lock User Management, params:[:]], saved params:[id:4cca91b5-fa38-4066-b49a-6ceddb03699c, name:userConfigPage, passed:true, user:1]
4cca91b5-fa38-4066-b49a-6ceddb03699c 12:51:12 PM: trace Passed from submitOnChange, atomicState lookup for user:1
Wrong topic but anyways it looks like an issue with the ST mobile app/platform (the smartapp takes what is passed to it by the ST mobile app). Basically the ST mobile app isn’t saving your inputs and your smartapp logs are showing the same, the user details are all empty.
Wait for a few hours and try again (ST was doing some maintenance this morning/most weekends) otherwise uninstall and reinstall the ST mobile app or try using the different version of the ST mobile app (Classic or new).
Uninstalled LUM and re-installed . All is well now. Thanks
Hey there! I was directed here from an old post that mentioned a $10 contribution. I’ve looked around the RBOY site, but wanted to double check - is the contribution to use the app now $39? Or am I not seeing another option?
I have an August lock and was just hoping to get the doorsense sensor integrated into my security home monitor. If the app is $39 now though, it seems more feasible to just buy another door sensor? Or is there another alternative?
Hi there,
I have a Danalock Zwave v3, does this DH have the possibility to change the timeout value on the autolock feature? Thanks
Yes you can adjust it from the device preferences page under t he Danalock section settings. See the first post for a full list of available features for different lock brand/models.
Sorry what i wanted to say was the AutoUnlock timeout value, that its impossible to change in the DanaLock app or the ST app. Thanks
Hi! Is august lock pro door open/close/ajar sensor working properly in the new app?
Universal Enhanced Z-Wave/Plus Lock/Keypad Device Handler - Version 04.06.00
- Updated device handler to display more capabilities in new ST app
- Locks with a built-in door open/close sensor (August Pro, Yale DPS, IDLock, KeyWe, Philia etc) is now a separate contact sensor device
- Improved support for IDLock
NOTE: For the new ST app to display the additional capabilities you will need to delete the device handler and reinstall it
by deleting, this means from the IDE side? and as opposed to just copying and pasting over the old device handler version?
RE: deleting the device handler -
In order to preserve any routines, automations, etc. connected with a lock, is it okay to assign a different device handler temporarily while deleting the RBoy one and saving the new v04.06.00 one?
