NOTE: You should be on version 04.03.00 or newer to be compatible with the new 25.x firmware for V2 and V3 hubs
Universal Enhanced Z-Wave Lock for Schlage, Yale, Kwikset, IDLock, DanaLock, August Pro, Samsung, Locstar, Delaney, KeyWe, Philia and Popp Z-Wave Keypad Device Handler - Version 04.03.08
- Added support for more KeyWe and Locstar models
- Added support for Phialia locks with door sensors
- Improved support for Yale Keyfree/Keyless models
- Improved compatibility with IDLock 101
- Alternative identification of lock model if lock has pairing has errors (missing NIF reporting all 0’s)
Schlage Lock Alarm Mode and Sensitivity Change and Monitor - Version 02.02.00
A SmartApp like Lock User Management (LUM) or SmartLocks is required for programming user codes.
This Device Handler has been tested and verified and optimized on the following lock models:
- Yale Z-Wave locks (Assa Abloy, YRD2xx, YRD4xx, YRL2xx, YRC2xx, B1L, T1L, Keyfree, Assure, Conexis, Touchscreen, Deadbolt, RealLiving, nexTouch) (DPS sensor)
- Schlage Z-Wave locks (FE469, BE469, BE468, FE599, BE369)
- Kwikset Z-Wave locks (910, 912, 914, 916)
- DanaLock Z-Wave locks (V2/V3)
- August Pro Z-Wave locks (door sensor)
- IDLock Z-Wave locks (101/150) (door sensor)
- Samsung Z-Wave locks (SHP-xxx, SHS-xxx)
- Delaney (ZWxxx)
- Locstar Z-Wave locks
- Monoprice Z-Wave locks
- KeyWe Z-Wave locks (door sensor)
- Philia Z-Wave locks (door sensor)
- Popp Z-Wave keypad
Key features include automatic discovery of lock features:
- Lock/Unlock
- Privacy/keypad control
- Autolock
- Audio control
- One touch/Lock n leave
- Alarm mode
- Alarm sensitivity
- DPS/Door sense
- Fire/smoke alarm
- Tamper/motion alerts
- Emergency alerts (police/fire)
- Battery life optimization
- Configuration of one time parameters
Yale -> relock timeout, wrong code reporting limit, volume level and dps
Danalock ->turn speed, brake n go, turn n go and relock timeout
IDLock -> volume level, unopened relock
- Enhanced programming communication for a weak mesh
- Handling of missing information while pairing locks
Tap the refresh button in the Classic ST app to query the locks capabilities and the supported tiles will show up.
You can find the installation instructions here.
If you’re looking to capture specific events (e.g. invalid codes) and create custom actions/rules in CoRE/WebCoRE refer to this post.
To enable real time updates with the Smart Locks dashboard
Change the name of the device handler in metadata section around line 152
from
name: “Universal Z-Wave Lock With Alarms”
to
Click Save
-> Publish
Copyright © RBoy Apps
