Never mind, I discovered that some of these groups were still attached to ActionTiles and Logitech Harmony (Connect). Once I cleared those connection the Trendsetter groups deleted fine. Thanks for pointing me in the right direction to lead me there.
Just installed everything via GitHub (what a cool thing that is!!) and I created my first group using 3 of Philipsâ new WiFi Connected by Wiz lights, and when I use the group switch thereâs like a 1/2 sec delay between each bulb turning on. Doesnât seem to be much faster than just hitting a virtual switch to control them. How do we get it as fast as the native âLighting Groupsâ? When I click on those they all turn on and off perfectly synced every time. But it doesnât seem to let you use those in automations??!! Totally new to all of this so maybe Iâm missing something?
I havenât kept up with the updates and just reinstalled everything as my setup stopped working recently. My problem is that my virtual dimmers are not dimming my group of lights. three bulbs paired with one virtual dimmer. The lights turn off and on fine with the virtual but when I dim the virtual nothing happens. Am I missing something?
Same problem happens to me since last night. Iâm wondering if itâs not a global ST issues since Dim With Me smartapp has the same issue: turn on/off fine, but wonât dim
do you get this error in your dimmer group log:
java.lang.NullPointerException: Cannot get property âvalueâ on null object @line 190 (setLevel)
If yes , try commenting the line 190 of the dimmer group device handler:
//sendEvent(name: âswitch.setLevelâ, value: val, rate: 0, isStateChange: true)
In the web IDE (where you added your smartapps code) https://graph.api.smartthings.com/
You have a tab named Live Logging at the top of the page. Go there and try to dim your virtual dimmer from the phone app. You should see the commands logged in real time.
Why are my grouped bulbs not coming on together at the same time? They just come on one at a time, the same way they do if theyâre turned on normally with smartthings.
I thought that was one of the main points of this smart app? And If thatâs the case, then how do they turn on and off perfectly synced using the native âLighting Groupsâ?
Perhaps I am wrong. I may be thinking about when you do this via webCoRE as even using ASYNC commands it still runs sequentially. I just know those lamps I have controlled with Trend Setter have always turned on in sequence. Itâs very quick (like ms gaps) but definitely not all at the same time.
Mineâs more like .5-1 sec in between each bulb in the group. But when switched on/off using the stâs native âLighting Groupsâ theyâre perfectly synced. Why canât we use that in automations??
Someone did but I donât have Hubitat to test it on or the time if Iâm honest.
Looking at the code, I canât see why it would be doing this, the error doesnât seem to give much detail, sorry
Iâm afraid the SmartApp is at the mercy of however the SmartThings platform decides to run the commands on the devices in the group. Because TrendSetter doesnât run locally thereâs always a chance of delays as itâs running in the cloud and then sending the commands to your hub. It isnât this slow for everyone so Iâm afraid I canât be sure what the reasons for the delay would be.
Dimming Issue
Iâve noticed this is happening to me as well, Iâve updated the repository with a fix. SmartThings decided to deprecate something I think.
To clarify, when I said 1/2 sec delay between bulbs, I mean if there are 8 bulbs in a group, then one bulb turns on, then 1/2 sec later the 2nd bulb, followed by the next 1/2 sec later⊠so on until theyâre all on. So for 8 bulbs it takes approximately 4-5 seconds of watching them light up one at a time. Arenât they all supposed to at least try to come on at the same time? Isnât that one of the main things this smart app is supposed to do? Do you think it could be the fact that Iâm using WiFi bulbs (new Philips WiFi Wiz ones)? I donât believe my Samsung SmartThings bulbs I have installed have the same delay now that I think of itâŠ
I donât know exactly how SmartThings sends the commands to the devices, all I can tell you is that TrendSetter sends them in one go without any delay, whether they get looped over underneath I donât know. Itâs possible that SmartThings handles WiFi connected devices differently
thats not a fix but a klugd now you are not setting the level of gthe bulb correctly⊠someone needs to figure out what smarthings broke⊠ihave the same issue in all my device types that set a dimming level
