[RELEASE] Thermostat Manager - An alternative to Thermostat Mode Director
Releasing an app I developed for myself called, Thermostat Manager. Thermostat Manager is similar to and could be considered an alternative to, Thermostat Mode Director.
Why: Originally, I went with Thermostat Mode Director which was available from within the SmartThings app. But over time I found Thermostat Mode Director to be buggy and unreliable.
What’s the Same:
• Mode Adjusting: Thermostat Manager will change the mode (heat to cool, cool to heat) of your thermostat based on user-defined thresholds in a similar manner as Thermostat Mode Director. Originally I was hoping to have this app set modes based on the setPoints that you set on your thermostat. You know, the values that you set on the thermostat itself and can also set in your Hello Home, “I’m Home” functions? But at least in my case, I discovered that the thermostat only remembers the setPoint for the mode it is currently in. I have a Zen for those interested, but this app will be fine for about any thermostat. Anyway, I ended up having to go with the same model that Thermostat Mode Director uses. You set upper and lower limits. BTW, Thermostat Manager is NOT a rework of Thermostat Mode Director. I’ve seen a couple of these in the forums and they don’t ever seem to be any good.
• Notifications: Thermostat Manager has text notifications that are similar to Thermostat Mode Director’s but the content of Thermostat Manager’s notifications is more dynamic. Also, they only occur if the user enables them and then they are only sent if a command is sent to the thermostat (change in mode/temperature, etc.). Thermostat Manager also adds optional push notifications.
• Can Use Remote Temperature Sensors: Although I generally recommend using your thermostat as your temperature sensor, there are unusual situations in which you may benefit from using a remote temperature sensor. Users can select any temperature reporting device and use it to base Thermostat Manager’s decisions on (such as mode changes). Please note that the thermostat still uses its own internal thermometer to decide when to start blowing air. This feature will work in the same manner as it does in Thermostat Mode Director.
What’s Different:
• User Friendly: I designed my app to be more readable, with help tips on settings that aren’t self-explanatory.
• Completely Configurable: It is chock full of options. There’s an enable/disable slider for every capability so that you don’t have to de-configure it in order to disable it temporarily.
• Optional Smart Home Monitor based setPoint Enforcement: Thermostat Manager adds the capability to enforce thermostat setPoints based on Smart Home Monitor security modes. Generally I find it annoying when an app tries to override manual settings but I discovered that some situations can occur where the thermostat will change modes to a setPoint that was set a long time ago that doesn’t fit what we want currently. If this happens when you’re not home, it could be a problem for your pets or your electronics. So I made my system minimally invasive. It will only enforce the setPoints if, “Smart Home Monitor Based SetPoint Enforcement” is configured and enabled and then only if there is a mode change (cool to heat, heat to cool).
• The energy saving, turn-off-the-thermostat-when-the-doors-are-open thing in this app actually works. And it’s also completely optional. It has the same configuration as Thermostat Mode Director but, this one will actually work if you use it. And when you close the doors, the thermostat will pop back on and set the mode it is was in before the thermostat was turned off.
• Bonus: I have a particular family member who likes to go to the thermostat and change the fan mode from, “auto” to, “on”. If I don’t notice this, a lot of energy (money) can be wasted. Therefore, I built in an optional slider that enforces fan mode auto on the thermostat. In case you have any wacky household members like me.
What’s New:
• By request, I’ve added the ability to override Thermostat Manager by manually setting the thermostat to “off” mode. If the, “Allow Manual Thermostat Off to Override Thermostat Manager” slider is enabled, Thermostat Manager will essentially be disabled when someone manually turns off the thermostat. Temperature changes will be ignored and modes and setPoints will not be set. If you prefer that Thermostat Manager re-enable cooling or heating mode when someone manually turns off the thermostat (and the temperature rises or falls below one of the manually configured thresholds), then leave the slider in disabled mode.
• By request, I’ve added the option to use emergency heat mode in place of heat mode. If you would like to do this, go to the, “Emergency Heat Settings” page and enable the, “Always Use Emergency Heat Mode Instead of Heat Mode” slider. This may come in handy if your HVAC unit is malfunctioning.
• By request, I’ve added the ability to enable emergency heat based on the temperature reading of an external temperature sensor. These settings can be found in the, “Emergency Heat Settings”. Thermostat Manager users who live in cold areas had complained that it takes too long to wait for the thermostat to enable emergency heat by itself based on the thermostat’s internal temperature readings.
• By request, I’ve added an optional, “hold-down timer” for the Energy Saver system. If specified or set to a value other than zero, Energy Saver will now pause for a user specified minimum number of minutes before being allowed to turn the thermostat back on after all of the doors are closed. The setting has a default value. If you do not wish to use it, just set it to 0. These settings can be found under the Energy Saver settings page.
• TM now has the ability to enforce temperature setpoints. This means that if this ability is enabled, even if someone manually changes the temperature TM will change it back to the setpoint you have specified in TM.
• As many have requested, I’ve added in an optional a “hold-after” timer option to the Energy Saver feature. If set, the hold-after timer will hold the thermostat in a paused status for a specified number of minutes after all contacts have been closed. This timer works in conjunction with the hold-down timer which is configured using the setting, “Minimum Pause Time”. If both are set, TM will use whichever timer takes the longest to complete.
• I finally decided to add the ability to use a remote temperature sensor. Using the thermostat as your temperature sensor is recommended for most situations, however, I have found some unusual cases in which it can be useful to have a remote temperature sensor (albeit one that is not fully functional). As I have mentioned before, ‘Unless you have an Ecobee, the thermostat uses its own internal thermometer to control the HVAC unit. Even if we manually set the mode to, “heat” for example, the heat won’t kick on unless the thermostat’s internal thermometer says that it is below the thermostat’s heating setPoint.’ That having been said, there are situations in which one may want to have the modes controlled by a remote temperature sensor even though the HVAC won’t kick on until the thermostat’s internal thermometer has reached configured setpoints on its own.
Future Additions:
• I’ve had a request to add support for multiple thermostats. This will be done but it requires some in-depth changes and it may be a while until it gets added. Until then, there is no problem running multiple instances of Thermostat Manager.
I always perform my own testing before I publish a new version, but I also rely on you to report any problems. Please let me know if you notice that anything isn’t working right. Feel free to make further recommendations for changes or additions as I continue working to perfect Thermostat Manager.
Enjoy!
To Install Thermostat Manager Smart App:
  1. Login to the SmartThings IDE.
  2. Click on My SmartApps.
  3. Click the New SmartApp button.
  4. Select the From Code tab.
  5. Copy all of the code from the thermostat-manager.groovy file into the box.
  6. Click Create.
  7. Click Save.
  8. Click Publish and choose For Me.
Hey Jordan, Thanks for creating this app.
I seem to be having trouble with the app actually turning OFF the thermostat after door is left open for 1 min.
I receive the text stating “Therm Manager will shut thermos off” but therm keeps running. I have a Honeywell WIFI therm if that helps.
I can control the therm from Smartthings App with no issues.
Also how can I look in the debugging log? I turned on that option in the app.
Thanks.
Hi Jordon,
Lots of good things in your app. Here’s what I’m trying to do… (AZ electric rate structure quadruples between 3 pm and 8 pm)
8 pm to 3pm heat/ ac runs
3pm to 8 pm off
If any of 4 doors with sensors is open for more than 1 minute, heat/ac off. When all 4 doors are closed, heat/ac turn back on.
Because I don’t see time of day on your temp settings, I used thermostat mode manager to set the temps. I tried thermostat manager to shut off/on for doors open and closed (no temp set).
Thermostat manager shuts off when the door opens but does not turn it back on when it’s closed.
Do you have any suggestions?
nexxman, To access the debugging log, access the SmartThings IDE at https://account.smartthings.com/
Then click on the, “Live Logging” link at the top of the page.
I’ll take a look at the Honeywell system and see if there are any issues that might cause this to happen. In the meantime, I suggest trying changing the minutes left open to 2 minutes instead of 1 minute, just as a test. Let me know if you have any luck with that. If you do, I’ll know what code to look at.
Spurkat, that’s an interesting problem. I’ll look at incorporating time of day settings into the app…
1st, try turning on debug logging and perform the test again. What mode does the debug log say that your thermostat is in? Is it something other than, “heat” or “cool”? Maybe it says, “Thermostat Manager - Mode: auto?” When you close the doors, you should see something in the logs like, “Thermostat Manager - All contacts have been closed. Restoring cooling mode.”. If you see that log entry, but the thermostat isn’t coming on that’ll help me figure it out.
What kind of thermostat are you using?
EDIT: I may have guessed your problem. You are using Thermostat Manager in conjunction with Thermostat Mode Director, right? Thermostat Mode Director likes to set, “auto” mode sometimes. Thermostat Manager tends to ignore that mode because it is somewhat ambiguous and its behavior varies from device to device. Thinking of this exposed a loophole in my design that I didn’t intend. I have just patched this and uploaded an updated source code that should take care of this possibility should it arise. Give the new code a try and let me know if that solves your issue. If not, try the suggestions above and let me know how it goes.
Dear
I installed the smartapp and I also see problem when the device needs to switch off because of open door/ window. The termostat I use is Daikin Wifi:
No command is sent to the thermostat. Until now I have been using built in routines to switch on/off or change setpoint and it works OK, so according me the Daikin DTH works
Here is the log from Thermostat manager:
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:58:25: debug Thermostat Manager standing by.
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:58:25: debug Thermostat Manager - Temperature: 22.5
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:58:25: debug Thermostat Manager - Cooling Setpoint: 28 | Heating Setpoint: 22.0
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:58:25: debug Thermostat Manager - Mode: heat
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:58:25: debug Thermostat Manager - Fan Mode: auto
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:58:25: debug Thermostat Manager - Hello Home Mode: Home
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:58:25: debug Thermostat Manager - Smart Home Monitor Status: off
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:58:25: debug Thermostat Manager - At least one contact is open: null
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:58:01: error groovy.lang.MissingMethodException: No signature of method: script_app_Thermostat_c8b78d6a_c9a3_4de7_a006_b9ba4611c5ff_ver_0_1.sendpush() is applicable for argument types: (java.lang.String) values: [Thermostat Manager is turning the thermostat off temporarily due to an open contact.]
Possible solutions: sendPush(java.lang.String), sendPush(java.lang.String, java.util.Map), sendSms(java.lang.String, java.lang.String), input(java.lang.String), sendSms(java.lang.String, java.lang.String, java.util.Map) @line 300 (logNNotify)
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:58:01: info Thermostat Manager is turning the thermostat off temporarily due to an open contact.
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:56:01: debug Thermostat Manager - A contact has been opened. Initiating countdown to thermostat pause.
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:55:25: debug Thermostat Manager standing by.
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:55:25: debug Thermostat Manager - Temperature: 23.0
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:55:25: debug Thermostat Manager - Cooling Setpoint: 28 | Heating Setpoint: 22.0
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:55:25: debug Thermostat Manager - Mode: heat
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:55:25: debug Thermostat Manager - Fan Mode: auto
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:55:25: debug Thermostat Manager - Hello Home Mode: Home
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:55:25: debug Thermostat Manager - Smart Home Monitor Status: off
d4b32df4-8018-414a-a1f6-be5bae0ca47f 19:55:25: debug Thermostat Manager - At least one contact is open: null
Below is the log from the airco
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:58:26: debug Executing ‘updateEvents’ with heat, 22.0 and false
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:58:25: debug Parsing Response: [ret:OK, pow:1, f_rate:A, dfrh:5, dfd7:0, dfd6:0, b_f_rate:A, b_shum:0, dfd3:0, dfd2:0, shum:0, dfd5:0, f_dir:0, dfd4:0, b_f_dir:0, mode:4, dfd1:0, stemp:22.0, dfdh:0, b_stemp:22.0, adv:, dh7:AUTO, dh4:0, dh5:0, alert:255, dt1:25.0, dt2:M, dt3:25.0, b_mode:4, dt4:22.0, dt5:22.0, dt7:25.0, dhh:50, dfr4:A, dfr5:A, dfr6:5, dfr7:5, dh3:0, dfr1:5, dh2:50, dfr2:5, dh1:AUTO, dfr3:5]
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:58:25: debug Parsing Response: [ret:OK, err:0, otemp:7.0, htemp:22.5, cmpfreq:30, hhum:-]
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:58:25: debug Executing hubaction on 192.168.1.241:80/aircon/get_control_info
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:58:25: debug Delay for ‘500’
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:58:25: debug Executing hubaction on 192.168.1.241:80/aircon/get_sensor_info
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:58:25: debug Refreshing
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:57:25: debug Executing ‘updateEvents’ with heat, 22.0 and false
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:57:25: debug Parsing Response: [ret:OK, pow:1, f_rate:A, dfrh:5, dfd7:0, dfd6:0, b_f_rate:A, b_shum:0, dfd3:0, dfd2:0, shum:0, dfd5:0, f_dir:0, dfd4:0, b_f_dir:0, mode:4, dfd1:0, stemp:22.0, dfdh:0, b_stemp:22.0, adv:, dh7:AUTO, dh4:0, dh5:0, alert:255, dt1:25.0, dt2:M, dt3:25.0, b_mode:4, dt4:22.0, dt5:22.0, dt7:25.0, dhh:50, dfr4:A, dfr5:A, dfr6:5, dfr7:5, dh3:0, dfr1:5, dh2:50, dfr2:5, dh1:AUTO, dfr3:5]
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:57:25: debug Parsing Response: [ret:OK, err:0, otemp:7.0, htemp:23.0, cmpfreq:30, hhum:-]
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:57:25: debug Executing hubaction on 192.168.1.241:80/aircon/get_control_info
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:57:25: debug Delay for ‘500’
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:57:25: debug Executing hubaction on 192.168.1.241:80/aircon/get_sensor_info
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:57:25: debug Refreshing
c4751f06-9e5a-4dec-adad-ded6962ccfce 19:56:25: debug Executing ‘updateEvents’ with heat, 22.0 and false
D_Gjorgjievski, thank you! And thank you for posting the logs. It appears that you’ve discovered a typo in my code that was causing a problem to happen. I have corrected the code and you shouldn’t have any problems now. Let me know if I can be of further assistance.
Dear Jordan
Thanks, great app
It seems it works now. I have tested it in one room and it was OK.
I have some suggestions for improvements:
  1. The Thermostat Manager disable functionality: it would be nice if I could link virtual switch to it so as in my case where I have 9 thermostats I can disable the manager with one click.
  2. Setting setpoints per mode: my alarm is interfaced to the smartthings so I can use the functionality that you already built in the smart app, but it doesn’t cover all situations. For example if there is nobody home the heating is set to bit lower temperature than normally, but when I am on holiday I would decrease the set-point even lower than that
  3. Include delay for starting on the thermostat. Sometimes you (or maybe draft/wind) may close a door for a short time and open it again and that will prevent starting the unit too often
  4. Possibility to override the temperature set-point manually (I am no sure if this is possible, but sometimes can be useful)
Would be great if you can include some of the above suggestions
Greetings
D_Gjorgjievski,
Hello again. Make sure you’re using the latest revision. I also changed something else in the app. In particular the build number is 2018040102 and line 218 should look like this:
def openContact = contact?.currentValue("contact")?.contains("open")
I’ll take a look at some of your suggestions. The toggle widget isn’t a bad idea. As far as further setpoint settings, I am looking at making some enhancements in this area but there are so many situations that people have, it is difficult to come up with one that suits everyone. But I will continue to work on it. On #3, I should be able to do this with little difficulty, I’ll take a look at it. On number 4, this may be already possible, depending on your meaning. If you don’t want any thermostat mode changes to occur, just set your thresholds to zero, “0”. If you set it at zero, that particular threshold will be ignored and heat/cool will not be set based on it. If you’re talking about overriding the thermostat temperature by setting the temperature manually, you can already do this as well. The setpoints are only set when a thermostat mode change takes place. Cool to heat, heat to cool etc. The reason it works like this is because I wanted to be able to maintain manual functionality as much as possible, but I also discovered that sometimes when a mode change occurs, unusual things can happen. For example, say during winter you have your thermostat set to 65F for heating, 79 for cooling (while not home for example). But then summer comes around and to save money you want it set at 73 for cooling. Well when the mode change occurs (while you aren’t home), it takes the value that you set it at last, which could have been months ago. If this is a house that you only reside at 6 months out of the year, or you are on vacation and are not home, this could be a problem. Your electronics may overheat or any animals in the house may end up getting very hot (at 79F). It’s a bit of a safeguard. It is possible to disable these by disabling setpoint enforcement however. Another alternative is to experiment with mode rules. At the bottom of the settings, you will see options for, “set for specific mode(s)”. You could try creating various instances for various modes. Thanks your thoughts. I am always open to input and will continue looking at expanding flexibility.
Dear Jordan
I already have installed the last version and I already tested that the energy saver mode is working (I connected to your github repository).
If I correctly understand you, the setpoints will only change if the thermostat mode is changed(heat to cool) or if the alarm changes state. In the meantime I could manually or via other routine/smartapp modify the set-point without the smart app setting it back. That is great and that is what I wanted.
The “Holiday” set-point can also be covered if I change the mode to Holiday and disable the manager for the holiday mode, or alternatively if you decide to implement the manager disable functionality, I could set a a virtual switch to disable the manager and then set the set-points via some other app/routine.
I think that the On delay will be useful to have but on the other hand it is also something I can also live without
Great job in any case
Greetings
Dear Jordan
I just realised that the setpoint is not sent when the alarm status is changed. Can you please include this functionality?
You can update the set-points only when the alarm armed status is changed and it will still keep the functionality to manually override the manager.
Additionally I was thinking that it is not bad idea in energy saver mode to have an option to set the heating/cooling thermostat setpoint to the outside temperature in order to avoid too often start/stop of the unit which will increase the reliability of the airco system i general. Things fail most often during switching them on.
thanks for taking this in consideration
D_Gjorgjievski, have you tried using the, “Hello Home” (I’m Back, Goodbye, etc.) tiles to set the temperature/security mode? That’s what most people do. They are more convenient because you can set multiple settings with one button. You can also make widgets out of them.
Yes, I currently use the routines you describe, but I looked for single smartapp that will integrate all functions for the airco. I have 9 units at this moment (and 3 more to come), so it is quite messy knowing I have several smartapps for one unit and also prone to errors.
I might also modify your code for the functions I need as soon I have more time. It is a very good starting point for what I need.
Greeetings
Darko
Hi JMark,
I actually changed the timing to 3 mins but that did not work either. Let me know if I should try anything else.
BTW I do recieve the text notification stating Therm Manager is going to shutoff the therm so I know that part works.
Really would like to get this to work. Wife keeps forgetting patio door open when dog goes out. (-; TIA
nexxman,
I took a look at the Honeywell Wifi code and didn’t see anything that should cause a problem. I recently released a new version of Thermostat Manager that has a couple of fixes in it. Make sure you are using the latest revision (2018040102) just in case this may solve your problem. Did you see anything in the debug logs? If you haven’t done it yet, just turn on debug logging, log into the SmartThings IDE, click on, “Live Logging” and then run a test by opening and closing some doors over a period of minutes. Copy and paste the logs here and that will help me find the problem.
Awesome work Sir! Work flawlessly
Turns therm off then turns back on after door is closed.
Thanks very much!
Hi, clueless newbie alert. I’m just getting started with SmartThings and home automation in general.
I’ve got the ST V1 hub. My HVAC system has three Honeywell WiFi thermostats for a single system with baffles to direct air to three zones. The thermostats are defined and working in both the “classic” SmartThings Android app and the “new” SmartThings app.
Things I’d like to do are:
  1. Swap between heating and cooling mode on all three thermostats with one tap (currently have to go thru several taps for each thermostat individually).
  2. Use the external temperature to automatically change between heating and cooling mode.
I think the thermostats retain separate heating and cooling setpoints as well as schedules.
I’ve got the Thermostat Manager SmartApp installed and need to make sure I’m setting it up correctly.
Do I have to create an instance of the app for each thermostat? I don’t see any way to select multiple thermostats for one instance of the app.
How do I create … something … that will react to external temperature? Is that what the “Cooling Threshold” and “Heating Threshold” settings do or are those inside temperatures as reported by the thermostats?
Thanks for any help,
–Hal
Hi Jordan,
I have a 2-stage heating system and 4 modes: OFF, COOL, HEAT, and EMERG HEAT. I was wondering if there is an option (or could there be an option) to have the Thermostat Manager switch the thermostat from HEAT to EMERG HEAT when the outside air temperature (as measured either from an outdoor sensor or from the cloud) was below 30 degrees or some selectable setpoint? This would prevent my system from constantly turning on the HEAT PUMP first and then switching over to EMERG HEAT when it figures out it needs it. I’m not sure what algorithm it uses, but it’s annoying when the temperature gets really cold and I usually just manually switch the system to EMERG HEAT to avoid the cycling.
Currently, yes. I only have a single thermostat home with which to perform testing and I generally don’t like to implement anything that I can’t test. It is not a difficult thing to setup multiple instances, but if you would like to use the same settings for the 3 thermostats, I could work with you to modify the system to allow for multiple thermostats. If you could do the testing for me and report back the results, I’d be willing to make the modifications.
Cooling and heating thresholds are user defined variables that define when Thermostat Manager will send a command to the thermostat to switch modes. For example, a cooling threshold of 76F will tell Thermostat Manager to send a command to your thermostat to switch it into cooling mode (if it is not in cooling mode already) so that it will start cooling your house at a temperature above 76F. A heating threshold of 68F will tell Thermostat Manager to switch to heating mode if the temperature falls below 68F.
The short answer is, you can’t. That is unless the thermostat you have came with a system that includes remote sensors like an Ecobee, or your thermostat allows you use other thermostats as remote sensors. The reason for this is that although we may have something like a SmartThings temperature sensor readily available for reporting the temperature in a given area, your thermostat uses its own internal thermometer to decide whether or not to activate. For example, you could have an outside sensor report that it is 90F outside and then have an app tell the thermostat to switch to cool mode based on that report. But the thermostat’s internal thermometer will read the temperature of its own area, in this case let’s say its 75F. If your cooling setpoint is 76F, the AC won’t kick on because the thermostat’s internal thermometer says that it doesn’t need to. It will be set to cooling mode as instructed by the app, but the AC won’t kick on. The only way around this would be to use an app that automatically adjusts the cooling and heating setpoints in order to make the unit kick on when you want it to. Thermostat Manager wasn’t designed to work like this and so I won’t be implementing this feature but, SmartThings already has an app in their library that does this, called, “Keep Me Cozy” if I remember right. And you should be able to use it in combination with Thermostat Manager.
An alternative method to achieve #1 on your wish list may be to simply use a SmartThings tile. You should be able to create a simple button that sets all 3 thermometers relatively easily using this method. But if you do want to add the capability for Thermostat Manager to control multiple thermostats, let me know and I’ll work with you on that.
Thermostat Manager does not currently have this functionality, but something like this is possible. I would not be able to test this modification myself as I do not have a unit that has an emergency heat mode, but I would be willing to make these modifications if you wouldn’t mind testing them and reporting the results to me. This seems like a desirable feature.
© 2019 SmartThings, Inc. All Rights Reserved. Terms of Use | Privacy Policy
SmartThings; SmartApps®; Physical Graph; Hello, Home; and Hello, Smart Home are all trademarks of the SmartThings, Inc.
