Sean,
The Arduino UNO’s 2KB of RAM and 32KB of flash are really limiting, especially when using the W5100 shield as the Ethernet Library takes up a lot of space.
Here is a sample sketch which does compile successfully, but it only has a few devices enabled:
// File: ST_Anything_Multiples_EthernetW5100.ino
// Authors: Dan G Ogorchock & Daniel J Ogorchock (Father and Son)
// Summary: This Arduino Sketch, along with the ST_Anything library and the revised SmartThings
// library, demonstrates the ability of one Arduino + Ethernet W5100 Shield to
// implement a multi input/output custom device for integration into SmartThings.
// The ST_Anything library takes care of all of the work to schedule device updates
// as well as all communications with the Ethernet W5100 Shield.
// ST_Anything_Multiples implements the following ST Capabilities in multiples of 2 as a demo of what is possible with a single Arduino
// - 2 x Door Control devices (used typically for Garage Doors - input pin (contact sensor) and output pin (relay switch)
// The following are all commented out in the code below, but left as an example
// - 2 x Contact Sensor devices (used to monitor magnetic door sensors)
// - 2 x Switch devices (used to turn on a digital output (e.g. LED, relay, etc...)
// - 2 x Water Sensor devices (using an analog input pin to measure voltage from a water detector board)
// - 2 x Illuminance Measurement devices (using a photoresitor attached to ananlog input)
// - 2 x Voltage Measurement devices (using a photoresitor attached to ananlog input)
// - 2 x Smoke Detector devices (using simple digital input)
// - 2 x Carbon Monoxide Detector devices (using simple digital input)
// - 2 x Motion devices (used to detect motion)
// - 2 x Temperature Measurement devices (Temperature from DHT22 device)
// - 2 x Humidity Measurement devices (Humidity from DHT22 device)
// - 2 x Relay Switch devices (used to turn on a digital output for a set number of cycles And On/Off times (e.g.relay, etc...))
// - 2 x Button devices (sends "pushed" if held for less than 1 second, else sends "held"
// - 2 x Alarm devices - 1 siren only, 1 siren and strobe (using simple digital outputs)
// - 2 x Dimmer Switch devices - uses 2 digital outputs, one for on/off and one for pwm level
// During the development of this re-usable library, it became apparent that the
// Arduino UNO R3's very limited 2K of SRAM was very limiting in the number of
// devices that could be implemented simultaneously. A tremendous amount of effort
// has gone into reducing the SRAM usage, including siginificant improvements to
// the SmartThings Arduino library.
// Note: This sketch was fully tested on an Arduino MEGA 2560 using the Ethernet W5100 Shield.
// Change History:
// Date Who What
// 2015-01-03 Dan & Daniel Original Creation
// 2017-02-12 Dan Ogorchock Revised to use the new SMartThings v2.0 library
// 2017-04-16 Dan Ogorchock New sketch to demonstrate multiple SmartThings Capabilties of each type
// 2017-04-22 Dan Ogorchock Added Voltage, Carbon Monoxide, and Alarm with Strobe
// SmartThings Library for Arduino Ethernet W5100 Shield
#include <SmartThingsEthernetW5100.h> //Library to provide API to the SmartThings Ethernet W5100 Shield
// ST_Anything Library
#include <Constants.h> //Constants.h is designed to be modified by the end user to adjust behavior of the ST_Anything library
#include <Device.h> //Generic Device Class, inherited by Sensor and Executor classes
#include <Sensor.h> //Generic Sensor Class, typically provides data to ST Cloud (e.g. Temperature, Motion, etc...)
#include <Executor.h> //Generic Executor Class, typically receives data from ST Cloud (e.g. Switch)
#include <InterruptSensor.h> //Generic Interrupt "Sensor" Class, waits for change of state on digital input
#include <PollingSensor.h> //Generic Polling "Sensor" Class, polls Arduino pins periodically
#include <Everything.h> //Master Brain of ST_Anything library that ties everything together and performs ST Shield communications
#include <PS_Illuminance.h> //Implements a Polling Sensor (PS) to measure light levels via a photo resistor on an analog input pin
#include <PS_Voltage.h> //Implements a Polling Sensor (PS) to measure voltage on an analog input pin
#include <PS_TemperatureHumidity.h> //Implements a Polling Sensor (PS) to measure Temperature and Humidity via DHT library
#include <PS_Water.h> //Implements a Polling Sensor (PS) to measure presence of water (i.e. leak detector) on an analog input pin
#include <PS_MQ2_Smoke.h> //Implements an Polling Sensor (PS) to monitor the status of an analog input pin from a MQ2 sensor
#include <IS_Motion.h> //Implements an Interrupt Sensor (IS) to detect motion via a PIR sensor on a digital input pin
#include <IS_Contact.h> //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin
#include <IS_Smoke.h> //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin
#include <IS_CarbonMonoxide.h> //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin
#include <IS_DoorControl.h> //Implements an Interrupt Sensor (IS) and Executor to monitor the status of a digital input pin and control a digital output pin
#include <IS_Button.h> //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin for button presses
#include <EX_Switch.h> //Implements an Executor (EX) via a digital output to a relay
#include <EX_Alarm.h> //Implements Executor (EX)as an Alarm capability with Siren and Strobe via digital outputs to relays
#include <S_TimedRelay.h> //Implements a Sensor to control a digital output pin with timing/cycle repeat capabilities
#include <EX_Switch_Dim.h> //Implements an Executor (EX) for a switch (on/off) and pwm output (level) uses 2 digital output pins
//Define which Arduino Pins will be used for each device
// Notes: Arduino communicates with both the W5100 and SD card using the SPI bus (through the ICSP header).
// This is on digital pins 10, 11, 12, and 13 on the Uno and pins 50, 51, and 52 on the Mega.
// On both boards, pin 10 is used to select the W5100 and pin 4 for the SD card.
// These pins cannot be used for general I/O. On the Mega, the hardware SS pin, 53,
// is not used to select either the W5100 or the SD card, but it must be kept as an output
// or the SPI interface won't work.
// See https://www.arduino.cc/en/Main/ArduinoEthernetShieldV1 for details on the W5100 Sield
//"RESERVED" pins for W5100 Ethernet Shield - best to avoid
#define PIN_4_RESERVED 4 //reserved by W5100 Shield on both UNO and MEGA
#define PIN_1O_RESERVED 10 //reserved by W5100 Shield on both UNO and MEGA
#define PIN_11_RESERVED 11 //reserved by W5100 Shield on UNO
#define PIN_12_RESERVED 12 //reserved by W5100 Shield on UNO
#define PIN_13_RESERVED 13 //reserved by W5100 Shield on UNO
#define PIN_50_RESERVED 50 //reserved by W5100 Shield on MEGA
#define PIN_51_RESERVED 51 //reserved by W5100 Shield on MEGA
#define PIN_52_RESERVED 52 //reserved by W5100 Shield on MEGA
#define PIN_53_RESERVED 53 //reserved by W5100 Shield on MEGA
//Analog Pins
#define PIN_WATER_1 A0 //SmartThings Capability "Water Sensor"
//#define PIN_WATER_2 A1 //SmartThings Capability "Water Sensor"
//#define PIN_ILLUMINANCE_1 A2 //SmartThings Capability "Illuminance Measurement"
//#define PIN_ILLUMINANCE_2 A3 //SmartThings Capability "Illuminance Measurement"
//#define PIN_VOLTAGE_1 A4 //SmartThings Capability "Voltage Measurement"
//#define PIN_VOLTAGE_2 A5 //SmartThings Capability "Voltage Measurement"
//Digital Pins
//#define PIN_TEMPERATUREHUMIDITY_1 22 //SmartThings Capabilities "Temperature Measurement" and "Relative Humidity Measurement"
//#define PIN_TEMPERATUREHUMIDITY_2 23 //SmartThings Capabilities "Temperature Measurement" and "Relative Humidity Measurement"
//#define PIN_MOTION_1 24 //SmartThings Capability "Motion Sensor"
//#define PIN_MOTION_2 25 //SmartThings Capability "Motion Sensor"
//#define PIN_CONTACT_1 26 //SmartThings Capability "Contact Sensor"
//#define PIN_CONTACT_2 27 //SmartThings Capability "Contact Sensor"
//#define PIN_SWITCH_1 28 //SmartThings Capability "Switch"
//#define PIN_SWITCH_2 29 //SmartThings Capability "Switch"
//#define PIN_TIMEDRELAY_1 30 //SmartThings Capability "Relay Switch"
//#define PIN_TIMEDRELAY_2 31 //SmartThings Capability "Relay Switch"
//#define PIN_SMOKE_1 32 //SmartThings Capability "Smoke Detector"
//#define PIN_SMOKE_2 33 //SmartThings Capability "Smoke Detector"
//#define PIN_ALARM_1 34 //SmartThings Capability "Alarm"
//#define PIN_ALARM_2 40 //SmartThings Capability "Alarm"
//#define PIN_STROBE_2 41 //SmartThings Capability "Alarm"
//#define PIN_CO_1 42 //SmartThings Capability "Carbon Monoxide Detector"
//#define PIN_CO_2 43 //SmartThings Capability "Carbon Monoxide Detector"
//Garage Door Pins
#define PIN_DOORCONTROL_CONTACT_1 2 //SmartThings Capabilty "Door Control"
#define PIN_DOORCONTROL_RELAY_1 3 //SmartThings Capabilty "Door Control"
#define PIN_DOORCONTROL_CONTACT_2 5 //SmartThings Capabilty "Door Control"
#define PIN_DOORCONTROL_RELAY_2 6 //SmartThings Capabilty "Door Control"
//W5100 Ethernet Shield Information
byte mac[] = {0x06,0x01,0x02,0x03,0x04,0x05}; //MAC address, leave first octet 0x06, change others to be unique // <---You must edit this line!
IPAddress ip(192, 168, 1, 226); //Arduino device IP Address // <---You must edit this line!
IPAddress gateway(192, 168, 1, 1); //router gateway // <---You must edit this line!
IPAddress subnet(255, 255, 255, 0); //LAN subnet mask // <---You must edit this line!
IPAddress dnsserver(192, 168, 1, 1); //DNS server // <---You must edit this line!
const unsigned int serverPort = 8090; // port to run the http server on
// Smartthings hub information
IPAddress hubIp(192,168,1,149); // smartthings hub ip // <---You must edit this line!
const unsigned int hubPort = 39500; // smartthings hub port
//st::Everything::callOnMsgSend() optional callback routine. This is a sniffer to monitor
// data being sent to ST. This allows a user to act on data changes locally within the
// Arduino sktech withotu having to rely on the ST Cloud for time-critical tasks.
void callback(const String &msg)
//Uncomment if it weould be desirable to using this function
//Serial.print(F("ST_Anything_Miltiples Callback: Sniffed data = "));
//Serial.println(msg);
//TODO: Add local logic here to take action when a device's value/state is changed
//Masquerade as the ThingShield to send data to the Arduino, as if from the ST Cloud (uncomment and edit following line(s) as you see fit)
//st::receiveSmartString("Put your command here!"); //use same strings that the Device Handler would send
//Arduino Setup() routine
void setup()
//Declare each Device that is attached to the Arduino
// Notes: - For each device, there is typically a corresponding "tile" defined in your
// SmartThings Device Hanlder Groovy code, except when using new COMPOSITE Device Handler
// - For details on each device's constructor arguments below, please refer to the
// corresponding header (.h) and program (.cpp) files.
// - The name assigned to each device (1st argument below) must match the Groovy
// Device Handler names. (Note: "temphumid" below is the exception to this rule
// as the DHT sensors produce both "temperature" and "humidity". Data from that
// particular sensor is sent to the ST Hub in two separate updates, one for
// "temperature" and one for "humidity")
// - The new Composite Device Handler is comprised of a Parent DH and various Child
// DH's. The names used below MUST not be changed for the Automatic Creation of
// child devices to work properly. Simply increment the number by +1 for each duplicate
// device (e.g. contact1, contact2, contact3, etc...) You can rename the Child Devices
// to match your specific use case in the ST Phone Application.
//Polling Sensors
static st::PS_Water sensor1(F("water1"), 60, 0, PIN_WATER_1, 200);
// static st::PS_Water sensor2(F("water2"), 60, 10, PIN_WATER_2, 200);
// static st::PS_Illuminance sensor3(F("illuminance1"), 60, 20, PIN_ILLUMINANCE_1, 0, 1023, 0, 1000);
// static st::PS_Illuminance sensor4(F("illuminance2"), 60, 30, PIN_ILLUMINANCE_2, 0, 1023, 0, 1000);
// static st::PS_TemperatureHumidity sensor5(F("temphumid1"), 60, 40, PIN_TEMPERATUREHUMIDITY_1, st::PS_TemperatureHumidity::DHT22,"temperature1","humidity1");
// static st::PS_TemperatureHumidity sensor6(F("temphumid2"), 60, 50, PIN_TEMPERATUREHUMIDITY_2, st::PS_TemperatureHumidity::DHT22,"temperature2","humidity2");
// static st::PS_Voltage sensor7(F("voltage1"), 60, 55, PIN_VOLTAGE_1, 0, 1023, 0, 5000);
// static st::PS_Voltage sensor8(F("voltage2"), 60, 57, PIN_VOLTAGE_2, 0, 1023, 0, 5000);
// static st::PS_MQ2_Smoke sensor23(F("smoke3"), PIN_SMOKE_3, 400);
//Interrupt Sensors
// static st::IS_Motion sensor9(F("motion1"), PIN_MOTION_1, HIGH, false, 500);
// static st::IS_Motion sensor10(F("motion2"), PIN_MOTION_2, HIGH, false, 500);
// static st::IS_Contact sensor11(F("contact1"), PIN_CONTACT_1, LOW, true, 500);
// static st::IS_Contact sensor12(F("contact2"), PIN_CONTACT_2, LOW, true, 500);
// static st::IS_Smoke sensor13(F("smoke1"), PIN_SMOKE_1, HIGH, true, 500);
// static st::IS_Smoke sensor14(F("smoke2"), PIN_SMOKE_2, HIGH, true, 500);
static st::IS_DoorControl sensor15(F("doorControl1"), PIN_DOORCONTROL_CONTACT_1, LOW, true, PIN_DOORCONTROL_RELAY_1, LOW, true, 1000);
static st::IS_DoorControl sensor16(F("doorControl2"), PIN_DOORCONTROL_CONTACT_2, LOW, true, PIN_DOORCONTROL_RELAY_2, LOW, true, 1000);
// static st::IS_Button sensor17(F("button1"), PIN_BUTTON1, 1000, LOW, true, 500);
// static st::IS_Button sensor18(F("button2"), PIN_BUTTON2, 1000, LOW, true, 500);
// static st::IS_CarbonMonoxide sensor19(F("carbonMonoxide1"), PIN_CO_1, HIGH, true, 500);
// static st::IS_CarbonMonoxide sensor20(F("carbonMonoxide2"), PIN_CO_2, HIGH, true, 500);
//Special sensors/executors (uses portions of both polling and executor classes)
// static st::S_TimedRelay sensor21(F("relaySwitch1"), PIN_TIMEDRELAY_1, LOW, true, 3000, 0, 1);
// static st::S_TimedRelay sensor22(F("relaySwitch2"), PIN_TIMEDRELAY_2, LOW, true, 3000, 0, 1);
//Executors
// static st::EX_Switch executor1(F("switch1"), PIN_SWITCH_1, LOW, true);
// static st::EX_Switch executor2(F("switch2"), PIN_SWITCH_2, LOW, true);
// static st::EX_Alarm executor3(F("alarm1"), PIN_ALARM_1, LOW, true);
// static st::EX_Alarm executor4(F("alarm2"), PIN_ALARM_2, LOW, true, PIN_STROBE_2);
// static st::EX_Switch_Dim executor5(F("dimmerSwitch1"), PIN_DIMMERSWITCH_1, PIN_DIMMERLEVEL_1, LOW, false);
// static st::EX_Switch_Dim executor6(F("dimmerSwitch2"), PIN_DIMMERSWITCH_2, PIN_DIMMERLEVEL_2, LOW, false);
// Configure debug print output from each main class
st::Everything::debug=true;
st::Executor::debug=true;
st::Device::debug=true;
st::PollingSensor::debug=true;
st::InterruptSensor::debug=true;
//Initialize the "Everything" Class
//Initialize the optional local callback routine (safe to comment out if not desired)
st::Everything::callOnMsgSend = callback;
//Create the SmartThings EthernetW5500 Communications Object
//STATIC IP Assignment - Recommended
st::Everything::SmartThing = new st::SmartThingsEthernetW5100(mac, ip, gateway, subnet, dnsserver, serverPort, hubIp, hubPort, st::receiveSmartString);
//DHCP IP Assigment - Must set your router's DHCP server to provice a static IP address for this device's MAC address
//st::Everything::SmartThing = new st::SmartThingsEthernetW5100(mac, serverPort, hubIp, hubPort, st::receiveSmartString);
//Run the Everything class' init() routine which establishes Ethernet communications with the SmartThings Hub
st::Everything::init();
//Add each sensor to the "Everything" Class
st::Everything::addSensor(&sensor1);
// st::Everything::addSensor(&sensor2);
// st::Everything::addSensor(&sensor3);
// st::Everything::addSensor(&sensor4);
// st::Everything::addSensor(&sensor5);
// st::Everything::addSensor(&sensor6);
// st::Everything::addSensor(&sensor7);
// st::Everything::addSensor(&sensor8);
// st::Everything::addSensor(&sensor9);
// st::Everything::addSensor(&sensor10);
// st::Everything::addSensor(&sensor11);
// st::Everything::addSensor(&sensor12);
// st::Everything::addSensor(&sensor13);
// st::Everything::addSensor(&sensor14);
st::Everything::addSensor(&sensor15);
st::Everything::addSensor(&sensor16);
// st::Everything::addSensor(&sensor17);
// st::Everything::addSensor(&sensor18);
// st::Everything::addSensor(&sensor19);
// st::Everything::addSensor(&sensor20);
// st::Everything::addSensor(&sensor21);
// st::Everything::addSensor(&sensor22);
// st::Everything::addSensor(&sensor23);
//Add each executor to the "Everything" Class
// st::Everything::addExecutor(&executor1);
// st::Everything::addExecutor(&executor2);
// st::Everything::addExecutor(&executor3);
// st::Everything::addExecutor(&executor4);
// st::Everything::addExecutor(&executor5);
// st::Everything::addExecutor(&executor6);
//Initialize each of the devices which were added to the Everything Class
st::Everything::initDevices();
//Arduino Loop() routine
void loop()
//Execute the Everything run method which takes care of "Everything"
st::Everything::run();
