ST_Anything)/Groovy/ Deprecated ?
Well, I have older NodeMCU which is still not reflashed, so nothing changed there, it must be the DHs.
Here is one what I have -
// SmartThings NodeMCU ESP8266 Wifi Library
// License
// (C) Copyright 2017 Dan Ogorchock
// History
// 2017-02-10 Dan Ogorchock Created
#include "SmartThingsESP8266WiFi.h"
namespace st
// SmartThingsESP8266WiFI Constructor - Static IP
SmartThingsESP8266WiFi::SmartThingsESP8266WiFi(String ssid, String password, IPAddress localIP, IPAddress localGateway, IPAddress localSubnetMask, IPAddress localDNSServer, uint16_t serverPort, IPAddress hubIP, uint16_t hubPort, SmartThingsCallout_t *callout, String shieldType, bool enableDebug, int transmitInterval) :
SmartThingsEthernet(localIP, localGateway, localSubnetMask, localDNSServer, serverPort, hubIP, hubPort, callout, shieldType, enableDebug, transmitInterval, false),
st_server(serverPort)
ssid.toCharArray(st_ssid, sizeof(st_ssid));
password.toCharArray(st_password, sizeof(st_password));
// SmartThingsESP8266WiFI Constructor - DHCP
SmartThingsESP8266WiFi::SmartThingsESP8266WiFi(String ssid, String password, uint16_t serverPort, IPAddress hubIP, uint16_t hubPort, SmartThingsCallout_t *callout, String shieldType, bool enableDebug, int transmitInterval) :
SmartThingsEthernet(serverPort, hubIP, hubPort, callout, shieldType, enableDebug, transmitInterval, true),
SmartThingsESP8266WiFi::SmartThingsESP8266WiFi(uint16_t serverPort, IPAddress hubIP, uint16_t hubPort, SmartThingsCallout_t *callout, String shieldType, bool enableDebug, int transmitInterval) :
st_preExistingConnection = true;
//SmartThingsESP8266WiFI::~SmartThingsESP8266WiFI()
SmartThingsESP8266WiFi::~SmartThingsESP8266WiFi()
/// Initialize SmartThingsESP8266WiFI Library
void SmartThingsESP8266WiFi::init(void)
if (!st_preExistingConnection) {
Serial.println(F(""));
Serial.println(F("Initializing ESP8266 WiFi network. Please be patient..."));
// attempt to connect to WiFi network
WiFi.begin(st_ssid, st_password);
Serial.print(F("Attempting to connect to WPA SSID: "));
Serial.println(st_ssid);
while (WiFi.status() != WL_CONNECTED) {
Serial.print(F("."));
delay(500); // wait for connection:
Serial.println();
if (st_DHCP == false)
WiFi.config(st_localIP, st_localGateway, st_localSubnetMask, st_localDNSServer);
st_server.begin();
Serial.println(F("Enter the following three lines of data into ST App on your phone!"));
Serial.print(F("localIP = "));
Serial.println(WiFi.localIP());
Serial.print(F("serverPort = "));
Serial.println(st_serverPort);
Serial.print(F("MAC Address = "));
Serial.println(WiFi.macAddress());
Serial.print(F("SSID = "));
Serial.print(F("PASSWORD = "));
Serial.println(st_password);
Serial.print(F("hubIP = "));
Serial.println(st_hubIP);
Serial.print(F("hubPort = "));
Serial.println(st_hubPort);
Serial.println(F("SmartThingsESP8266WiFI: Intialized"));
//Turn off Wirelss Access Point
Serial.println(F("Disabling ESP8266 WiFi Access Point"));
WiFi.mode(WIFI_STA);
// Run SmartThingsESP8266WiFI Library
void SmartThingsESP8266WiFi::run(void)
String readString;
String tempString;
if (WiFi.isConnected() == false)
if (_isDebugEnabled)
Serial.println(F("**********************************************************"));
Serial.println(F("**** WiFi Disconnected. ESP8266 should auto-reconnect ***"));
//init();
WiFiClient client = st_server.available();
if (client) {
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 200) {
//store characters to string
readString += c;
else
Serial.println(F("SmartThings.run() - Exceeded 200 character limit"));
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
//now output HTML data header
tempString = readString.substring(readString.indexOf('/') + 1, readString.indexOf('?'));
if (tempString.length() > 0) {
client.println(F("HTTP/1.1 200 OK")); //send new page
client.println();
else {
client.println(F("HTTP/1.1 204 No Content"));
client.println();
client.println();
Serial.println(F("No Valid Data Received"));
break;
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
delay(1);
//stopping client
client.stop();
//Handle the received data after cleaning up the network connection
Serial.print(F("Handling request from ST. tempString = "));
Serial.println(tempString);
//Pass the message to user's SmartThings callout function
_calloutFunction(tempString);
readString = "";
tempString = "";
/// Send Message out over Ethernet to the Hub
void SmartThingsESP8266WiFi::send(String message)
//init();
//Make sure the client is stopped, to free up socket for new conenction
st_client.stop();
if (st_client.connect(st_hubIP, st_hubPort))
st_client.println(F("POST / HTTP/1.1"));
st_client.print(F("HOST: "));
st_client.print(st_hubIP);
st_client.print(F(":"));
st_client.println(st_hubPort);
st_client.println(F("CONTENT-TYPE: text"));
st_client.print(F("CONTENT-LENGTH: "));
st_client.println(message.length());
st_client.println();
st_client.println(message);
else
//connection failed;
Serial.println(F("***********************************************************"));
Serial.println(F("***** SmartThings.send() - Ethernet Connection Failed *****"));
Serial.print(st_hubIP);
Serial.print(F(" "));
Serial.println(F("**** WiFi Disconnected. ESP8266 should auto-reconnect ****"));
//init(); //Re-Init connection to get things working again
Serial.println(F("****** Attempting to resend missed data *******"));
st_client.flush();
st_client.stop();
//if (_isDebugEnabled) { Serial.println(F("WiFi.send(): Reading for reply data "));}
// read any data returned from the POST
while (st_client.connected()) {
//while (st_client.available()) {
char c = st_client.read(); //gets byte from ethernet buffer
//if (_isDebugEnabled) { Serial.print(c); } //prints byte to serial monitor
delay(1);
st_client.stop();
