Hre it is, Sir!
// File: ST_Anything_Multiples_ESP01WiFi.ino
// Authors: Dan G Ogorchock & Daniel J Ogorchock (Father and Son)
// Summary: This Arduino Sketch, along with the ST_Anything library and the revised SmartThings
// library, demonstrates the ability of one ESP8266-01 (ESP-01) to
// implement a multi input/output custom device for integration into SmartThings.
// The ST_Anything library takes care of all of the work to schedule device updates
// as well as all communications with the ESP-01's WiFi.
// ST_Anything_Multiples implements the following ST Capabilities in multiples of 1 as a demo of what is possible with a single ESP-01
// - 1 x Contact Sensor device (used to monitor magnetic door sensors)
// - 1 x Motion devices (used to detect motion)
// Note: The tiny ESP-01 only has 2 GPIO pins, so this example is somewhat limited. Use the ST_ANything_Multiples_ESP8266WiFi.ino example to see
// what else is possible. As long as you only try using 2 pins, you can use them for whatever you'd like.
// Change History:
// Date Who What
// 2015-01-03 Dan & Daniel Original Creation
// 2017-02-12 Dan Ogorchock Revised to use the new SmartThings v2.0 library
// 2017-02-21 Dan Ogorchock New example specifically for running everythin on a ESP-01 (no Arduino required!)
// 2017-04-24 Dan Ogorchock Updated for use with new v2.5 Parent/Child Device handlers
// 2018-02-09 Dan Ogorchock Added support for Hubitat Elevation Hub
// SmartThings Library for ESP8266WiFi
#include <SmartThingsESP8266WiFi.h>
// ST_Anything Library
#include <Constants.h> //Constants.h is designed to be modified by the end user to adjust behavior of the ST_Anything library
#include <Device.h> //Generic Device Class, inherited by Sensor and Executor classes
#include <Sensor.h> //Generic Sensor Class, typically provides data to ST Cloud (e.g. Temperature, Motion, etc...)
#include <Executor.h> //Generic Executor Class, typically receives data from ST Cloud (e.g. Switch)
#include <InterruptSensor.h> //Generic Interrupt "Sensor" Class, waits for change of state on digital input
#include <PollingSensor.h> //Generic Polling "Sensor" Class, polls Arduino pins periodically
#include <Everything.h> //Master Brain of ST_Anything library that ties everything together and performs ST Shield communications
//#include <PS_Illuminance.h> //Implements a Polling Sensor (PS) to measure light levels via a photo resistor
//#include <PS_TemperatureHumidity.h> //Implements a Polling Sensor (PS) to measure Temperature and Humidity via DHT library.
//#include <PS_Water.h> //Implements a Polling Sensor (PS) to measure presence of water (i.e. leak detector)
//#include <IS_Motion.h> //Implements an Interrupt Sensor (IS) to detect motion via a PIR sensor
#include <IS_Contact.h> //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin
#include <EX_Switch.h> //Implements an Executor (EX) via a digital output to a relay
//#include <EX_Alarm.h> //Implements Executor (EX)as an Alarm Siren capability via a digital output to a relay
//Define which Arduino Pins will be used for each device
#define PIN_SWITCH 0
#define PIN_CONTACT 2
//ESP8266 WiFi Information
String str_ssid = "XXXXXXXXXXXX"; // <---You must edit this line!
String str_password = "00000000000"; // <---You must edit this line!
IPAddress ip(192, 168, 10, 85); //Device IP Address // <---You must edit this line!
IPAddress gateway(192, 168, 10, 1); //Router gateway // <---You must edit this line!
IPAddress subnet(255, 255, 255, 0); //LAN subnet mask // <---You must edit this line!
IPAddress dnsserver(192, 168, 10, 1); //DNS server // <---You must edit this line!
const unsigned int serverPort = 8090; // port to run the http server on
// Smartthings / Hubitat Hub TCP/IP Address
IPAddress hubIp(192, 168, 10, 200); // smartthings/hubitat hub ip // <---You must edit this line!
// SmartThings / Hubitat Hub TCP/IP Address: UNCOMMENT line that corresponds to your hub, COMMENT the other
const unsigned int hubPort = 39500; // smartthings hub port
//const unsigned int hubPort = 39501; // hubitat hub port
//st::Everything::callOnMsgSend() optional callback routine. This is a sniffer to monitor
// data being sent to ST. This allows a user to act on data changes locally within the
// Arduino sktech.
void callback(const String &msg)
Serial.print(F("ST_Anything Callback: Sniffed data = "));
Serial.println(msg);
//TODO: Add local logic here to take action when a device's value/state is changed
//NOTE: you may need to play with the logic below to get the behavior you desire!!!
if (msg == "contact1 closed") {
st::receiveSmartString("switch1 on");
if (msg == "contact1 open") {
st::receiveSmartString("switch1 off");
//Arduino Setup() routine
void setup()
//Declare each Device that is attached to the ESP-01
// Notes: - For each device, there is typically a corresponding "tile" defined in your
// SmartThings Device Hanlder Groovy code, except when using new COMPOSITE Device Handler
// - For details on each device's constructor arguments below, please refer to the
// corresponding header (.h) and program (.cpp) files.
// - The name assigned to each device (1st argument below) must match the Groovy
// Device Handler names. (Note: "temphumid" below is the exception to this rule
// as the DHT sensors produce both "temperature" and "humidity". Data from that
// particular sensor is sent to the ST Hub in two separate updates, one for
// "temperature" and one for "humidity")
// - The new Composite Device Handler is comprised of a Parent DH and various Child
// DH's. The names used below MUST not be changed for the Automatic Creation of
// child devices to work properly. Simply increment the number by +1 for each duplicate
// device (e.g. contact1, contact2, contact3, etc...) You can rename the Child Devices
// to match your specific use case in the ST Phone Application.
//Polling Sensors
//Interrupt Sensors
static st::IS_Contact sensor1(F("contact1"), PIN_CONTACT, LOW, true);
//Executors
static st::EX_Switch executor1(F("switch1"), PIN_SWITCH, LOW, true); //Inverted logic for "Active Low" Relay Board
// Configure debug print output from each main class
st::Everything::debug=true;
st::Executor::debug=true;
st::Device::debug=true;
st::PollingSensor::debug=true;
st::InterruptSensor::debug=true;
//Initialize the "Everything" Class
//Initialize the optional local callback routine (safe to comment out if not desired)
st::Everything::callOnMsgSend = callback;
//Create the SmartThings ESP8266WiFi Communications Object
//STATIC IP Assignment - Recommended
st::Everything::SmartThing = new st::SmartThingsESP8266WiFi(str_ssid, str_password, ip, gateway, subnet, dnsserver, serverPort, hubIp, hubPort, st::receiveSmartString);
//DHCP IP Assigment - Must set your router's DHCP server to provice a static IP address for this device's MAC address
//st::Everything::SmartThing = new st::SmartThingsESP8266WiFi(str_ssid, str_password, serverPort, hubIp, hubPort, st::receiveSmartString);
//Run the Everything class' init() routine which establishes WiFi communications with SmartThings Hub
st::Everything::init();
//Add each sensor to the "Everything" Class
st::Everything::addSensor(&sensor1);
//Add each executor to the "Everything" Class
st::Everything::addExecutor(&executor1);
//Initialize each of the devices which were added to the Everything Class
st::Everything::initDevices();
//Arduino Loop() routine
void loop()
//Execute the Everything run method which takes care of "Everything"
st::Everything::run();
