Here is what I mean. This is a sketch that should have everything you need based on what you’ve posted above. I haven’t tested it as I am not at home currently. Of course, you’ll need to configure the networking section for your home network. It has 13 contact sensors digital inputs, 1 motion detector digital input, and 1 alarm (a digital output that you would attached to a relay to power a siren.)
// File: ST_Anything_Multiples_EthernetW5100.ino
// Authors: Dan G Ogorchock & Daniel J Ogorchock (Father and Son)
// Summary: This Arduino Sketch, along with the ST_Anything library and the revised SmartThings
// library, demonstrates the ability of one Arduino + Ethernet W5100 Shield to
// implement a multi input/output custom device for integration into SmartThings.
// The ST_Anything library takes care of all of the work to schedule device updates
// as well as all communications with the Ethernet W5100 Shield.
// ST_Anything_Multiples implements the following ST Capabilities in multiples of 2 as a demo of what is possible with a single Arduino
// - 2 x Door Control devices (used typically for Garage Doors - input pin (contact sensor) and output pin (relay switch)
// - 2 x Contact Sensor devices (used to monitor magnetic door sensors)
// - 2 x Switch devices (used to turn on a digital output (e.g. LED, relay, etc...)
// - 2 x Water Sensor devices (using an analog input pin to measure voltage from a water detector baord)
// - 2 x Illuminance Measurement devices (using a photoresitor attached to ananlog input)
// - 2 x Voltage Measurement devices (using a photoresitor attached to ananlog input)
// - 2 x Smoke Detector devices (using simple digital input)
// - 2 x Carbon Monoxide Detector devices (using simple digital input)
// - 2 x Motion devices (used to detect motion)
// - 2 x Temperature Measurement devices (Temperature from DHT22 device)
// - 2 x Humidity Measurement devices (Humidity from DHT22 device)
// - 2 x Relay Switch devices (used to turn on a digital output for a set number of cycles And On/Off times (e.g.relay, etc...))
// - 2 x Button devices (sends "pushed" if held for less than 1 second, else sends "held"
// - 2 x Alarm devices (using a simple digital output)
// During the development of this re-usable library, it became apparent that the
// Arduino UNO R3's very limited 2K of SRAM was very limiting in the number of
// devices that could be implemented simultaneously. A tremendous amount of effort
// has gone into reducing the SRAM usage, including siginificant improvements to
// the SmartThings Arduino library.
// Note: This sketch was fully tested on an Arduino MEGA 2560 using the Ethernet W5100 Shield.
// Change History:
// Date Who What
// 2015-01-03 Dan & Daniel Original Creation
// 2017-02-12 Dan Ogorchock Revised to use the new SMartThings v2.0 library
// 2017-04-16 Dan Ogorchock New sketch to demonstrate multiple SmartThings Capabilties of each type
// SmartThings Library for Arduino Ethernet W5100 Shield
#include <SmartThingsEthernetW5100.h> //Library to provide API to the SmartThings Ethernet W5100 Shield
// ST_Anything Library
#include <Constants.h> //Constants.h is designed to be modified by the end user to adjust behavior of the ST_Anything library
#include <Device.h> //Generic Device Class, inherited by Sensor and Executor classes
#include <Sensor.h> //Generic Sensor Class, typically provides data to ST Cloud (e.g. Temperature, Motion, etc...)
#include <Executor.h> //Generic Executor Class, typically receives data from ST Cloud (e.g. Switch)
#include <InterruptSensor.h> //Generic Interrupt "Sensor" Class, waits for change of state on digital input
#include <PollingSensor.h> //Generic Polling "Sensor" Class, polls Arduino pins periodically
#include <Everything.h> //Master Brain of ST_Anything library that ties everything together and performs ST Shield communications
#include <PS_Illuminance.h> //Implements a Polling Sensor (PS) to measure light levels via a photo resistor on an analog input pin
#include <PS_Voltage.h> //Implements a Polling Sensor (PS) to measure voltage on an analog input pin
#include <PS_TemperatureHumidity.h> //Implements a Polling Sensor (PS) to measure Temperature and Humidity via DHT library
#include <PS_Water.h> //Implements a Polling Sensor (PS) to measure presence of water (i.e. leak detector) on an analog input pin
#include <IS_Motion.h> //Implements an Interrupt Sensor (IS) to detect motion via a PIR sensor on a digital input pin
#include <IS_Contact.h> //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin
#include <IS_Smoke.h> //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin
#include <IS_CarbonMonoxide.h> //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin
#include <IS_DoorControl.h> //Implements an Interrupt Sensor (IS) and Executor to monitor the status of a digital input pin and control a digital output
pin
#include <IS_Button.h> //Implements an Interrupt Sensor (IS) to monitor the status of a digital input pin for button presses
#include <EX_Switch.h> //Implements an Executor (EX) via a digital output to a relay
#include <EX_Alarm.h> //Implements Executor (EX)as an Alarm Siren capability via a digital output to a relay
#include <S_TimedRelay.h> //Implements a Sensor to control a digital output pin with timing/cycle repeat capabilities
//Define which Arduino Pins will be used for each device
// Notes: Arduino communicates with both the W5100 and SD card using the SPI bus (through the ICSP header).
// This is on digital pins 10, 11, 12, and 13 on the Uno and pins 50, 51, and 52 on the Mega.
// On both boards, pin 10 is used to select the W5100 and pin 4 for the SD card.
// These pins cannot be used for general I/O. On the Mega, the hardware SS pin, 53,
// is not used to select either the W5100 or the SD card, but it must be kept as an output
// or the SPI interface won't work.
// See https://www.arduino.cc/en/Main/ArduinoEthernetShieldV1 for details on the W5100 Sield
//"RESERVED" pins for W5100 Ethernet Shield - best to avoid
#define PIN_4_RESERVED 4 //reserved by W5100 Shield on both UNO and MEGA
#define PIN_1O_RESERVED 10 //reserved by W5100 Shield on both UNO and MEGA
#define PIN_11_RESERVED 11 //reserved by W5100 Shield on UNO
#define PIN_12_RESERVED 12 //reserved by W5100 Shield on UNO
#define PIN_13_RESERVED 13 //reserved by W5100 Shield on UNO
#define PIN_50_RESERVED 50 //reserved by W5100 Shield on MEGA
#define PIN_51_RESERVED 51 //reserved by W5100 Shield on MEGA
#define PIN_52_RESERVED 52 //reserved by W5100 Shield on MEGA
#define PIN_53_RESERVED 53 //reserved by W5100 Shield on MEGA
//Analog Pins
//Digital Pins
#define PIN_CONTACT_1 22 //SmartThings Capability "Contact Sensor"
#define PIN_CONTACT_2 23 //SmartThings Capability "Contact Sensor"
#define PIN_CONTACT_3 24 //SmartThings Capability "Contact Sensor"
#define PIN_CONTACT_4 25 //SmartThings Capability "Contact Sensor"
#define PIN_CONTACT_5 26 //SmartThings Capability "Contact Sensor"
#define PIN_CONTACT_6 27 //SmartThings Capability "Contact Sensor"
#define PIN_CONTACT_7 28 //SmartThings Capability "Contact Sensor"
#define PIN_CONTACT_8 29 //SmartThings Capability "Contact Sensor"
#define PIN_CONTACT_9 30 //SmartThings Capability "Contact Sensor"
#define PIN_CONTACT_10 31 //SmartThings Capability "Contact Sensor"
#define PIN_CONTACT_11 32 //SmartThings Capability "Contact Sensor"
#define PIN_CONTACT_12 33 //SmartThings Capability "Contact Sensor"
#define PIN_CONTACT_13 34 //SmartThings Capability "Contact Sensor"
#define PIN_MOTION_1 35 //SmartThings Capability "Motion Detector"
#define PIN_ALARM_1 36 //SmartThings Capability "Alarm"
//Garage Door Pins
//Pushbutton Pins
//#define PIN_BUTTON1 48 //SmartThings Capabilty Button / Holdable Button
//#define PIN_BUTTON2 49 //SmartThings Capabilty Button / Holdable Button
//W5100 Ethernet Shield Information
byte mac[] = {0x06,0x02,0x03,0x04,0x05,0x06}; //MAC address, leave first octet 0x06, change others to be unique // <---You must edit this line!
IPAddress ip(192, 168, 1, 200); //Arduino device IP Address // <---You must edit this line!
IPAddress gateway(192, 168, 1, 1); //router gateway // <---You must edit this line!
IPAddress subnet(255, 255, 255, 0); //LAN subnet mask // <---You must edit this line!
IPAddress dnsserver(192, 168, 1, 1); //DNS server // <---You must edit this line!
const unsigned int serverPort = 8090; // port to run the http server on
// Smartthings hub information
IPAddress hubIp(192,168,1,149); // smartthings hub ip // <---You must edit this line!
const unsigned int hubPort = 39500; // smartthings hub port
//st::Everything::callOnMsgSend() optional callback routine. This is a sniffer to monitor
// data being sent to ST. This allows a user to act on data changes locally within the
// Arduino sktech withotu having to rely on the ST Cloud for time-critical tasks.
void callback(const String &msg)
//Uncomment if it weould be desirable to using this function
//Serial.print(F("ST_Anything_Miltiples Callback: Sniffed data = "));
//Serial.println(msg);
//TODO: Add local logic here to take action when a device's value/state is changed
//Masquerade as the ThingShield to send data to the Arduino, as if from the ST Cloud (uncomment and edit following line(s) as you see fit)
//st::receiveSmartString("Put your command here!"); //use same strings that the Device Handler would send
//Arduino Setup() routine
void setup()
//Declare each Device that is attached to the Arduino
// Notes: - For each device, there is typically a corresponding "tile" defined in your
// SmartThings Device Hanlder Groovy code, except when using new COMPOSITE Device Handler
// - For details on each device's constructor arguments below, please refer to the
// corresponding header (.h) and program (.cpp) files.
// - The name assigned to each device (1st argument below) must match the Groovy
// Device Handler names. (Note: "temphumid" below is the exception to this rule
// as the DHT sensors produce both "temperature" and "humidity". Data from that
// particular sensor is sent to the ST Hub in two separate updates, one for
// "temperature" and one for "humidity")
// - The new Composite Device Handler is comprised of a Parent DH and various Child
// DH's. The names used below MUST not be changed for the Automatic Creation of
// child devices to work properly. Simply increment the number by +1 for each duplicate
// device (e.g. contact1, contact2, contact3, etc...) You can rename the Child Devices
// to match your specific use case in the ST Phone Application.
//Polling Sensors
//Interrupt Sensors
static st::IS_Motion sensor1(F("motion1"), PIN_MOTION_1, HIGH, false, 500);
static st::IS_Contact sensor2(F("contact1"), PIN_CONTACT_1, LOW, true, 500);
static st::IS_Contact sensor3(F("contact2"), PIN_CONTACT_2, LOW, true, 500);
static st::IS_Contact sensor4(F("contact3"), PIN_CONTACT_1, LOW, true, 500);
static st::IS_Contact sensor5(F("contact4"), PIN_CONTACT_2, LOW, true, 500);
static st::IS_Contact sensor6(F("contact5"), PIN_CONTACT_1, LOW, true, 500);
static st::IS_Contact sensor7(F("contact6"), PIN_CONTACT_2, LOW, true, 500);
static st::IS_Contact sensor8(F("contact7"), PIN_CONTACT_1, LOW, true, 500);
static st::IS_Contact sensor9(F("contact8"), PIN_CONTACT_2, LOW, true, 500);
static st::IS_Contact sensor10(F("contact9"), PIN_CONTACT_1, LOW, true, 500);
static st::IS_Contact sensor11(F("contact10"), PIN_CONTACT_2, LOW, true, 500);
static st::IS_Contact sensor12(F("contact11"), PIN_CONTACT_1, LOW, true, 500);
static st::IS_Contact sensor13(F("contact12"), PIN_CONTACT_2, LOW, true, 500);
static st::IS_Contact sensor14(F("contact13"), PIN_CONTACT_2, LOW, true, 500);
// static st::IS_Button sensor17(F("button1"), PIN_BUTTON1, 1000, LOW, true, 500);
// static st::IS_Button sensor18(F("button2"), PIN_BUTTON2, 1000, LOW, true, 500);
//Executors
static st::EX_Alarm executor1(F("alarm1"), PIN_ALARM_1, LOW, true);
// Configure debug print output from each main class
st::Everything::debug=true;
st::Executor::debug=true;
st::Device::debug=true;
st::PollingSensor::debug=true;
st::InterruptSensor::debug=true;
//Initialize the "Everything" Class
//Initialize the optional local callback routine (safe to comment out if not desired)
st::Everything::callOnMsgSend = callback;
//Create the SmartThings EthernetW5100 Communications Object
st::Everything::SmartThing = new st::SmartThingsEthernetW5100(mac, ip, gateway, subnet, dnsserver, serverPort, hubIp, hubPort, st::receiveSmartString);
//Run the Everything class' init() routine which establishes Ethernet communications with the SmartThings Hub
st::Everything::init();
//Add each sensor to the "Everything" Class
st::Everything::addSensor(&sensor1);
st::Everything::addSensor(&sensor2);
st::Everything::addSensor(&sensor3);
st::Everything::addSensor(&sensor4);
st::Everything::addSensor(&sensor5);
st::Everything::addSensor(&sensor6);
st::Everything::addSensor(&sensor7);
st::Everything::addSensor(&sensor8);
st::Everything::addSensor(&sensor9);
st::Everything::addSensor(&sensor10);
st::Everything::addSensor(&sensor11);
st::Everything::addSensor(&sensor12);
st::Everything::addSensor(&sensor13);
st::Everything::addSensor(&sensor14);
//Add each executor to the "Everything" Class
st::Everything::addExecutor(&executor1);
//Initialize each of the devices which were added to the Everything Class
st::Everything::initDevices();
//Arduino Loop() routine
void loop()
//Execute the Everything run method which takes care of "Everything"
st::Everything::run();
