Thank you so much for the powerful infrastructure you have created. Iâve just started creating devices with ST_Anything for remote control of wireless blinds, fans, etc.(433 & 304mhz ook). I got it all working, however, as I was playing with it and adding/deleting children on the device for various tests, I seem to have corrupted the device table. I now get the dreaded âerror 500: internal server errorâ. Still waiting on Samsung support to help clear it (7 days!). Any suggestions on how to prevent this from happening again in the future?
Fully powering down ST Hub didnât help. I did reserve IP address for ST Hub in my router.
Iâm trying to update code for my Device Handlers but canât remember how to do so on the IDE.
On my Device Handlers page I can see Status for your Child Alarm, Child Contact Sensor, Child Relay Switch, etc shows they have been Editted.
I have a github repository pointing to DanielOgorChuckâs ST_Anything master branch.
But when click Update from Repository for ST_Anything (master), the boxes for Obsolete (updated in GitHub), Conflicted (updated locally and in Github) and New (updated only in Github) are all empty, as if nothing needs to be updated.
I tried clicking on the individual device handlers, but I donât see anywhere to update from github.
How do I update the ST_Anything device handler code?
Sounds like youâve actually updated all of the ST_Anything DTH code, but forgot to check the âpublishâ box when you did so.
So, now all you had to do to change the status from EDITED to PUBLISHED is to click on the name of each and every one of the DTHs, and the click the PUBLISH->ForMe button.
Thanks for your help. Ran PUBLISH->For Me for each of my ST_Anything DTHs and everything started working again in the classic app.
I then migrated to new ST app and my non ST_Anything devices seem to work.
However, my ST_Anything devices no longer display their state as they did in the classic app.
Which I click on a ST_Anything child, it shows Contact sensor with a picture of a cloud with a slash through it.
When I look at the ST_Anything child in the IDE, Current States displays the correct state of contact:open or contact:closed, even though the new ST app does not display the state.
Is this expected behaviour under new ST app?
ST_Anything appears to be working in the IDE based on the IDE Current States, even though the app does not display the Current States like it did in the classic app.
Did you delete all of the Child Devices and the let them be recreated automatically? If not, they will not work in the New ST App, unfortunately. Yes, this means youâll have to redo all of the automations that use these child devices.
What is the recommended procedure for deleting all of the Child Devices? Searching this thread I see warnings about manually deleting child devices as it may break the Parent.
That was quite some time ago. It appears ST has corrected that issue, as my recent testing was successful with deleting child devices in the new ST App.
Not sure what to tell you. If your microcontroller is working properly, running ST_Anything, and youâve restarted it, or hit REFRESH on the Parent Device, then the child devices will be recreated.
Did you use the GitHub integration to originally install all of the DTHs? If so, just log into the Web IDE, click âMy Device Handlersâ. Then, youâll see a button near the top of the page that lets you update fro GitHub. Select ST_Anything, and make sure you check all of the updated DTHs AND a select PUBLISH in the bottom right corner before you click Update.
Yes, I used GitHub integration to originally install all of the DTHs.
I found help which explains that green DTHs indicate files exist only in IDE and do not exist in repository. So I must have obsolete DTHS that you renamed at some point in the past?
Child Alarm
Child Relay Switch
Child Temperature Sensor
Child Water Sensor
On/Off Ethernet
I guess I could delete these DTHs?
Help says magenta DTHs have been updated in repository but not IDE.
Since my DTHs are black (unchanged vs repository) or green (only in IDE, not repository), Iâm up to date with repository.
I havenât made any local edits of your DTHs.
So now Iâm stuck since I already deleted and recreated all my child devices and they are not working in new ST app (although they do work in IDE and in classic app)
I was hoping I had a downlevel DTH which was causing the problem.
